  • Can I Change the Field Angle (Degree) of a Source Four by Moving the Lenses within the Lens Tube?
    Each field angle uses a unique lens. The lenses are different sizes and each lens has a colored dot on it's edge to identify its placement.
    So you cannot simply move a lens around in a tube to change the degree spread.
