  • Reflection: How to Set Up Slave Unit-Public
    Reflection unit.
    Question:
    How do you slave two Reflection consoles together?
    Answer:
    • Open the console.
    • Remove Jumpers on the right of the large ribbon cable. Labeled LK2 and LK3.
    • Add jumper at "C" to the left of the large ribbon cable, Remove at "D."
    • Use a Straight Serial cable, using Pins 1-3 only.
    • Cable to be no longer than 8 feet. The shorter the better.
    • Software in both units must be 2.07 at IC5
      Cable Pin out is:
      1 = Common
      2 = DATA
      3 = CLOCK
    • Must set a unique ID number for each unit.
    • Slave face panel becomes inactive.
