  • Sensor Flickering
    There are a number of issues that can appear as "flickering" in a Sensor dimmer rack.
    • Airflow issues are a common reason that all dimmers in a rack might flicker together: /Support/Articles/Dimming-Switching/Legacy/
    • DMX problems might cause all dimmers in all racks to flicker sporadically.  This flicker will usually "pop around" with different dimmers blinking at different rates and times.
    • Power problems might cause all dimmers in all racks to flicker together or for dimmers powered from a specific phase of power to have issues across all racks, while the remaining dimmers behave normally.
    If these things do not seem to describe the issue, contact ETC Technical Services.
