Editing Palettes in Blind
Note: [Palette] is used in the examples below. Element Classic users will need to use {Palette}.
All palettes can be viewed and edited in Blind. To open a palette in Blind, you can do any of the following:
- [Blind] [Palette] [Enter] - pressing this will display the first recorded palette of the selected type (Intensity, Focus, Color or Beam) in Blind or return to the last palette of this type viewed in blind.
- [Blind] {Palette Select 3} or [Blind] [Palette] [3] [Enter] - pressing this will display the specified palette in Blind.
- [Palette] [Palette] {Edit} - opens the list view of the palette type and then opens Blind palette. You can also use the tab number to open the list view. See Editing Palettes in List View for a list of tab numbers.
CAUTION: When editing palettes in Blind, changes to palettes are automatic, therefore no update or record command is required.
Palettes can be viewed and edited in blind in the table and spreadsheet views. In Blind, the following softkeys are available when editing palettes:
