User > Displays
{Preserve Blind Cue}
This enables the console to display the last selected cue in blind when you return to blind. Disabled by default.
{Blind Next/Last Affects Target}
When enabled, in Blind the Next and Last commands will always apply to channels, if a channel selection is on the command line. Disabled by default.
{Popup Magic Sheet}
Assigns a magic sheet (see About Magic Sheets) that can be accessed via the Quick Access Pop-Up Tools tools.
{Popup Nav Lock}
Enables or disables the zoom and scroll navigation for your {Popup Magic Sheet}. Enabled by default.
{Augment3d Display Behavior}
The following Augment3d display behaviors are available:
- Normal Display - the display will behave the same as other display tabs.
- A locked tab will not be skipped.
- A single click or tap on the tab will draw focus to that tab.
- Channel Display - this mode uses the following rules:
- When focus is drawn to the playback status display, an Augment3d channel display will be brought to the front.
- [Shift] & [Live] will cycle through Augment3d channel displays alongside Live channel displays.
- Pressing [Live] or bringing a Live tab into focus will restore your last focused Augment3d channel display.
- Augment3d channel displays in the locked frame will not be skipped when using the [Tab] key to cycle through tabs.
- Control - the display will behave the same way Control Tabs do.
- Locked tabs will be skipped.
- A single click or tap will not draw focus.
- A double click or tap will draw focus to the tab.
These settings are also available in the Augment3d Tab Configuration menu.
{Display Fader Ribbon}
Element 2 and Element Classic only. Enables or disables the ribbon display showing the status of the faders. When disabled, the fader ribbon will not display. Enabled by default.
{Display Help Prompts}
Element 2 and Element Classic only. Enables or disables the context-sensitive Key Help display in the CIA. Enabled by default.
