Pinout for an EBY connector on a Kodak projector remote
The pin out for an EBY connector on a Kodak projector remote are:
MALE (Remote) 2 1  53   4
Pins 1 and 2 are closer together and generally have a dot or other mark between them on the case.
Forward is a dry contact closure between pins 2 and 5.
Reverse is a dry contact closure between pins 3 and 5.
Pins 1 and 4 are used for remote focus and varies slightly between the E2=and E3 models.
The pinout for the Kodak E-III remote is as follows:
1 - Focus+
2 - Forward
3 - Reverse
4 - Focus-
5 - Common 28v AC
For your purposes you will need pins 2,3 and 5.
If you are running a really long extension, be aware that you might have problems with voltage drop...
You'll know this is happening when the projector doesn't advance reliably. Hopefully you have some really heavy-duty 3-pin XLR cablelying around -  use the largest gauge cable possible.  (Keep in mind that for voltage drop calculations the cable length is *double* the physical length because control power has to come all the way from the projector to your control pickle and back.)  Also, be sure when making your adapters that you don't use the XLR shield ground or you could get bit by 28 volts from the projector. The current is minimal, but you could easily short the projector power supply and/or lose your balance on a ladder... :
Note For the Curious: Pins 7 & 8 are for externally switching (or dimming) the projector lamp on the E-III.  With the fan switch on, 82v AC from the projector will appear on one of those pins; the other pin goes directly back to the lamp, bypassing the Hi/Lo switch.  You can connect pins 7 & 8 to the two wires of almost any dimmer or switch to take control of the lamp. Yes, garden-variety household dimmers will work, even though it's 82 volts instead of 115.  Voltage drop can be a problem with the lamp, too, especially if you need a really bright image.
 FWIW, As I write this I'm running a show that uses CD-80 dimmers to run Kodak projectors
I run all of the projector functions from the light board, programmed with the light cues - works great!
The source I have used for EBY connectors is:
RMF Products
1275 Paramount Pkwy
PO Box 520
Batavia IL
60510
630-879-0020
630-879-6749 Fax
Jon Lagerquist
Technical Director @ South Coast Repertory, Costa Mesa, CA
