  • Expression/Express Programming cheat sheet
    Basic Operations
    Patch dimmers to channels
    In [Patch] display:
    • Enter dimmer number(s).  Can use [And] and [Thru] commands. Press Enter.
    • Enter channel number .Press Enter
    To unpatch dimmers
    In Patch display:
    • Enter dimmer number(s). You can use [And] and [Thru] commands to select multiple channels. Press Enter.
    • Enter channel number. Press Enter.
    Setting channels at levels
    • Chan N At XX
    • Chan N Full
    • Chan N {Finger on Trackpad}
    • Chan N At [+] or [-]
    Record a cue
    • Set channels at desired levels.
    • Press Record.
    • Enter the cue number. Press Enter.
    Changing fade time on a cue
    • Select Cue number
    • Press Time.
    • Enter upfade time. Press Enter.
    • Enter downfade time. Press Enter. (If no difference from upfade time, just press Enter.)
    Delete a cue
    In Blind display:
    • Select S6 Softkey {Delete Cue}
    • Enter cue number to be deleted.
    • Press Enter. Press Enter again to confirm.
    Record a submaster
    • Press Record then Sub.
    • Enter the sub number.
    • Press Enter.
    • OR
    • Press Record.
    • Press the bump button of the sub where you want the look recorded.
    Delete a submaster
    In Blind display:
    • Press Sub.
    • Select S6 Softkey {Delete Sub}
    • Enter sub number to be deleted. Press Enter.
    • Press Enter again to confirm.
    Save show to Disk
    In Setup display:
    • Select menu item 3 -- Disk Functions.
    • Select menu item 1 -- Write show to disk. Press Enter. Press Enter again to confirm.
    Effects (Chases)
    Creating a simple chase
    • Press [Blind] [Cue] [100] [Type] [3].
    • Press [S1], Step, and enter [1] [Thru] [1] [0]. Press [Enter].
    • Press [1] [Thru] [1][0], the range of channels to assign to the steps. Press [S8] -- Add Channels.
    • Channels are assigned to steps as indicated above; see chart below.
    • Press [Record] [Enter].
    StepsChannels
    Step 11
    Step 22
    Step 33
    Step 44
    Step 55
    Step 66
    Step 77
    Step 88
    Step 99
    Step 1010
    Assigning attributes
    • Press [S7] -- More Softkeys, then [S8] -- Attribute.
    • Select attributes from the softkeys on the screen. All effects are either Positive or Negative.
    • Additional Attributes include: Alternate, Reverse, Bounce, Build and Random
    Note: To remove an attribute, select it again.  It is helpful to take time to play with a simple effect, changing its attributes, its timing and its low and high levels.
    Working with Moving Lights
    Patching fixtures
    In Setup display:
    Select Menu item 15, Moving Light Functions Select Menu item 2, Fixture Patch Enter fixture number(s). Can use [And] and [Thru] commands Press [Enter] to move through columns.In the Personality column, use [+] and [-] to select personalities. Enter Start Channel.Enter DMX Port and Starting Address[1] [Enter] [1] [Enter].
    Working with the fixture window
    • Press [S8]-- Fixture [1] [Enter] [1][Thru] [-] selects all fixtures.
    • [+] or [-] scrolls thru fixture numbers or scrolls thru attributes on selected page­ or the page buttons scroll thru attribute pages
    Record a focus point
    • Aim fixtures at desired location.
    • Check Intensity On, Open strobes/irises, motor speed settings.
    • Position each fixture on the selected area.
    • Press [Record] then [Focus Point]. Enter the number.Press [Enter].
    Setting fixtures at focus points
    • Fixture N At FP X Enter
    • Can use [And] and [Thru] commands
    • Fixture N Only [Category] At FP X Enter
    • Categories: Position, Color, Beam, Image
    Update focus points
    • Aim fixture(s) at new or changed location.
    • Press [S2]-- Update then [Focus Point]. Enter the number. Press [Enter].
