  • Proper Installation of Dimmer Modules in Sensor+ SineWave Racks
    When installing SineWave dimmer modules in a Sensor+ rack, always insert modules starting at the bottom of the rack and work your way up. As you insert each module, make sure it is fully-seated in its slot and that the bus bars make proper contact with the module.
