  • Remote Device Jumper/DIP Switch Guide
    REMOTE VIDEO INTERFACE (RVI)
    Switch Sets S1 and S2 (on right side of exterior) select Network cable type.S1 is front and S2 is rear (Front is face w/RFU connector).
    S1
    S2
    Action
    Up
    Down
    Twisted Pair (UTP) active
    Down
    Up
    ThinNet active
    Switch Set S4 (mounted above I960, interior of RVI)
    Switch
    Function
    Position
    Action
    1
    Factory
    Up
    Should always be on
    2-5
    Factory
    Down
    Should always be off
    6,7
    Factory
    Up
    Should always be on
    8
    Factory
    Down
    Off (Open) =Down,  On (Closed)=Up
    REMOTE INTERFACE UNIT (RI or RIU)
    1. Switches are either On (Closed) or Off (Open). \
    2. DIP switch 1 must be Off and 2 must be On or the Remote Interface will not   start.
    Jumper Field J22 (lower left corner) selects network cable type:
    ETCNet Jumpers for Rev A PCB (J22)
    1. Locate jumpers 1 through 14.
    2. For BNC connector (Thin-Net), install jumpers 1 through 6. Jumpers 7 through 12 are not installed.
    3. For RJ45 connector (Twisted Pair) or the DB15 connector (ThickNet), install jumpers 7 through 12. Jumpers 1 through 6 are not installed.
    4. Jumper 14 should always be on, and Jumper 13 must always be Off, or RI will not start.
    ETCNet Jumpers for Rev 0 PCB (J22)
    2. For BNC connector (Thin-Net), install jumpers 9 through 14.  Jumpers 3 through 8 are not installed.
    3. For RJ45 connector (Twisted Pair) or the DB15 connector (ThickNet), install only jumpers 3 through 8. Jumpers 9 through 14 are not installed.
    4. Jumper 1 must always be On, and Jumper 2 must always be Off, or RI will not start.
    Verify that the Node Card is getting proper DC voltage by metering between TP1 and COM.  You should get 5.05Vdc between these two points. If not adjust voltage at the power supply so that you get 5.05Vdc between TP1 and COM.
    Other Jumpers
    Switch Set S1 (lower right corner)
    Switch
    Function
    Position
    Action
    1
    Factory
    Up
    Should always be up (off)
    2
    Factory
    Down
    Should always be down (on)
    3-5
    Factory
    Up
    6
    DMX Ports
    Up
    Selects 1-1536 (off)
    Down
    Selects 1537-3072 (on)
    7,8
    Factory
    Up
    Off=Up, On=Down
    Note: The Remote Interface Unit is modified to support ports 7-9 on the Obsession II 4600.
