  • Obsession II Face Panel Keyboard Unresponsive ( Sub Mode )
    Symptom:
    None of the keys on the keyboard including GO and Stop/Back. However submasters seem to work normally.
    Cause:
    Someone has reset the Face Panel to operate in Submaster Mode. Because a Submaster Panel doesn't have a keyboard, the unit does not respond to keyboard input.
    Resolution:
    1. Reboot Obsession Console
    2. When prompted to press GO+STOP/BACK, press sub bumps 1,2,3, & 4 simultaneously.
    3. At menu screen navigate using sub bump 1 as up arrow, bump 2 as down arrow, bump 3 as enter, bump 4 as clear. Go into Category 6 (Console Mode)
    4. Select option 1 (Full Console Mode)
    5. Return to previous screen with S8 (sub bumps 25-32 are S1-S8 respectively)
    6. Press S8 again to start in console mode
