  • Sensor Classic Low Voltage Pinout (J2)
    This pinout can also be found in the Sensor Installation Guide
    PinSignal
    1DMX A -
    2DMX A +
    3DMX A/B Common
    4Panic In (Usually switched with Pin 6)
    5Beacon Drive
    6Panic +10 VDC (Usually switched with Pin 4)
    7Panic Out Common
    8Panic Out 12Vdc (Used to drive Panic indication LED's/lamps)
    9DMX B -
    10DMX B +
    11ETCLink Voltage +12Vdc
    12ETCLink Voltage Common
    13ETCLink Data
    14ETCLink Data
