  • Setting DMX Address on the CEM+ (Basic/Portable)
    Note: Basic/Portable mode is a simplified setup mode in CEM+ version 2.0 and above, intended for portable/touring racks. In basic/portable mode, the only active DMX is port A input. Once a unit is configured and running in basic/portable mode, anyone can press checkmark from the front panel to quickly reset the DMX address.
    1. Press checkmark.
    2. Use [+]/[-] to adjust the starting DMX address.
    3. Press checkmark. (You may have to press and hold for the system to recognize this because it takes a bit to register.)
