  • Smart Macro Keys for Express Lighting Playback Controller-Public
    Supported in software version 3.02 and Higher
    The key to the execution of many of these functions is to press and hold the Macro 7 key.
    Note: These Macros keys are not supported in software version 3.01, 3.0 and 2.0
    Reboot
    (either method seems to work)
    • Press and Hold Macro 7
    • Press Macro 1 and Macro 5 while still holding Macro 7
    • Release Macro 7
    • Release Macro 1 and Macro 5
    • Press and release Macro 7 while still holding Macro 1 and Macro 5
    Stage
    • Press Macro 1 while still holding Macro 7
    • Release Macro 7Release Macro 1
    • Press and Hold Macro 1
    • Press and release Macro 7 while holding Macro 1Release Macro 1
    Patch
    • Press Macro 3 while still holding Macro 7
    • Release Macro 7
    • Release Macro 3
    • Press and Hold Macro 3
    • Press and release Macro 7 while holding Macro 3
    • Release Macro 3
    Setup
    • Press Macro 4 while still holding Macro 7
    • Release Macro 7
    • Release Macro 4
    • Press and Hold Macro 4
    • Press and release Macro 7 while still holding Macro 4
    • Release Macro 4
    (essentially the down arrow key)
    • Press and Hold Macro 1 and Macro 2
    • Push and release Macro 7 to step through the options
    (essentially the up arrow key)
    • Press and Hold Macro 2 and Macro 3
    Carriage Return (Enter)
    • Press and Hold Macro 1 and Macro 3
    • Push and Release Macro 7 to execute the "enter"  command
    Hardboot (at boot up only)
    • Press and hold Macro 2 and Macro 4 and Macro 6 while turning on the power
    789 Deep Clear
    • Press and hold Macro 1 and Macro 3 and Macro 5 while turning on the power
    • Read System Configuration
    • Put disk in drivePress and Hold Macro 7
    • Press [Read From Disk] while holding Macro 7
    • Release Macro 7
    • Release [Read From Disk]
    • Read Show
    • Put disk in drivePress Read From Disk
    Other: On a curious note, in software version 3.0 if you hit Macro 7 and Macro 2 you see the Help menu pop up, but no way to navigate. If you hit M7 again you see the fader display, but no way to navigate.  How fun.
    Note:   You should know that the 96-channel and 192-channel LPC's will default to "Two Scene" mode. This causes the A/B fader to act as a crossfader and not a cue fader.
    If someone is running a show written in an Expression Console and they need to reference a Macro to a cue, have them run the cue in the C/D fader pair.
    You can write a macro to change into 1-scene mode.
    • Setup
    • 1 Enter
    • 15 Enter
    • 1 Enter
    • Stage.
    • Then run the Macro.
