• Emphasis Will Not Serve Out IP Addresses to Nodes
    If you have just reset the IP address of the server, it will not serve out IP addresses to nodes.
    Reboot the server and it will be fine.  The problem is that ETC Net2 Services will not work properly after changing the server's IP address until it is rebooted.
