  • Portable 6-channel SmartPack Rear Power Outputs
    Question:
    How Many Power Outputs Come with the Portable 6-channel SmartPack?
    Answer:
    For Edison, Stagepin, and PowerCon versions, each 6-channel Portable SmartPack unit comes with 12 connectors. So for each circuit there are two physical connectors on the back of the Portable SmartPack.
    The Portable SmartPacks with Twist-lock connectors only come with 6 available connectors. So for each circuit there is only one physial connector on the back of the Portable SmartPack.
