• Net3 Radio Focus Remote (RFR) Startup Modes
    When the RFR starts up, it can be put into a variety of different modes by holding down keys on the keypad. A summary of those modes is shown here.
    [More SK]
      Software Upgrade Mode
    • Screen Displays "Remote boot Version0.3"
      RFR Setup Mode
    • Set frequency, net id, signal strength, backlight timer, reset defaults.
    • Softkeys are Prev, Next, Save, and Default
    Default Settings: HF 1, Net Id 1, HF Power +18dBm, Backlight time 1 min.
      Range Test Mode
    • Remote connects to closest base
    • Any key press will generate feedback on signal strength.
    • Remote will switch bases
      Console Selection Mode
    • Allows user to choose between Direct USB mode, Base USB mode, and available host consoles.
    • Base USB mode is only presented as an option when an Base connected via USB is detected.
      Base Station List Mode
    • Provides signal strength to all available bases in a list format.
    • Provides feedback from bases in Master, Slave or USB mode.
