New DALI-2 Certified Gateway from ETC
Date Posted: 4/14/2026
ETC announces the new Response DALI Gateway MK2, a DALI-2 certified device developed to meet the growing demand for DALI applications throughout North America and beyond. The gateway features a user-friendly, intuitive web interface that enables quick
setup and effortless status management of fixtures or devices. The Response DALI Gateway Mk2 is DIN-mounted and converts DMX or sACN to DALI. Each device Gateway supports four ports (DALI subnets), each with an integrated bus power supply.
For decades, 0-10V dimming has become the familiar default in North America. Many prioritize low cost and code compliance over the importance of lighting controls. As LED lighting becomes standard and buildings demand greater flexibility and long-term
durability, installing lighting systems based on familiarity is no longer necessary. DALI is at the center of new and emerging conversations about lighting control systems. It’s about providing a solution for clients that maximizes technology, minimizes
cost, and takes into consideration how buildings operate.
LEDs are digital devices, and DALI control acknowledges them for what they are. Instead of sending fluctuating voltages and hoping every fixture responds the same way, DALI sends clear, digital commands. The driver does the work consistently and predictably.
The result is not just better performance; it’s a more desirable outcome. Color temperature stays consistent across long runs. Low‑end dimming is smoother. Flicker is minimized. And the system behaves the same way today, as it will five and ten years
from now.
While DALI drivers typically cost the same as their 0-10 V equivalents, the savings come from everything around them. With DALI, a single control bus can support up to 64 drivers and multiple control groups. This means fewer wires, less conduit, as-needed
control devices, and significantly reduced labor, especially as zone complexity expands. From hospitality spaces to residential high rises, the math is consistent. As the number of zones goes up, DALI becomes more cost-effective.
For facility teams, the advantages continue long after installation. DALI systems can report when a driver goes offline, or a fixture fails, often before anyone even notices. In larger buildings, visibility saves time and labor.
DALI is an open protocol, and all certified devices work with all compliant controllers. DALI-2 certification offers another layer of confidence by ensuring integration through third‑party verification. For ETC, this coincides with a long‑standing commitment
to open standards and customer choice. Lighting systems should serve their buildings, not entrap them.
DMX continues to be essential where speed and theatrical precision are required. But in architectural and commercial environments, such as schools, airports, offices, healthcare facilities, and hospitality venues, DALI integrates into how buildings are
designed, installed, and operated. The real shift is about moving away from outdated analog control and toward digital systems that match modern expectations.
