Magic Sheet Layout Toolbar
Expand individual sections below to view more information, or use the Expand All button in the topic toolbar.
The layout toolbar is always visible at the top of the editor, providing various options for adjusting and arranging magic sheet objects.
Undo and Redo
Use {Undo} and {Redo} to revert and restore changes made while in the Magic Sheet Editor. When hovered over, a tooltip will provide a description of the action to be undone or redone. When no available actions can be undone or redone, the respective button is disabled.
These tools can also be activated with the default Windows or macOS keyboard shortcuts for undo (CTRL+Z or CMD+Z) and redo (CTRL+Y or CMD+Y).
{Grid Toggle}
A grid is overlaid on the magic sheet background by default, which objects snap to when positioned. To hide or show the grid, use the {Grid Toggle} (CTRL+I) button at the left of the toolbar. When disabled, objects can be freely positioned without snapping.
Zoom
The zoom tools adjust the view of the magic sheet open in the editor.
Alignment and Distribution
These tools adjust the physical positions of the objects in the magic sheet.
{Create Array}
The array tool creates arrays of a selected object. With the object selected, use {Create Array} to open a pop-up menu to define the array shape and size.
Align
These tools alter the position of selected objects relative to a common point.
Distribute
These tools alter the position of selected objects based on the distance between them.
{Flip}
Reverses the positions of one or more selected objects horizontally or vertically.
New positioning is previewed as soon as {Flip} is used. Select {Accept Flip} to apply the results, or {Cancel Flip} to close the flip options without making changes.
{Mirror}
{Mirror} (CTRL+M) duplicates one or more selected objects, mirroring them across a chosen axis.
Group and Order
The order tools adjust the relationships between the objects in a magic sheet.
Layout
The layout tools affect how objects can be added to a magic sheet from the Magic Sheet Object Library.
Target Bar
The target bar is always visible below the toolbar, indicating a target type, the target number that will be used for the next object, and the increment used between those target numbers.
Modes
The magic sheet cursor modes allow you to add and interact with objects in various ways. The current cursor mode will be outlined in gold.
