  • Setting Contrast on a PACP Display-Public
    If you encounter a PACP with what appears to be a dim screen, the likely issue is that contrast has gone off a bit. To change it,
    • Go to the home screen on the PACP (Exit all the way out)
    • Hold the back button down for 3-5 seconds
    • While still holding the back button use the wheel on the facepanel to run Contrast up and down
    • There is no need to save the setting. It is a persistent hardware value
