  • Eos Family Local I/O Relay Out and Contact Closure Inputs
    Eos Ti, Gio, Ion, Element, and Ion RPU all have local I/O ports that include a DB15 connector with four contact closures and a single relay out. For additional closures or relays, a Net3 I/O Gateway would be needed.
     Pin Out
    To use the Relay Out
    Example:
    [Cue][1]{Execute}{Relay}[1][/][1]{On}[Enter]  --- This will turn relay 1 in "Relay Out Group 1" on when cue 1 is fired.
    [Cue][2]{Execute}{Relay}[1][/][1]{Off}[Enter] --- This will turn Relay 1 in "Relay Out Group 1" off when cue  2 is fired.
     Relay
    Relay setup is located in the shell.  (See photo below)
    To use the Contact Closure Inputs:
    Use the "Show Control Display" to setup the functionality of the inputs.
     Show Control
    "Type" is Analog
    "Source" is the Contact Closure Group #
    "Address" is the Contact Closure Address within that group.
    To setup the Relay and Contact Closure inputs:
    Exit the console to the shell. Choose Settings > Local I/O
     Local IO
