  • RD-2034A and RD-2034C Self Tests
    To put the unit into self-test mode, set the "10's" thumbwheel to 9 and hit reset.
    Once this is done, use the "one's"  thumbwheel to activate the needed self-test.
    90 - ?
    91 - test thumbwheels, outputs binary to lights
    92 - chase
    93 - fade all, (if there is flickering, it is due to bug in software)
    94 - chase fade
    95 - Dimmer select. (01 on thumbwheels turns on dimmer #1)
    96 - Ram Test?
    97 - ?98 - pulsing then resets and starts again
    99- all onAfter self test is running, speed is set by adjusting UNITS thumbwheel (1=fastest, 9=slowest, 0=freeze)
