Eos Family Resources
Eos [Home]
etcconnect.com/eos-home
ETC offers a comprehensive online hub for the Eos Family featuring resources, software, support, the Eos community forums. and more. If you're new to Eos, training videos and documentation will get you started. For seasoned professionals, in-depth dives into advanced features will help you keep getting the most out of your Eos console.
ETC Knowledge Management System (KMS)
support.etcconnect.com/eos-family
Maintained by ETC's excellent Technical Services team, the KMS provides a wealth of explanatory and troubleshooting resources for current and legacy ETC, High End, and RAYN products.
The KMS should be the primary resource used for troubleshooting ETC equipment and products.
Eos Family Community Forums
community.etcconnect.com
You are encouraged to visit and participate in the Eos Family Community Forums. This gives you access to an online community of Eos Family users where you can read about other users’ experiences, suggestions, and questions regarding the product as well as submit your own.
You may register for the forum by clicking the Join link in the upper right corner of the page and following the provided registration instructions.
Register Your Console
etcconnect.com/MyETC/Account-Management/My-Registered-Products.aspx
Registering your console with ETC ensures that you will be notified of software and library updates, as well as any product advisories.
Registering your console requires an ETC One account. Log in or sign up at etcconnect.com/MyETC/.
Help from ETC Technical Services
If you have questions that are not answered by this document, try the ETC support website at support.etcconnect.com or the main ETC website at etcconnect.com. If none of these resources are sufficient, visit etcconnect.com/contactETC and contact ETC Technical Services. Emergency service is available from all ETC offices outside of normal business hours.
When calling for help, take these steps first:
  • Prepare a detailed description of the problem.
  • Go near the equipment for troubleshooting.
  • Find your ticket number if you have called in previously.
Other Reference Materials
Key Help
Press [Help] to open the Eos key help in the Central Information Area (CIA). Holding [Help] and pressing any hard or softkey will display the following information:
  • The name of the key.
  • A description of the key's function.
  • Applicable syntax examples for using the key.
  • Links to relevant topics in the manual.
Element Prompts
Element 2 and Element Classic provide additional onscreen prompts in the CIA help area to aid with programming. These prompts dynamically change with the current display or key input to give context-sensitive instructions and options. The prompts can be enabled or disabled via Setup > User > Displays > {Display Help Prompts}.
