  • DOS Navigation Tricks
    CHDIR or (CD)
    Displays the name of the current 'directory or changes the current directory.".." move one directory up. "\" changes to the root.
    COPY
    Copies one or more files to the location you specify.
    DEL
    Deletes the files you specify. /P Prompt
    DELTREE (Be careful with this command!!!!!)
    Deletes a directory and all the files and sub directories that are in it.
    DIR
    Displays a list of the files and subdirectories that are in the directory you
    specify.
    /W = Wide   /P = Pause
     /A D = Directories only /A -D = Without directories
    Sorting:
     /O N  by name ,Alphabetically
     /O D  By date earliest first
     /O S  By size Smallest first
    MKDIR or (MD)
    Creates a directory.
    You can use the MKDIR or MD command to create a multilevel directory RMDIR or
    (RD)
    Deletes (removes) a directory.
    Before you can delete a directory, you must delete its files and subdirectories. The directory must be empty except for the "." and ".." symbols.
    XCOPY
    Copies directories, their subdirectories, and files (except hidden and system files). With this command, you can copy all the files in a directory, including the files in the subdirectories of that directory.
