  • Color Scheme of Channel Assignments In The Expression-Express Family
    CHANNEL NUMBERS/STANDARD PATCH:
    Gray Unselected channel
    White Channel is not selected by Only Function
    Yellow
    Selected channel. Controlled by the "Y" wheel
    CHANNEL NUMBERS/FIXTURE PATCH:
    Gray bar Surrounds all channels of one fixture
    Light gray Low channels for 16-bit data types
    Gold Channels linked through the link list or fixtures
    Yellow Selected channels of selected fixtures
    CHANNEL OUTPUT LEVELS:
    White on Red Channel level when it is being changed
    Yellow In Stage, a channel in yellow was set by a sub master
    White In stage, a channel in white was set by an effect. In Blind, a channel in white was set by a sub master, group, focus point. Or an all fade cue
    Gray Channel was recorded into a multi-part cue, but not in the currently displayed part (Blind only)
    Red In Stage, captured channels are in red. In Blind, channels not recorded are in red
    Green Channel output levels are changed from what was in the previous cue. In Blind, channel output is lower than it was in the previous cue
    Purple Channel output level is the same as it was in the previous cue (tracking)
    Blue In Blind only, channel output level is higher than it was in the previous cue
