Pixel Map Media
Image, video, HTML, and text files can be applied to a pixel map. A stock library of media can be obtained by installing the Eos Family Pixel Mapping Installer.
Importing Media Content
Additional media content can be imported. Files must follow the naming convention filenumber_filename; for example, 002_Volcano.mov.
Size, resolution and length of any imported content should be as minimal as possible. For example, stock video content is under 10MB, under 320x180 resolution, and between 2-20 seconds.
Import All Pixel Map Media
Automatically import media via File > Import > Pixel Map Media > All Pixel Map Media.
Options when importing include:
  • {Library (1-255)} - selects the library to import media.
  • {File (0-255)} - selects the file number.
  • {Reorder Libraries} - specify whether or not the library on the source device will be renumbered. If the source device’s library is not numbered, it will be assigned the specified library number.
  • {Reorder Files} - specify whether or not the files on the source device will be renumbered. If the source device’s files are not numbered, they will be assigned the specified file number.
  • {Overwrite} - overwrite the existing media files.
  • {Start Import} - begins the import process. A progress bar will appear to indicate the status of the import process. When finished, select {Done}.
  • {Cancel} - stops the import, and exits the display.
Import Show Pixel Map Media
Automatically import all media needed for the current show file used by backup and client consoles via File > Import > Pixel Map Media > Show Pixel Map Media. See Synchronizing Media Archives.
Import with the File Manager
Manually import media via ECU > Settings > Maintenance > {File Manager...}. Files should be numbered manually prior to import.
Streaming Media
Available video streams can be selected and used directly as pixel map media. Options are configured via Setup > System > Video Streams > {Video Stream Pixel Maps}.
Supported Media Formats
  • .svg
  • .tiff
Video
The following video formats are recommended:
  • .mov (.H264 encoding)
  • .mp4
For a full list of supported video formats, please consult etcconnect.com.
HTML & Text
  • .htm
  • .html
  • .txt
Exporting Media Content
Export Pixel Map Media
Automatically export all the media used in the current show file via File > Export > Show Pixel Map Media, selecting the device to which you want to export the media content. This includes any pixel map media stored in cues, presets, submasters, etc.
There are only two options available in this display:
  • {Start Export} - begins the export process. A progress bar will appear to indicate the status of the import process. When finished, select {Done}.
  • {Cancel} - stops the export and exits the display.
Export with the File Manager
Exporting with the file manager is very similar to importing with it. You select the files in the MediaArchive folder that you wish to export, and you can either copy or move them to your device.
