  • Troubleshooting Analog Address Systems-Public
    When troubleshooting AAS problems, you need to verify the following to solve the problem.
    LED activity:
    Do stations have LED activity?
    Is green LED (12V DC rail) on AAS processor lit?
    LCD screen activity:
    Is there any information on the LCD screen? In monitor mode?
    Fuses:
    Check if fuses are installed and good?
    Station voltage:
    Do stations have 12V DC?
    Software Setup:
    Is console mode set correctly?
    Is patch correct?
    Switches on AAS processor:
    Does anything change when you toggle them?
    [Reset\Normal]Resets AAS processor
    [Term on\Term off]Terminates DMX input
    [Bypass\Normal]Bypasses DMX input
