  • Why Are My Relays Chattering or Not Firing?
    If your relays are chattering or not firing in your Sensor, Sensor+ or Unison rack there may be a problem with the neutral wire on your signal distro card.  Make sure that the neutral wire is present and connected on both ends.  This problem can also cause ELV10 modules to not work correctly in test mode in Sensor+ racks.
