  • Micro II Pinout and Protocol
    Overview
    Micro II is an asynchronous, differential digital protocol primarily used for backplane control communications between RD-2031 cards and RD-2034 cards.  In a few facilities, consoles (such as the CH200 or Designer from LMI) used Micro II to send dimmer information to the RD-2034 cards directly.  Conversion of the facilities to DMX usually will require a custom configured RD-2031B card and standard code installed in the RD-2034A or RD-2035 card.  Also, the console and control connectors must be replaced.  This is not an easy conversion so plan for time in parts programming and installation.
    Micro II from a console uses a 3-pin XLR connector.
    Pinout
    Pin
    Signal
    N/C
    2
    Data -
    3
    Data +
