Designed specifically for the 230 V market, the Foundry Switch Panel is a high-performance power control solution available with 12-, 24-, or
48-channels of switched power. It intelligently reduces in-rush through phased switch-ons to help
manage today’s modern electrical loads. With optional current monitoring and reporting, the Foundry Switch Panel provides tools for venues to intelligently manage their energy usage.
Center of System
The Foundry Switch Panel is designed to be the center of your entertainment lighting system. It’s fanless construction means it can be used in sensitive environments where you need silent operation. The switched outputs can be individually controlled
by sACN or DMX as they supply power to your system.
It seamlessly integrates into the ETC ecosystem, pairing nicely with ETC Eos consoles and ETC’s architectural controls. It ensures your whole install works in harmony, regardless of the size of your venue.
FSP - DMX |
FSP - Connect |
FSP - Report |
| 12-Circuits |
| 24-Circuits |
| 48-Circuits (using client rack) |
| Convection cooled (fan free) |
| DMX Input |
| sACN Input |
| "Panic" contact input |
| Circuit Protection |
RCD per 4, or RCBO per circuit |
| Current rating |
10A |
10A |
10A |
| Inrush reduction |
Automatic switch-on delays
Automatic & manual switch-on delays |
Automatic & manual switch-on delays, Zero-cross switching
| NFC Configuration via Set Light |
| RDM Configuration |
| Onboard UI |
| Web-UI |
| Current Monitoring and Reporting |
| Five-year warranty |
Ease of Configuration
Built with exacting standards in ETC’s European factory, the Foundry Switch Panel was designed and built in Europe to meet the needs of the market.
Its scalable nature allows you to specify precisely what you need, lowering costs and simplifying the installation process. The Foundry Switch Panel follows EU design protocols, wiring standards, and methodology so electricians can get it working
quickly. You can rest assured knowing everything is built to work together and assembled correctly – resulting in less work for your onsite team.
Configuration is a breeze. The DMX model can be set up using the ETC Set Light App. The Connect and Report models can be configured via the web interface, RDM, or the on-board user interface.
Plus, Foundry Switch Panel is backed by ETC’s legendary 24/7/365 support and 5-year warranty.
Safety from the Start
Unrelenting attention to safety is part of the package. Each channel is protected from current disruptions via a RCD making it easier to comply with local installation requirements. For more information on all the things to consider when upgrading your
system to LED loads, watch our video, “The Balance of Power”.
