  • SMPTE Input Range For Expression 2 and 3
    You can increase the dynamic range of the SMPTE input by adjusting the offset voltage of the amplifier.
    The range of the SMPTE input with is:
    • +3 to +14 dBu (without bypass jumper)
    • 20K input 0 to +14 dBu (with bypass installed)
    This can be adjusted down for input attenuation and matching if required.
    Make sure to always measure SMPTE is with a true RMS averaging meter.
