  • Enabling Or Disabling Data Ports
    Enabling/Disabling Data Ports
    •  Push the setup button []
    • Scroll down to [Rack] and push [Enter]
    • The Data Ports section is the second from the top so you should see it right away.
    • Scroll down until DMX A:        [Enabled] is highlighted.
    • To disable DMX A push [Enter] and change [Enabled] to [Disabled].
    • Do the same for DMX B:         [Enabled], which is the next one down.
    • Do the same for sACN:           [Enabled], which is the last one.
