  • WRFU IPAQ 5500 Will Not Connect to the Access Point
    After following the user manual's instructions for setting up both the access point and the IPAQ, you may need to:
    1. Hit soft reset on the bottom of the unit after changing network settings. Then check for functionality
    2. If the PocketPC won't connect and you can't enable the WIFI connection: ensure the unit is charged.
    3. Remove the battery from the IPAQ.  This performs a deep reset that will clear out any settings that may have gotten stuck in the program.
