OSC Dictionary
OSC Inputs
If a user ID is not specified, the command defaults to the current Eos user. You can use /eos/user/-1 to revert from a virtual OSC user back to the default.
| Address Pattern | Arguments | Examples | Notes |
| /eos/active/switch/coarse/<index>=<level> | <index>: Int, 1-based index referencing the list of current parameters for the selected
channel(s). <level>: Int, number of coarse wheel ticks to continuously change the parameter by. |
/eos/active/switch/coarse/1=2.0 - Increases the parameter indexed by 1 (likely intensity) by 2
coarse wheel ticks continuously. |
Eos will send the parameter name and current value for each active parameter, so that the wheels on your
OSC-enabled device may be labeled appropriately. Switch is a variant of Wheel with the added functionality of continuously repeating wheel ticks until a subsequent OSC switch command sets the wheel ticks to zero. |
| /eos/active/switch/fine/<index>=<level> | <index>: Int, 1-based index referencing the list of current parameters for the selected
channel(s). <level>: Int, number of fine wheel ticks to continuously change the parameter by. |
/eos/active/switch/fine/1=2.0 - Increases the parameter indexed by 1 (likely intensity) by 2 fine
| /eos/active/wheel/coarse/<index>=<level> | <index>: Int, 1-based index referencing the list of current parameters for the selected
channel(s). <level>: Int, number of coarse wheel ticks to change the parameter by. |
/eos/active/wheel/coarse/1=2.0 - Increases the parameter indexed by 1 (likely intensity) by 2
coarse wheel ticks. |
OSC-enabled device may be labeled appropriately. |
| /eos/active/wheel/fine/<index>=<level> | <index>: Int, 1-based index referencing the list of current parameters for the selected
channel(s). <level>: Int, number of fine wheel ticks to change the parameter by. |
/eos/active/wheel/fine/1=2.0 - Increases the parameter indexed by 1 (likely intensity) by 2 fine
wheel ticks. |
| /eos/active/wheel/<index>=<level> | <index>: Int, 1-based index referencing the list of current parameters for the selected
channel(s). <level>: Int, number of wheel ticks to change the parameter by. |
/eos/active/wheel/1=2.0 - Increases the parameter indexed by 1 (likely intensity) by 2 wheel
ticks. /eos/active/wheel/1=-2.0 - Decreases the parameter indexed by 1 (likely intensity) by 2 wheel ticks. |
OSC-enabled device may be labeled appropriately. Defaults to Coarse mode, but wheel mode can be changed with the /eos/wheel command. |
| /eos/active/switch/<index>=<level> | <index>: Int, 1-based index referencing the list of current parameters for the selected
/eos/active/switch/1=2.0 - Increases the parameter indexed by 1 (usually intensity) by 2 wheel
ticks continuously. /eos/active/switch/1=-2.0 - Decreases the parameter indexed by 1 (usually intensity) by 2 wheel ticks continuously. /eos/active/switch/1=0 - Stops the continous change in the parameter indexed by 1. |
OSC-enabled device may be labeled appropriately. Switch is a variant of Wheel with the added functionality of continuously repeating wheel ticks until a subsequent OSC switch command sets the wheel ticks to zero. Defaults to Coarse mode, but wheel mode can be changed with the /eos/switch command. |
| /eos/addr=<address> /eos/addr/<address>=<level> /eos/addr/<address>/dmx=<dmx level> |
<address>: Int. The absolute address to select. <level>: Float, 0.0-100.0. Useful for mappinig to an OSC fader. <dmx level>: Int, 0-255. |
/eos/addr=513 - Selects Address 513 (2/1). /eos/addr/513=100 - Sets Address 513 to output 100%. /eos/addr/513/dmx=255 - Sets Address 513 to output a DMX value of 255. |
While addresses are on the OSC command line, they are parked. |
| /eos/at/+% /eos/at/+%=<button edge> |
<button edge>: Float. 1.0=down (default), 0.0=up. Optional to specify a button edge. |
/eos/at/+% - Adjusts the currently selected params by +%, according to its setting. |
Adjusts the current selection by +%, as specified in Setup. |
| /eos/at/-% /eos/at/-%=<button edge> |
/eos/at/-% - Adjusts the currently selected params by -%, according to its setting. |
Adjusts the current selection by -%, as specified in Setup. |
| /eos/at/full /eos/at/full=<button edge> |
/eos/at/full - Sets the currently selected params to their Full levels. |
Sets the current selection to their Full levels. |
| /eos/at/home /eos/at/home=<button edge> |
/eos/at/home - Sets the currently selected params to their Home levels. |
Sets the current selection to their Home levels. |
| /eos/at/level /eos/at/home=<button edge> |
/eos/at/level - Sets the currently selected params to the Level value. |
Sets the current selection to the Level value, as specified in Setup. |
| /eos/at/max /eos/at/max=<button edge> |
/eos/at/max - Sets the currently selected params to their Maximum levels. |
Sets the current selection to their Maximum levels. |
| /eos/at/min /eos/at/min=<button edge> |
/eos/at/min - Sets the currently selected params to their Minimum levels. |
Sets the current selection to their Minimum levels. |
| /eos/at/out /eos/at/out=<button edge> |
/eos/at/out - Sets the currently selected params to Out. |
Sets the current selection to Out. |
| /eos/at/remdim /eos/at/remdim=<button edge> |
/eos/at/remdim - Dims all other unselected channels. |
Dims all channels that aren't in the current selection. |
| /eos/at/<level> /eos/at/dmx=<dmx level> |
<level>: Float, 0.0-100.0. <dmx level>: Int, 0-255. |
/eos/at=75 - Sets the currently selected params to 75. Useful for mapping to an OSC
fader. /eos/at/dmx=128 - Sets the currently selected params to output a DMX value of 128. /eos/pan/at/10 - Sets the current selection's Pan parameter to a value of 10. |
Sets the current selection to the specified level. Multiple parameters can be targeted in any /eos/at/ method by listing each one as <param1>/<param2>/.... |
| /eos/bp/fire=<index> /eos/bp/<index>/fire=<button edge> |
<index>: Beam palette number to fire. <button edge>: Float, 1.0=down (default), 0.0=up. Optional param to specify button edge. |
/eos/bp/fire=1 - Runs Beam Palette 1. /eos/bp/1/fire - Runs Beam Palette 1. |
Fires (executes) beam palettes. |
| /eos/bp=<index> | <index>: Beam palette to select. |
/eos/bp=1 - Selects Beam Palette 1. |
Use to select beam palettes. |
| /eos/chan/<chan>/color/hs=<hue>, <saturation> | <chan>: Channel number. <hue>: Float, 0.0-360.0. <saturation>: Float, 0.0-100.0. |
/eos/chan/1/color/hs=330.0, 75.0 - Chan 1 set to pink color with 75% saturation. |
Changes the given <chan> to the specified color. |
| /eos/chan/<chan>/color/hsxy=<x>, <y> | <chan>: Channel number. <x>: Float, 0.0-1.0. <y>: Float, 0.0-1.0. |
/eos/chan/1/color/hsxy=0.82, 0.31 - Chan 1 set to pink color with 75% saturation. |
Changes the given <chan> to the specified color. For simulating the Hue/Saturation wheel in a 2D XY graph where bottom-left corner is (0.0, 0.0) and top-right corner is (1.0, 1.0). |
| /eos/chan/<chan>/color/rgb=<red>, <green>, <blue> | <chan>: Channel number. <red>: Float, 0.0-1.0. <green>: Float, 0.0-1.0. <blue>: Float, 0.0-1.0. |
/eos/chan/1/color/rgb=1.0, 0.25, 0.63 - Chan 1 set to pink color with 75% saturation. |
| /eos/chan/<chan>/color/xy=<x>, <y> | <chan>: Channel number. <x>: Float, 0.0-1.0. <y>: Float, 0.0-1.0. |
/eos/chan/1/color/xy=0.464, 0.254 - Chan 1 set to pink color with 75% saturation. |
Changes the given <chan> to the specified color. For setting (x, y) chromaticity point in the CIE 1931 xyY color space. |
| /eos/chan/<chan>/color/xyz=<x>, <y>, <z> | <chan>: Channel number. <x>: Float, 0.0-1.0. <y>: Float, 0.0-1.0. <z>: Float, 0.0-1.0. |
/eos/chan/1/color/xyz=0.851, 0.466, 0.516 - Chan 1 set to pink color with 75%
saturation. |
Changes the given <chan> to the specified color. For setting(X, Y, Z) color point in XYZ color space. |
| /eos/chan/<chan>/pantilt = < x>, <y> | <chan>: Channel number. <x>: Float, 0.0-1.0. <y>: Float, 0.0-1.0. |
/eos/chan/1/pantilt/xy=0.5, 0.5 - Sets Chan 1's pan and tilt to (0,0) on the Pan/Tilt
graph. |
For 2D Pan/Tilt graph where bottom-left corner is (0.0, 0.0) and top-right corner is (1.0, 1.0). |
| /eos/chan/<chan>/+% /eos/chan/1/param/<param>/+% /eos/chan/<chan>/+%=<button edge> /eos/chan/1/param/<param>/+%=<button edge> |
<chan>: Channel number. <param>: Parameter name as a string. <button edge>: Float, 1.0=down (default), 0.0=up. Optional param to specify button edge. |
/eos/chan/1/+% - Adjusts Chan 1's intensity by +%, as specified in
Setup. /eos/chan/1/param/pan/+% - Adjusts Chan 1's Pan parameter by +%, as specified in Setup. |
Adjusts the channel specified by <chan>'s <param> by +%, as specified in
Setup. If no <param> is given, Intensity will be affected. |
| /eos/chan/<chan>/-% /eos/chan/1/param/<param>/-% /eos/chan/<chan>/-%=<button edge> /eos/chan/1/param/<param>/-%=<button edge> |
/eos/chan/1/-% - Adjusts Chan 1's intensity by -%, as specified in
Setup. /eos/chan/1/param/pan/-% - Adjusts Chan 1's Pan parameter by -%, as specified in Setup. |
Adjusts the channel specified by <chan>'s <param> by -%, as specified in
| /eos/chan/<chan>/full /eos/chan/1/param/<param>/full /eos/chan/<chan>/full=<button edge> /eos/chan/1/param/<param>/full=<button edge> |
/eos/chan/1/full - Sets Chan 1's intensity to its Full
value. /eos/chan/1/param/pan/full - Sets Chan 1's Pan parameter to its Full value. |
Sets the channel specified by <chan>'s <param> to its Full
value. If no <param> is given, Intensity will be affected. |
| /eos/chan/<chan>/home /eos/chan/1/param/<param>/home /eos/chan/<chan>/home=<button edge> /eos/chan/1/param/<param>/home=<button edge> |
/eos/chan/1/home - Sets Chan 1's intensity to its Home
value. /eos/chan/1/param/pan/home - Sets Chan 1's Pan parameter to its Home value. |
Sets the channel specified by <chan>'s <param> to its Home
| /eos/chan/<chan>/level /eos/chan/1/param/<param>/level /eos/chan/<chan>/level=<button edge> /eos/chan/1/param/<param>/level=<button edge> |
/eos/chan/1/level - Sets Chan 1's intensity to Level, as specified in
Setup. /eos/chan/1/param/pan/level - Sets Chan 1's Pan parameter to Level, as specified in Setup. |
Sets the channel specified by <chan>'s <param> to Level, as specified in
| /eos/chan/<chan>/max /eos/chan/1/param/<param>/max /eos/chan/<chan>/max=<button edge> /eos/chan/1/param/<param>/max=<button edge> |
/eos/chan/1/max - Sets Chan 1's intensity to its maximum
value. /eos/chan/1/param/pan/max - Sets Chan 1's Pan parameter to its maximum value. |
Sets the channel specified by <chan>'s <param> to its maximum
| /eos/chan/<chan>/min /eos/chan/1/param/<param>/min /eos/chan/<chan>/min=<button edge> /eos/chan/1/param/<param>/min=<button edge> |
/eos/chan/1/min - Sets Chan 1's intensity to its minimum
value. /eos/chan/1/param/pan/min - Sets Chan 1's Pan parameter to its minimum value. |
Sets the channel specified by <chan>'s <param> to its minimum
| /eos/chan/<chan>/out /eos/chan/1/param/<param>/out /eos/chan/<chan>/out=<button edge> /eos/chan/1/param/<param>/out=<button edge> |
/eos/chan/1/out - Sets Chan 1's intensity to Out. /eos/chan/1/param/pan/out - Sets Chan 1's Pan parameter to its Out value. |
Sets the channel specified by <chan>'s <param> to Out. If no <param> is given, Intensity will be affected. |
| /eos/chan/<chan>/remdim /eos/chan/<chan>/remdim=<button edge> |
/eos/chan/1/remdim - Dims all channels to their RemDim state except Chan 1. |
Dims all channels except the specified <chan>. |
| /eos/chan/<chan>=<level> /eos/chan/<chan>/param/<param>=<level> /eos/chan/<chan>/dmx=<dmx level> /eos/chan/<chan>/param/<param>/dmx=<dmx level> |
<chan>: Channel number. <param>: Parameter name as a string. <level>: Float, 0.0-100.0. <dmx level>: Int, 0-255. |
/eos/chan/1=50 - Sets Chan 1's Intensity to 50. /eos/chan/1/param/pan=50 - Sets Chan 1's Pan to 50. /eos/chan/1/param/tilt/dmx=128 - Sets Chan 1's Tilt to output a DMX value of 128. |
Sets the specified <chan>'s <param> to the specified
level. Levels can be set directly or as a DMX output value. If no <param> is given, Intensity will be affected. Multiple parameters can be targeted by listing each one as <param1>/<param2>/... This works for all /eos/chan/ methods. |
| /eos/chan/<chan>/xyz = <x>, <y>, <z> | <chan>: Channel number. <x>: Float, Any number, in decimal meters. <y>: Float, Any number, in decimal meters. <z>: Float, Any number, in decimal meters. |
/eos/chan/1/xyz/=1, 1, 1 - Sets Chan 1's focus to XYZ coordinates (1, 1, 1). |
Sets XYZ position of selected channel according to Augment3d data. OSC XYZ coordinates are measured in decimal meters, regardless of the unit selected in Setup > System Settings > Augment3d. Channels can be focused this way regardless of whether they have XYZ Format enabled. |
| /eos/chan=<chan> | <chan>: Channel number. |
/eos/chan=1 - Selects Channel 1. |
Use to select channels. |
| /eos/cmd=<command> | <command>: String with command line text. |
/eos/cmd="Chan 1 At 75" - unterminated command. /eos/cmd="Chan 1 At 75#" - Eos interprets the "#" as a command termination. /eos/cmd="Chan 1 At 75 Enter" - Another terminated command. /eos/cmd="Chan %1 At FL", 101 - Eos will substitute 101 in place of %1, meaning the command is interpreted as "Chan 101 At FL". /eos/cmd="Chan %1 At %2", 75, 50 - Eos will substitute 75 in place of %1 and 50 in place of %2, meaning the command is interpreted as "Chan 75 At 50". /eos/cmd/Chan/1/At/75 - Another way to format commands. /eos/cmd/Chan/%1/At/%2#=1, 75 - Eos will substitute the arguments and interpret this as "Chan 1 At 75#". |
Command line instructions can be sent directly. String substitution with arguments is also allowed. To add a substitution, add %1 (or %2, %3, etc...) where the number given is the argument number where the actual value should be found. |
| /eos/color/hs=<hue>, <saturation> | <hue>: 0.0-360.0. <saturation>: 0.0-100.0. |
/eos/color/hs=330.0, 75.0 - pink color with 75% saturation. |
Changes the current selection on the command line to the specified color. |
| /eos/color/hsxy=<x>, <y> | <x>: 0.0-1.0. <y>: 0.0-1.0. |
/eos/color/hsxy=0.82, 0.31 - pink color with 75% saturation. |
Changes the current selection on the command line to the specified color. For simulating the Hue/Saturation wheel in a 2D XY graph where bottom-left corner is (0.0, 0.0) and top-right corner is (1.0, 1.0). |
| /eos/color/rgb=<red>, <green>, <blue> | <red>: 0.0-1.0. <green>: 0.0-1.0. <blue>: 0.0-1.0. |
/eos/color/rgb=1.0, 0.25, 0.63 - pink color with 75% saturation. |
| /eos/color/xy=<x>, <y> | <x>: 0.0-1.0. <y>: 0.0-1.0. |
/eos/color/xy=0.464, 0.254 - pink color with 75% saturation. |
Changes the current selection on the command line to the specified color. For setting (x, y) chromaticity point in the CIE 1931 xyY color space. |
| /eos/color/xyz=<x>, <y>, <z> | <x>: 0.0-1.0. <y>: 0.0-1.0. <z>: 0.0-1.0. |
/eos/color/xyz=0.851, 0.466, 0.516 - pink color with 75% saturation. |
Changes the current selection on the command line to the specified color. For setting (X, Y, Z) color point in XYZ color space. |
| /eos/cp/fire=<index> /eos/cp/<index>/fire=<button edge> |
<index>: Color palette number to fire. <button edge>: Float, 1.0=down (default), 0.0=up. Optional param to specify button edge. |
/eos/cp/fire=1 - Runs Color Palette 1. /eos/cp/1/fire - Runs Color Palette 1. |
Fires (executes) color palettes. |
| /eos/cp=<index> | <index>: Color palette to select. |
/eos/cp=1 - Selects Color Palette 1. |
Use to select color palettes. |
| /eos/cue/fire=<cue number> /eos/cue/<cue number>/fire /eos/cue/<list number>/<cue number>/fire /eos/cue/<list number>/<cue number>/<part number>/fire |
<list number>: Cue list to target. <cue number>: Cue number to fire. <part number>: Cue part to fire. <button edge>: Float, 1.0=down (default), 0.0=up. Optional param to specify button edge. |
/eos/cue/fire=1 - Runs Cue 1 in the current Cue List. /eos/cue/1.5/fire - Runs Cue 1.5 in the current Cue List. /eos/cue/1/1.5/fire - Runs Cue 1.5 in Cue List 1. /eos/cue/1/1.5/2/fire - Runs Cue 1.5 Part 2 in Cue List 1. |
Use to run Cues. |
| /eos/cue=<cue number> /eos/cue/<list number>=<cue number /eos/cue/<list number>/<cue number>=<part number> |
<list number>: Cue list to target. <cue number>: Cue number to fire. <part number>: Cue part to fire. |
/eos/cue=1.5 - Selects Cue 1.5. /eos/cue/1=1.5 - Selects Cue 1.5 in Cue List 1. /eos/cue/1/1.5=2 - Selects Cue 1.5 Part 2 in Cue List 1. |
Use to select Cues. If a <list number> is given, index is the cue to select within that
list. If a <list number> and a <cue number> are provided, index is the cue
part to select within that list and cue. |
| /eos/cuelist/<index>/config/<list number>/<num prev cues>/<num pending
cues> /eos/cuelist/<index>/config/<list number>/<num prev cues>/<num pending cues>/<offset> |
<index>: Int, the OSC fader bank to reset. <list number>: Int, the OSC cue list number to create. <num prev cues>: Int, how many rows to display before the current cue. <num pending cues>: Int, how many rows to display after the current cue. <offset>: Int, 0-based index into the entire cue list, where each cue counts as one item and each cue part counts as one item. |
/eos/cuelist/1/config/2/3/6 - create OSC cue list bank #1 for cue list 2, showing 3 previous
cues, the current cue, and 6 pending cues. /eos/cuelist/1/config/2/3/6/10 - create OSC cue list bank #1 for cue list 2, showing 3 previous cues, the current cue, and 6 pending cues, starting at offset 10 into the cue list. |
Eos will send the cue list label and cue information for all OSC cue list banks. |
| /eos/cuelist/<index>/page/<delta> | <index>: Int, the OSC fader bank to reset. <delta>: Int, how many rows to move. |
/eos/cuelist/1/page/1 - page OSC cue list bank down 1
row. /eos/cuelist/1/page/-1 - page OSC cue list bank up 1 row. /eos/cuelist/1/page/0 - jump back to the current cue and follow it. |
Pages OSC cue list specified by <index> up or down by <delta>
rows. Use /page/0 to jump back to the current cue and follow it. This only shifts the view, it does not play back cues. |
| /eos/cuelist/<index>/reset | <index>: Int, the OSC cue list to reset. |
/eos/cuelist/1/reset - resets all configuration on OSC cue list bank 1. |
Resets the specified OSC cue list bank as specified by <index>. |
| /eos/cuelist/<index>/select/<cue number> | <index>: Int, the OSC fader bank to reset. <cue number>: Cue number to jump to. |
/eos/cuelist/1/select/100.4 - jump OSC cue list bank 1 to cue 100.4. |
Use to jump to a specified cue on the OSC cue list bank. |
| /eos/cues/<index>/fire /eos/cues/fire /eos/cues/fire=<button edge> /eos/cues/<index>/fire=<button edge> |
<index>: Cue list index. <button edge>: Float, 1.0=down (default), 0.0=up. Optional param to specify button edge. |
/eos/cues/2/fire - Fires Cue List 2, like [Go]. |
Used to play back a cue list specified by <index>. If no <index> is given, it
will fire the Cue List on the main playback. |
| /eos/cues/<index>/stop /eos/cues/stop /eos/cues/stop=<button edge> /eos/cues/<index>/stop=<button edge> |
/eos/cues/2/stop - Stops an active fade in Cue List 2, or goes back a cue if not
fading. |
Used to stop or go back in the cue list specified by <index>. If no <index> is
given, it will use the Cue List on the main playback. |
| /eos/cues/<index> /eos/cues=<index> /eos/cues/<index>=<button edge> |
<index>: The cue list number to select. <button edge>: Float, 1.0=down (default), 0.0=up. Optional param to specify button edge. |
/eos/cues/2 - Selects Cue List 2. /eos/cues=2 - Selects Cue List 2. |
Used to select Cue Lists. |
| /eos/curve=<index> /eos/curve/<index>=<button edge> |
<index>: Curve number to select. <button edge>: Float, 1.0=down (default), 0.0=up. Optional param to specify button edge. |
/eos/curve=901 - Selects Curve 901. /eos/curve/901 - Selects Curve 901. |
Use to select curves. |
| /eos/ds/<index>/page/<delta> | <index>: Int, the OSC direct select bank to target. <delta>: Int, how many pages to move. |
/eos/ds/1/page/1 - page OSC direct select bank 1 down by
1. /eos/cuelist/1/page/-1 - page OSC direct select bank 1 up by 1. /eos/ds/1/page/10 - page OSC direct select bank 1 down by 10. |
Pages OSC direct select bank specified by <index> up or down by <delta>
buttons. |
| /eos/ds/<index>/<target type>/<button
count> /eos/ds/<index>/<target type>/flexi/<button count> /eos/ds/<index>/<target type>/<page number>/<button count> /eos/ds/<index>/<target type>/flexi/<page number>/<button count> |
<index>: Int, the OSC direct select bank to target. <target type>: Any of the following: Chan, Group, Macro, Sub, Preset, IP (Intensity Palette), FP (Focus Palette), CP (Color Palette), BP (Beam Palette), MS (Magic Sheet), Curve, Snap (Snapshot), FX (Effects), Pixmap, Scene. <button count>: Int, how many buttons to create this direct select page with. <page number>: Int, the direct select page number to target. |
/eos/ds/1/bp/10 - create OSC direct select bank #1 with 10 Beam Palette
buttons. /eos/ds/1/macro/flexi/10 - create OSC direct select bank #1 with 10 Macro buttons in Flexi mode. /eos/ds/1/chan/3/10 - create OSC direct select bank #1 with 10 Channels on page 3. Can also be used to quick jump to a specific page. /eos/ds/1/fx/flexi/3/10 - create OSC direct select bank #1 with 10 Effect buttons on page 3, in flexi mode. Can also be used to quick jump to a specific page. |
OSC direct selects are virtual buttons and are mapped separately than direct selects visible on the
console. To use direct selects, you must first send one of the direct select creation commands. Direct
selects are mapped as a single target type. Eos will send the description and button labels for all OSC direct selects. |
| /eos/event=<command> | <command>: String with command line text. |
/eos/event="Chan 1 At 75#" - Terminated command that is interpreted as a console event
(like macros that fire outside of the command line.). |
Same behavior as /eos/cmd, but treated as a console event. |
| /eos/fader/<index>/<fader index>/+% /eos/fader/<index>/<fader index>/+%=<button edge> |
<index>: Int, 1-based index of any existing OSC fader bank. Use 0 to reference the master
fader. <fader index>: Int, index of the fader you wish to target in fader bank <index>. <button edge>: Float, 1.0=down (default), 0.0=up. Optional param to specify button edge. |
/eos/fader/1/2/+% - Adjusts Fader 2 in OSC fader bank #1 by +%, as specified in
Setup. |
Adjusts the given <fader index> in OSC fader bank <index> by +%, as specified
in Setup. |
| /eos/fader/<index>/<fader index>/-% /eos/fader/<index>/<fader index>/-%=<button edge> |
/eos/fader/1/2/-% - Adjusts Fader 2 in OSC fader bank #1 by -%, as specified in
Setup. |
Adjusts the given <fader index> in OSC fader bank <index> by -%, as specified
in Setup. |
| /eos/fader/<index>/config/<fader count> /eos/fader/<index>/config/<page number>/<fader count> |
<index>: Int, 1-based index of any OSC fader bank you wish to create. Use 0 to reference the
master fader. <fader count>: Int, how many faders to include on a page. |
/eos/fader/1/config/10 - create OSC fader bank #1 with 10 faders. (OSC Fader 1/1 is the same as
console fader 1/1). /eos/fader/1/config/2/10 - create OSC fader bank #1 with 10 faders on page 2. Can also be used to quick jump to a specific page if already created. OSC Fader 2/1 (Fader 11) is the same as console fader 2/1. |
Fader banks share fader mapping with Eos, but since an OSC Fader Bank can have any number of faders per
page, the paging will be different. Like Direct Selects, you must first send one of the OSC Fader Bank
creation commands before the fader pages will work. Faders will be mapped to the same fader number as
Eos. |
| /eos/fader/<index>/<fader index>/fire /eos/fader/<index>/<fader index>/fire=<button edge> |
/eos/fader/1/2/fire - Fires Fader 2 in OSC fader bank #1. |
Fires the given <fader index> in OSC fader bank <index>. |
| /eos/fader/<index>/<fader index>/home /eos/fader/<index>/<fader index>/home=<button edge> |
/eos/fader/1/2/home - Sets Fader 2 in OSC fader bank #1 to its Home value. |
Sets the given <fader index> in OSC fader bank <index> to its Home
value. |
| /eos/fader/<index>/<fader index>/level /eos/fader/<index>/<fader index>/level=<button edge> |
/eos/fader/1/2/level - Sets Fader 2 in OSC fader bank #1 to Level, as specified in
Setup. |
Sets the given <fader index> in OSC fader bank <index> to Level, as specified
in Setup. |
| /eos/fader/<index>/<fader index>/load /eos/fader/<index>/<fader index>/load=<button edge> |
/eos/fader/1/2/load - Loads Fader 2 in OSC fader bank #1. |
Loads the given <fader index> in OSC fader bank <index>. Use when content is
on the command line that you wish to load to a specific fader. |
| /eos/fader/<index>/<fader index>/max /eos/fader/<index>/<fader index>/max=<button edge> /eos/fader/<index>/<fader index>/full /eos/fader/<index>/<fader index>/full=<button edge> |
/eos/fader/1/2/max - Sets Fader 2 in OSC fader bank #1 to its maximum value. |
Sets the given <fader index> in OSC fader bank <index> to its maximum
value. |
| /eos/fader/<index>/<fader index>/min /eos/fader/<index>/<fader index>/min=<button edge> |
/eos/fader/1/2/min - Sets Fader 2 in OSC fader bank #1 to its minimum value. |
Sets the given <fader index> in OSC fader bank <index> to its minimum
value. |
| /eos/fader/<index>/<fader index>/out /eos/fader/<index>/<fader index>/out=<button edge> |
/eos/fader/1/2/out - Sets Fader 2 in OSC fader bank #1 to Out. |
Sets the given <fader index> in OSC fader bank <index> to Out. |
| /eos/fader/<index>/page/<delta> /eos/fader/<index>/page/<delta>=<button edge> |
fader. <delta>: Int, how many pages to move. <button edge>: Float, 1.0=down (default), 0.0=up. Optional param to specify button edge. |
/eos/fader/1/page/1 - Page OSC fader bank 1 down 1 page. /eos/fader/1/page/-1 - Page OSC fader bank 1 up 1 page. /eos/fader/1/page/10 - Page OSC fader bank 1 down 10 page. |
Pages OSC fader bank specified by <index> up or down by <delta> pages. Each
page has the number of faders given in the config command. |
| /eos/fader/<index>/reset | <index>: Int, the OSC fader bank to reset. |
/eos/fader/1/reset - Resets OSC fader bank 1. |
Resets the specified fader bank. |
| /eos/fader/<index>/<fader index>/stop /eos/fader/<index>/<fader index>/stop=<button edge> |
/eos/fader/1/2/stop - Stops Fader 2 in OSC fader bank #1. |
Stops the given <fader index> in OSC fader bank <index>. |
| /eos/fader/<index>/<fader index>/unload /eos/fader/<index>/<fader index>/unload=<button edge> |
/eos/fader/1/2/unload - Unloads Fader 2 in OSC fader bank #1. |
Unloads the given <fader index> in OSC fader bank <index>. |
| /eos/fader/<index>/<fader index>=<level> | <index>: Int, 1-based index of any existing OSC fader bank. Use 0 to reference the master
fader. <fader index>: Int, index of the fader you wish to target in fader bank <index>. <level>: 0.0-1.0, The level to set <fader index> to. |
/eos/fader/1/2=0.75 - Set the second fader in OSC fader bank #1 to 75%. |
Sets the given <fader index> in OSC fader bank <index> to the provided
level. |
| /eos/filter/add=<filter> | <filter>: One or more string arguments, representing filter(s) that may contain "*"
wildcards. |
/eos/filter/add="/eos/out/param/*" - Eos will only send OSC messages to this device
that start with "/eos/out/param/". |
Adds a filter, used to limit OSC traffic to devices that only need specific OSC messages from Eos. Any
device can set up any number of filters. |
| /eos/filter/clear | /eos/filter/clear - Clears all filters configured for this device, so Eos will send all
messages. |
Clears all filters for the device that sent this command. |
| /eos/filter/remove=<filter> | <filter>: One or more string arguments, representing filter(s) that may contain "*"
wildcards. |
/eos/filter/remove="/eos/out/param/*" - Removes the existing filter. |
Removes an existing filter on the device that sent this command. |
| /eos/fp/fire=<index> /eos/fp/<index>/fire=<button edge> |
<index>: Focus palette number to fire. <button edge>: Float, 1.0=down (default), 0.0=up. Optional param to specify button edge. |
/eos/fp/fire=1 - Runs Focus Palette 1. /eos/fp/1/fire - Runs Focus Palette 1. |
Fires (executes) focus palettes. |
| /eos/fp=<index> | <index>: Focus palette to select. |
/eos/fp=1 - Selects Focus Palette 1. |
Use to select focus palettes. |
| /eos/fx=<index> /eos/fx/<index>=<button edge> |
<index>: Effect to select. <button edge>: Float, 1.0=down (default), 0.0=up. Optional param to specify button edge. |
/eos/fx=901 - Selects Effect 901. /eos/fx/901 - Selects Effect 901. |
Use to select effects. |
| /eos/get/3dserver | Use to get the IP addresses for the Augment3D server. Returns /eos/out/get/3dserver. |
| /eos/get/bp/count | Use to get the number of Beam Palettes in the show. Returns /eos/out/get/bp/count. |
| /eos/get/bp/index=<index> | <index>: Int, index of the Beam Palette list, 0-indexed. |
/eos/get/bp/index=0 - Returns details of the first palette in the Beam Palette List. |
Same as /eos/get/bp/<index>, but 0-indexed from the Beam Palette list. |
| /eos/get/bp/uid=<uid> | <uid>: String containing the UID of a Beam Palette. |
/eos/get/bp/uid="00000000-0000-0000-0000-000000000000" - Returns details of the palette
given by the UID. |
Same as /eos/get/bp/<index>, but accessed with a Beam Palette's UID instead of its
index. |
| /eos/get/bp/<index> | <index>: Int. |
/eos/get/bp/2 - Returns details about Beam Palette 2. |
Returns /eos/get/out/bp/<index>. See /eos/get/out/<palette type>/<index>. |
| /eos/get/chans | Use to get the currently selected channels for the OSC user. Returns /eos/out/get/chans. |
| /eos/get/cp/count | Use to get the number of Color Palettes in the show. Returns /eos/out/get/cp/count. |
| /eos/get/cp/index=<index> | <index>: Int, index of the Color Palette list, 0-indexed. |
/eos/get/cp/index=0 - Returns details of the first palette in the Color Palette List. |
Same as /eos/get/cp/<index>, but 0-indexed from the Color Palette list. |
| /eos/get/cp/uid=<uid> | <uid>: String containing the UID of a Color Palette. |
/eos/get/cp/uid="00000000-0000-0000-0000-000000000000" - Returns details of the palette
given by the UID. |
Same as /eos/get/cp/<index>, but accessed with a Color Palette's UID instead of its
index. |
| /eos/get/cp/<index> | <index>: Int. |
/eos/get/cp/2 - Returns details about Color Palette 2. |
Returns /eos/get/out/cp/<index>. See /eos/get/out/<palette type>/<index>. |
| /eos/get/csv | Use to get the CSV file. Returns /eos/out/get/csv. |
| /eos/get/cue/<cue list>/count /eos/get/cue/<cue list>/<cue index>/count |
<cue list>: Int. <cue index>: Int. |
Use to get the number of cues in the given <cue list> or the number of parts in a given
<cue index>. Returns /eos/out/get/cue/<cue list>/count or /eos/out/get/cue/<cue list>/<cue index>. |
| /eos/get/cue/<list number>/index=<index> | <index>: Int, index of the given <list number>, 0-indexed. |
/eos/get/cue/1/index=0 - Returns details of the first Cue in Cue List 1. |
Same as /eos/get/cue/<list number>/<part number>, but 0-indexed from the given cue
list. |
| /eos/get/cue/<cue list>/noparts/count | <cue list>: Int. |
Use to get the number of cues, not counting part cues in the given <cue
list>. Returns /eos/out/get/cue/<cue list>/noparts/count. |
| /eos/get/cue/uid=<uid> | <uid>: String containing the UID of a Cue. |
/eos/get/cue/uid="00000000-0000-0000-0000-000000000000" - Returns details of the cue
given by its UID. |
Same as /eos/get/cue/<list number>/<index>, but accessed with a Cue's UID instead
of its list and index. |
| /eos/get/cue/<list number>/<cue number>/<part number> /eos/get/cue/<list number>/<cue number> |
<list number>: Int. <cue number>: Int. <part number>: Int. |
/eos/get/cue/1/1/1 - Returns information about Cue 1 Part 1 in Cue List 1. |
Returns /eos/get/cue/<list number/<cue number>/<part number> or
/eos/get/cue/<list number/<cue number>. |
| /eos/get/cuelist/count | Use to get the number of Cue Lists in the show. Returns /eos/out/get/cuelist/count. |
| /eos/get/cuelist/index=<index> | <index>: Int, index of the cue list, 0-indexed. |
/eos/get/cuelist/index=0 - Returns details of the first cuelist in the cue list
display. |
Same as /eos/get/cuelist/<index>, but 0-indexed from the list of cue lists. |
| /eos/get/cuelist/uid=<uid> | <uid>: String containing the UID of a cue list. |
/eos/get/cuelist/uid="00000000-0000-0000-0000-000000000000" - Returns details of the
cue list given by the UID. |
Same as /eos/get/cuelist/<index>, but accessed with a cue list's UID instead of its
index. |
| /eos/get/cuelist/<index> | <index>: Int. |
/eos/get/cuelist/1 - Returns details about Cue List 1. |
Returns /eos/out/get/cuelist/<index>. |
| /eos/get/curve/count | Use to get the number of Curves in the show. Returns /eos/out/get/curve/count. |
| /eos/get/curve/index=<index> | <index>: Int, index of the Curve list, 0-indexed. |
/eos/get/curve/index=0 - Returns details of the first Curve in the Curve List. |
Same as /eos/get/curve/<index>, but 0-indexed from the Curve list. |
| /eos/get/curve/uid=<uid> | <uid>: String containing the UID of a Curve. |
/eos/get/curve/uid="00000000-0000-0000-0000-000000000000" - Returns details of the
Curve given by the UID. |
Same as /eos/get/curve/<index>, but accessed with a Curve's UID instead of its
index. |
| /eos/get/curve/<index> | <index>: Int. |
/eos/get/curve/2 - Returns details about Curve 2. |
Returns /eos/get/out/curve/<index>. |
| /eos/get/emitters/<chan number> | <chan number>: Int. |
/eos/get/emitters/1 - Returns emitter information for Channel 1. |
Use to get emitter details for the given channel. Returns /eos/out/get/emitters<chan number>. |
| /eos/get/fp/count | Use to get the number of Focus Palettes in the show. Returns /eos/out/get/fp/count. |
| /eos/get/fp/index=<index> | <index>: Int, index of the Focus Palette list, 0-indexed. |
/eos/get/fp/index=0 - Returns details of the first palette in the Focus Palette List. |
Same as /eos/get/fp/<index>, but 0-indexed from the Focus Palette list. |
| /eos/get/fp/uid=<uid> | <uid>: String containing the UID of a Focus Palette. |
/eos/get/fp/uid="00000000-0000-0000-0000-000000000000" - Returns details of the palette
given by the UID. |
Same as /eos/get/fp/<index>, but accessed with a Focus Palette's UID instead of its
index. |
| /eos/get/fp/<index> | <index>: Int. |
/eos/get/fp/2 - Returns details about Focus Palette 2. |
Returns /eos/get/out/fp/<index>. See /eos/get/out/<palette type>/<index>. |
| /eos/get/fpe/count | Use to get the count of FPE sets in the show. Returns /eos/out/get/fpe/count. |
| /eos/get/fpe/<set index>/count | <set index>: Int, index of the FPE set. |
Use to get the count of FPE points within the given set index. Returns /eos/out/get/fpe/<set index>/count. |
| /eos/out/get/fpe/<set index>/<point index> | <set index>: Int, index of the FPE set. <point index>: Int, index of the point within <set index>. |
/eos/get/fpe/1/1 - Returns details of the first FPE point in the FPE set 1. |
Use to get details about the given FPE point in the given FPE set. Returns /eos/out/get/fpe/<set index>/<point index>. |
| /eos/get/fpe/index=<index> | <index>: Int, index of the FPE Set list, 0-indexed. |
/eos/get/fpe/index=0 - Returns details of the first FPE set in the FPE set list. |
Use to get details about the given FPE set. Returns /eos/out/get/fpe/<set index>. |
| /eos/get/fx/count | Use to get the number of Effects in the show. Returns /eos/out/get/fx/count. |
| /eos/get/fx/index=<index> | <index>: Int, index of the Effect list, 0-indexed. |
/eos/get/fx/index=0 - Returns details of the first Effect in the Effect List. |
Same as /eos/get/fx/<index>, but 0-indexed from the Effect list. |
| /eos/get/fx/uid=<uid> | <uid>: String containing the UID of an Effect. |
/eos/get/fx/uid="00000000-0000-0000-0000-000000000000" - Returns details of the Effect
given by the UID. |
Same as /eos/get/fx/<index>, but accessed with an Effect's UID instead of its
index. |
| /eos/get/fx/<index> | <index>: Int. |
/eos/get/fx/2 - Returns details about Effect 2. |
Returns /eos/get/out/fx/<index>. |
| /eos/get/group/count | Use to get the number of groups in the show. Returns /eos/out/get/group/count. |
| /eos/get/group/displayed/count | Same as /eos/get/group/count. Returns /eos/out/get/group/count. |
| /eos/get/group/displayed/index=<index> | <index>: Int, index of the group list, 0-indexed. |
/eos/get/group/displayed/index=0 - Returns details of the first group in the Group
List. |
Same as /eos/get/group/displayed/<index>, but 0-indexed. |
| /eos/get/displayed/uid=<uid> | <uid>: String containing the UID of a Group. |
/eos/get/group/displayed/uid="00000000-0000-0000-0000-000000000000" - Returns details
of the group identified by the UID. |
Same as /eos/get/group/displayed/<index>, but accessed with a Group's UID instead of
its index. |
| /eos/get/group/displayed/<index> | <index>: Int, index of the group list, 0-indexed. |
/eos/get/group/displayed/2 - Returns information about Group 2, with the channels listed as it
would appear on the command line. |
Returns /eos/out/get/group/<index>. Same as /eos/get/group/<index> except the channel list is returned as a single string as it would appear on the command line. This is useful to build custom command strings. |
| /eos/get/group/index=<index> | <index>: Int, index of the group list, 0-indexed. |
/eos/get/group/index=0 - Returns details of the first group in the Group List. |
Similar to /eos/get/group/<index>, but 0-indexed. |
| /eos/get/group/uid=<uid> | <uid>: String containing the UID of a Group. |
/eos/get/group/uid="00000000-0000-0000-0000-000000000000" - Returns details of the
Similar to /eos/get/group/<index>, but accessed with a Group's UID instead of its
index. |
| /eos/get/group/<index> | <index>: Int, index of the group list, 0-indexed. |
/eos/get/group/2 - Returns information about Group 2. |
Returns /eos/out/get/group/<index>. |
| /eos/get/ip/count | Use to get the number of Intensity Palettes in the show. Returns /eos/out/get/ip/count. |
| /eos/get/ip/index=<index> | <index>: Int, index of the Intensity Palette list, 0-indexed. |
/eos/get/ip/index=0 - Returns details of the first palette in the Intensity Palette
List. |
Same as /eos/get/ip/<index>, but 0-indexed from the Intensity Palette list. |
| /eos/get/ip/uid=<uid> | <uid>: String containing the UID of an Intensity Palette. |
/eos/get/ip/uid="00000000-0000-0000-0000-000000000000" - Returns details of the palette
given by the UID. |
Same as /eos/get/ip/<index>, but accessed with an Intensity Palette's UID instead of
its index. |
| /eos/get/ip/<index> | <index>: Int. |
/eos/get/ip/2 - Returns details about Intensity Palette 2. |
Returns /eos/get/out/ip/<index>. See /eos/get/out/<palette type>/<index>. |
| /eos/get/macro/count | Use to get the number of macros in the show. Returns /eos/out/get/macro/count. |
| /eos/get/group/index=<index> | <index>: Int, index of the macro list, 0-indexed. |
/eos/get/macro/index=0 - Returns details of the first Macro in the Macro list. |
Same as /eos/get/macro/<index>, but 0-indexed from the Macro list. |
| /eos/get/macro/uid=<uid> | <uid>: String containing the UID of a Macro. |
/eos/get/macro/uid="00000000-0000-0000-0000-000000000000" - Returns details of the
macro identified by the UID. |
Same as /eos/get/macro/<index>, but accessed with a Macro's UID instead of its
index. |
| /eos/get/macro/<index> | <index>: Int, index of the macro list, 0-indexed. |
/eos/get/macro/2 - Returns information about Macro 2. |
Returns /eos/out/get/macro/<index>. |
| /eos/get/ms/count | Use to get the number of Magic Sheets in the show. Returns /eos/out/get/ms/count. |
| /eos/get/ms/index=<index> | <index>: Int, index of the Magic Sheet list, 0-indexed. |
/eos/get/ms/index=0 - Returns details of the first Magic Sheet in the Magic Sheet
List. |
Same as /eos/get/ms/<index>, but 0-indexed from the Magic Sheet list. |
| /eos/get/ms/uid=<uid> | <uid>: String containing the UID of a Magic Sheet. |
/eos/get/ms/uid="00000000-0000-0000-0000-000000000000" - Returns details of the Magic
Sheet given by the UID. |
Same as /eos/get/ms/<index>, but accessed with a Magic Sheet's UID instead of its
index. |
| /eos/get/ms/<index> | <index>: Int. |
/eos/get/ms/2 - Returns details about Magic Sheet 2. |
Returns /eos/get/out/ms/<index>. |
| /eos/get/params/<chan number> | <chan number>: Int. |
/eos/get/params/1 - Returns parameter information for Channel 1. |
Use to get parameter details for the given channel. Returns /eos/out/get/params<chan number>. |
| /eos/get/patch/count | Use to get the number of channels in the show. Returns /eos/out/get/patch/count. |
| /eos/get/patch/index=<index> | <index>: Int, index of the list of patched channels, 0-indexed. |
/eos/get/patch/index=0 - Returns details of the first patched channel. |
Same as /eos/get/patch/<index>, but 0-indexed from the patched channel list. |
| /eos/get/patch/uid=<uid> | <uid>: String containing the UID of a patched channel. |
/eos/get/patch/uid="00000000-0000-0000-0000-000000000000" - See
/eos/get/patch/<index>. |
Same as /eos/get/patch/<index>, but accessed with a patched channel's UID instead of
its index. |
| /eos/get/patch/<channel number> /eos/get/patch/<channel number>/<part number> |
<channel number>: Int. <part number>: Int. |
/eos/get/patch/1/1 - Returns information about Chan 1 Part 1. |
Returns /eos/out/get/patch/<channel number> or /eos/out/get/patch/<channel
number>/<part number>. |
| /eos/get/pixmap/count | Use to get the number of Pixel Maps in the show. Returns /eos/out/get/pixmap/count. |
| /eos/get/pixmap/index=<index> | <index>: Int, index of the Pixel Map list, 0-indexed. |
/eos/get/pixmap/index=0 - Returns details of the first Pixel Map in the Pixel Map
List. |
Same as /eos/get/pixmap/<index>, but 0-indexed from the Pixel Map list. |
| /eos/get/pixmap/uid=<uid> | <uid>: String containing the UID of a Pixel Map. |
/eos/get/pixmap/uid="00000000-0000-0000-0000-000000000000" - Returns details of the
Pixel Map given by the UID. |
Same as /eos/get/pixmap/<index>, but accessed with a Pixel Map's UID instead of its
index. |
| /eos/get/pixmap/<index> | <index>: Int. |
/eos/get/pixmap/2 - Returns details about Pixel Map 2. |
Returns /eos/get/out/pixmap/<index>. |
| /eos/get/preset/count | Use to get the number of Presets in the show. Returns /eos/out/get/preset/count. |
| /eos/get/preset/index=<index> | <index>: Int, index of the Preset list, 0-indexed. |
/eos/get/preset/index=0 - Returns details of the first Preset in the Preset List. |
Same as /eos/get/preset/<index>, but 0-indexed from the Preset list. |
| /eos/get/preset/uid=<uid> | <uid>: String containing the UID of a Preset. |
/eos/get/preset/uid="00000000-0000-0000-0000-000000000000" - Returns details of the
Preset given by the UID. |
Same as /eos/get/preset/<index>, but accessed with a Preset's UID instead of its
index. |
| /eos/get/preset/<index> | <index>: Int. |
/eos/get/preset/2 - Returns details about Preset 2. |
Returns /eos/get/out/preset/<index>. |
| /eos/get/processors | Returns /eos/out/get/processors. |
| /eos/get/session | Returns /eos/out/get/session. |
| /eos/get/setup | Use to get default cue timings. Returns /eos/out/get/settings. |
| /eos/get/show/path | Returns /eos/out/get/show/path. |
| /eos/get/snap/count | Use to get the number of Snapshots in the show. Returns /eos/out/get/fx/count. |
| /eos/get/fx/index=<index> | <index>: Int, index of the Snapshot list, 0-indexed. |
/eos/get/fx/index=0 - Returns details of the first Snapshot in the Snapshot List. |
Same as /eos/get/fx/<index>, but 0-indexed from the Snapshot list. |
| /eos/get/fx/uid=<uid> | <uid>: String containing the UID of a Snapshot. |
Snapshot given by the UID. |
Same as /eos/get/fx/<index>, but accessed with a Snapshot's UID instead of its
index. |
/eos/get/fx/2 - Returns details about Snapshot 2. |
| /eos/get/sub/count | Use to get the number of Submasters in the show. Returns /eos/out/get/sub/count. |
| /eos/get/sub/index=<index> | <index>: Int, index of the Submaster list, 0-indexed. |
/eos/get/sub/index=0 - Returns details of the first Submaster in the Submaster List. |
Same as /eos/get/sub/<index>, but 0-indexed from the Submaster list. |
| /eos/get/sub/uid=<uid> | <uid>: String containing the UID of a Submaster. |
/eos/get/sub/uid="00000000-0000-0000-0000-000000000000" - Returns details of the
Submaster given by the UID. |
Same as /eos/get/sub/<index>, but accessed with a Submaster's UID instead of its
index. |
| /eos/get/sub/<index> | <index>: Int. |
/eos/get/sub/2 - Returns details about Submaster 2. |
Returns /eos/get/out/sub/<index>. |
| /eos/get/userlist | Use to get details about all users in the show. Returns /eos/out/get/userlist. |
| /eos/get/version | Returns /eos/out/get/version. |
| /eos/group/<group>/+% /eos/group/1/param/<param>/+% /eos/group/<group>/+%=<button edge> /eos/group/1/param/<param>/+%=<button edge> |
<group>: Group number. <param>: Parameter name as a string. <button edge>: Float, 1.0=down (default), 0.0=up. Optional param to specify button edge. |
/eos/group/1/+% - Adjusts Group 1's intensity by +%, as specified in
Setup. /eos/group/1/param/pan/+% - Adjusts Group 1's Pan parameter by +%, as specified in Setup. |
Adjusts the group specified by <group>'s <param> by +%, as specified in
| /eos/group/<group>/-% /eos/group/1/param/<param>/-% /eos/group/<group>/-%=<button edge> /eos/group/1/param/<param>/-%=<button edge> |
/eos/group/1/-% - Adjusts Group 1's intensity by -%, as specified in
Setup. /eos/group/1/param/pan/-% - Adjusts Group 1's Pan parameter by -%, as specified in Setup. |
Adjusts the group specified by <group>'s <param> by -%, as specified in
| /eos/group/<group>/full /eos/group/1/param/<param>/full /eos/group/<group>/full=<button edge> /eos/group/1/param/<param>/full=<button edge> |
/eos/group/1/full - Sets Group 1's intensity to its Full
value. /eos/group/1/param/pan/full - Sets Group 1's Pan parameter to its Full value. |
Sets the group specified by <group>'s <param> to its Full
| /eos/group/<group>/home /eos/group/1/param/<param>/home /eos/group/<group>/home=<button edge> /eos/group/1/param/<param>/home=<button edge> |
/eos/group/1/home - Sets Group 1's intensity to its Home
value. /eos/group/1/param/pan/home - Sets Group 1's Pan parameter to its Home value. |
Sets the group specified by <group>'s <param> to its Home
| /eos/group/<group>/level /eos/group/1/param/<param>/level /eos/group/<group>/level=<button edge> /eos/group/1/param/<param>/level=<button edge> |
/eos/group/1/level - Sets Group 1's intensity to Level, as specified in
Setup. /eos/group/1/param/pan/level - Sets Group 1's Pan parameter to Level, as specified in Setup. |
Sets the group specified by <group>'s <param> to Level, as specified in
| /eos/group/<group>/max /eos/group/1/param/<param>/max /eos/group/<group>/max=<button edge> /eos/group/1/param/<param>/max=<button edge> |
/eos/group/1/max - Sets Group 1's intensity to its maximum
value. /eos/group/1/param/pan/max - Sets Group 1's Pan parameter to its maximum value. |
Sets the group specified by <group>'s <param> to its maximum
| /eos/group/<group>/min /eos/group/1/param/<param>/min /eos/group/<group>/min=<button edge> /eos/group/1/param/<param>/min=<button edge> |
/eos/group/1/min - Sets Group 1's intensity to its minimum
value. /eos/group/1/param/pan/min - Sets Group 1's Pan parameter to its minimum value. |
Sets the group specified by <group>'s <param> to its minimum
| /eos/group/<group>/out /eos/group/1/param/<param>/out /eos/group/<group>/out=<button edge> /eos/group/1/param/<param>/out=<button edge> |
/eos/group/1/out - Sets Group 1's intensity to
Out. /eos/group/1/param/pan/out - Sets Group 1's Pan parameter to its Out value. |
Sets the group specified by <group>'s <param> to Out. If no <param> is given, Intensity will be affected. |
| /eos/group/<group>/remdim /eos/group/<group>/remdim=<button edge> |
/eos/group/1/remdim - Dims all groups to their RemDim state except Group 1. |
Dims all groups except the specified <group>. |
| /eos/group/<group>=<level> /eos/group/<group>/param/<param>=<level> /eos/group/<group>/dmx=<dmx level> /eos/group/<group>/param/<param>/dmx=<dmx level> |
<group>: Group number. <param>: Parameter name as a string. level: Float, 0.0-100.0. <dmx level>: Int, 0-255. |
/eos/group/1=50 - Sets Group 1's Intensity to 50. /eos/group/1/param/pan=50 - Sets Group 1's Pan to 50. /eos/group/1/param/tilt/dmx=128 - Sets Group 1's Tilt to output a DMX value of 128. |
Sets the specified <group>'s <param> to the specified
level. Levels can be set directly or as a DMX output value. If no <param> is given, Intensity will be affected. Multiple parameters can be targeted by listing each one as <param1>/<param2>/... This works for all /eos/group/ methods. |
| /eos/group=<index> | <index>: Group number to select. |
/eos/group=1 - Selects Group 1. |
Use to select Groups. |
| /eos/ip/fire=<index> /eos/ip/<index>/fire=<button edge> |
<index>: Intensity palette number to fire. <button edge>: Float, 1.0=down (default), 0.0=up. Optional param to specify button edge. |
/eos/ip/fire=1 - Runs Intensity Palette 1. /eos/ip/1/fire - Runs Intensity Palette 1. |
Fires (executes) intensity palettes. |
| /eos/ip=<index> | <index>: Intensity palette to select. |
/eos/ip=1 - Selects Intensity Palette 1. |
Use to select intensity palettes. |
| /eos/key/<key> /eos/key/<key>=<button edge> |
<key>: Any valid OSC key. <button edge>: Float. 1.0=down, 0.0=up. Optional to specify a button edge. |
/eos/key/select_active - Press and release [Select Active]
button. /eos/key/shift=1 - Hold down [Shift} key. |
For a list of supported key names, see OSC Key list below. For the slash key, use a backslash (/eos/key/\). |
| /eos/macro/fire=<index> /eos/macro/<index>/fire=<button edge> |
<index>: Macro number to fire. <button edge>: Float, 1.0=down (default), 0.0=up. Optional param to specify button edge. |
/eos/macro/fire=1 - Runs Macro 1. /eos/macro/1/fire - Runs Macro 1. |
Fires (executes) macros. |
| /eos/macro=<index> | <index>: Macro to select. |
/eos/macro=1 - Selects Macro 1. |
Use to select macros. |
| /eos/ms/fire=<index> /eos/ms/<index>/fire=<button edge> |
<index>: Magic Sheet to fire. <button edge>: Float, 1.0=down (default), 0.0=up. Optional param to specify button edge. |
/eos/ms/fire=1 - Runs Magic Sheet 1. /eos/ms/1/fire - Runs Magic Sheet 1. |
Fires (executes) Magic Sheets. |
| /eos/ms=<index> | <index>: Magic Sheet to select. |
/eos/ms=1 - Selects Magic Sheet 1. |
Use to select Magic Sheets. |
| /eos/newcmd=<command> | <command>: String with command line text. |
/eos/newcmd="Chan 1 At 75#" - Terminated Command that will reset the command line
first. |
Same behavior as /eos/cmd, but it resets the command line first. |
| /eos/newevent=<command> | <command>: String with command line text. |
/eos/newevent="Chan 1 At 75#" - Terminated command that is interpreted as a console
event (like macros that fire outside of the command line) that resets the command line
first. |
Same behavior as /eos/event, but will clear the internal command line first. |
| /eos/pantilt/xy=<x>, <y> | <x>: 0.0-1.0. <y>: 0.0-1.0. |
/eos/pantilt/xy=0.5, 0.5 - Sets the current selection's pan and tilt to (0,0) on the Pan/Tilt
graph. |
| /eos/param/<param>/+% /eos/param/<param>/+%=<button edge> |
<param>: Any valid parameter name. Multiple params can be targeted at once. <button edge>: 1.0=Down (default), 0.0=up, optional param to specify button edge. |
/eos/param/tilt/+% - Adjusts the current selection's Tilt parameter by +%, as specified in
Setup. |
Adjusts the current selection's <param> by +%, as specified in
Setup. Multiple parameters can be targeted by listing each one as <param1>/<param2>/... This works for all /eos/param methods. |
| /eos/param/<param>/-% /eos/param/<param>/-%=<button edge> |
/eos/param/tilt/-% - Adjusts the current selection's Tilt parameter by -%, as specified in
Setup. |
Adjusts the current selection's <param> by -%, as specified in
| /eos/param/<param>/full /eos/param/<param>/full=<button edge> |
/eos/param/pan/tilt/full - Sets the current selection's Pan and Tilt parameters to their Full
values. |
Sets the current selection's <param> to Full. Multiple parameters can be targeted by listing each one as <param1>/<param2>/... This works for all /eos/param methods. |
| /eos/param/<param>/home /eos/param/<param>/home=<button edge> |
/eos/param/pan/home - Sets the current selection's Pan parameter to its Home
value. |
Sets the current selection's <param> to its Home value. Multiple parameters can be targeted by listing each one as <param1>/<param2>/... This works for all /eos/param methods. |
| /eos/param/<param>/level /eos/param/<param>/level=<button edge> |
/eos/param/tilt/level - Sets the current selection's Tilt parameter to Level, as specified in
Setup. |
Sets the current selection's <param> to Level, as specified in
| /eos/param/<param>/max /eos/param/<param>/max=<button edge> |
/eos/param/pan/max - Sets the current selection's Pan to its maximum value. |
Sets the current selection's <param> to their maximum values. Multiple parameters can be targeted by listing each one as <param1>/<param2>/... This works for all /eos/param methods. |
| /eos/param/<param>/min /eos/param/<param>/min=<button edge> |
/eos/param/pan/min - Sets the current selection's Pan to its minimum value. |
Sets the current selection's <param> to to its minimum values. Multiple parameters can be targeted by listing each one as <param1>/<param2>/... This works for all /eos/param methods. |
| /eos/param/<param>/out /eos/param/<param>/out=<button edge> |
/eos/param/pan/out - Sets the current selection's Pan parameter to Out. |
Sets the current selection to Out. Multiple parameters can be targeted by listing each one as <param1>/<param2>/... This works for all /eos/param methods. |
| /eos/param/<param>/remdim /eos/param/<param>/remdim=<button edge> |
/eos/param/pan/remdim - Dims all other unselected channels. |
Dims all channels that aren't currently selected. The specified parameter will not change the
behavior. |
| /eos/param/<param>=<level> /eos/param/<param>/dmx=<dmx level> |
/eos/param/pan=50 - Sets the Pan parameters of the current selection to 50. Useful for mapping to
an OSC fader. /eos/param/pan/tilt=50 - Sets the Pan and Tilt parameters of the current selection to 50. /eos/param/<param>/dmx=128 - Sets the DMX channels assigned as Pan for the current selection to output 128. |
Sets the current selection's <param> to the specified level. Multiple parameters can be targeted by listing each one as <param1>/<param2>/... This works for all /eos/param methods. |
| /eos/ping=(arguments) | (arguments): None Required, any number can be sent. |
/eos/ping - . /eos/ping="abcde" - . /eos/ping="abcde", 4 - . |
Use to test an OSC connection. Send a ping message and Eos will respond on its configured port with
/eos/out/ping/. |
| /eos/pixmap=<index> /eos/pixmap/<index>=<button edge> |
<index>: Pixel Map to select. <button edge>: Float, 1.0=down (default), 0.0=up. Optional param to specify button edge. |
/eos/pixmap=1 - Selects Pixel Map 1. /eos/curve/1 - Selects Pixel Map 1. |
Use to select pixel maps. |
| /eos/preset/fire=<index> /eos/preset/<index>/fire=<button edge> |
<index>: Preset number to fire. <button edge>: Float, 1.0=down (default), 0.0=up. Optional param to specify button edge. |
/eos/preset/fire=1 - Runs Preset 1. /eos/preset/1/fire - Runs Preset 1. |
Fires (executes) presets. |
| /eos/preset=<index> | <index>: Preset to select. |
/eos/preset=1 - Selects Preset 1. |
Use to select presets. |
| /eos/(target)/override=<value> /eos/(target)/override/dmx=<dmx value> /eos/(target)/release |
(target): A reference to a valid target. See examples. <value>: Int, the level to set the target to. The valid range changes depending on the targeted parameter. <dmx value>: Int, 0-255. |
/eos/at/override=50 - Overrides the currently selected params to
50. /eos/chan/1/param/intens/override=50 - Overrides Chan 1's intensity parameter to 50. /eos/group/1/param/intens/override=50 - Overrides Group 1's intensity parameter to 50. /eos/group/1/override=50 - Overrides Group 1's intensity parameter to 50. /eos/chan/1/param/intens/dmx/override=252 - Overrides Chan 1's intensity parameter to a DMX output of 252. /eos/release - Releases all overrides. /eos/at/release - Releases overrides on the currently selected params. /eos/group/1/release - Releases overrides on Group 1. /eos/chan/1/param/intens/release - Releases overrides from Chan 1's intensity parameter. |
OSC can set and release override data, which appears in pink, has priority over other data types, and is
not recorded. Overridden levels will display in pink. Any selection or parameter can be overriden. |
| /eos/reset | /eos/reset - Triggers a reset of all OSC configuration. |
Clears any active switches. Resets all persistent OSC settings (like OSC user ID & wheel modes).
Send ALL implicit OSC output commands. |
| /eos/sc/<string>=<button edge> | <string>: Input String for some Event. <button edge>: Int, optional. 1.0=down (default), 0.0=up. |
/eos/sc/Event1 - Triggers an event whose Input String is "Event1" on a show control
list whose type is Network Inputs). |
Use to trigger events from a show control list. The List must be configured to Network Inputs and the
<string> must match the input string exactly (case-sensitive). Sending the string will fire
the event. |
| /eos/set/bp/<index>/label=<text> | <index>: Int. <text>: The string to set as the Label for the given Beam Palette. |
/eos/set/bp/1/label="New Label" - Sets Beam Palette 1's Label to "New
Label". |
Use to set the Label of a given Beam Palette. |
| /eos/set/cp/<index>/label=<text> | <index>: Int. <text>: The string to set as the Label for the given Color Palette. |
/eos/set/cp/1/label="New Label" - Sets Color Palette 1's Label to "New
Label". |
Use to set the Label of a given Color Palette. |
| /eos/set/cue/<list>/<number>/label=<text> /eos/set/cue/<list>/<number>/<part>/label=<text> |
<list>: Int. <number>: Int. <part>: Int. <text>: The string to set as the Label for the given Cue. |
/eos/set/cue/1/1/label="New Label" - Sets Cue 1 in Cue List 1's Label to "New
Label". /eos/set/patch/1/1/2/label="New Label" - Sets Cue 1 Part 2 in Cue List 1's Label to "New Label". |
Use to set the Label of a given Cue. |
| /eos/set/cue/<list>/<number>/notes=<text> /eos/set/cue/<list>/<number>/<part>/notes=<text> |
<list>: Int. <number>: Int. <part>: Int. <text>: The string to set as the Note for the given Cue. |
/eos/set/cue/1/1/notes="New Note" - Sets Cue 1 in Cue List 1's Note to "New
Note". /eos/set/cue/1/1/2/notes="New Note" - Sets Cue 1 Part 2 in Cue List 1's Note to "New Note". |
Use to set the Note of a given Cue. |
| /eos/set/cue/<list>/<number>/scene=<text> /eos/set/cue/<list>/<number>/<part>/scene=<text> |
<list>: Int. <number>: Int. <part>: Int. <text>: The string to set as the Scene for the given Cue. |
/eos/set/cue/1/1/scene="New Scene" - Sets Cue 1 in Cue List 1's Scene to "New
Scene". /eos/set/patch/1/1/2/scene="New Scene" - Sets Cue 1 Part 2 in Cue List 1's Scene to "New Scene". |
Use to set the Scene of a given Cue. |
| /eos/set/cuelist/<index>/label=<text> | <index>: Int. <text>: The string to set as the Label for the given Cue List. |
/eos/set/cuelist/1/label="New Label" - Sets Cue List 1's Label to "New
Label". |
Use to set the Label of a given Cue List. |
| /eos/set/curve/<index>/label=<text> | <index>: Int. <text>: The string to set as the Label for the given Curve. |
/eos/set/curve/901/label="New Label" - Sets Curve 901's Label to "New
Label". |
Use to set the Label of a given Curve. |
| /eos/set/fp/<index>/label=<text> | <index>: Int. <text>: The string to set as the Label for the given Focus Palette. |
/eos/set/fp/1/label="New Label" - Sets Focus Palette 1's Label to "New
Label". |
Use to set the Label of a given Focus Palette. |
| /eos/set/fx/<index>/label=<text> | <index>: Int. <text>: The string to set as the Label for the given Effect. |
/eos/set/fx/901/label="New Label" - Sets Effect 901's Label to "New
Label". |
Use to set the Label of a given Effect. |
| /eos/set/group/<index>/chans | text: The string to set the Group's channels with. |
/eos/set/group/1/chans="1 > 9 21 31" - Sets Group 1's Channels to 1 Thru 9, 21,
and 31. |
Use to set the Channels a given Group should point to. Strings should be written how they appear in the
Group List Display, with Thru ranges represented as "x > y". |
| /eos/set/group/<index>/label=<text> | <index>: Int. text: The string to set as the Label for the given Group. |
/eos/set/group/1/label="New Label" - Sets Group 1's Label to "New
Label". |
Use to set the Label of a given Group. |
| /eos/set/ip/<index>/label=<text> | <index>: Int. <text>: The string to set as the Label for the given Intensity Palette. |
/eos/set/ip/1/label="New Label" - Sets Intensity Palette 1's Label to "New
Label". |
Use to set the Label of a given Intensity Palette. |
| /eos/set/macro/<index>/label=<text> | <index>: Int. text: The string to set as the Label for the given Macro. |
/eos/set/macro/1/label="New Label" - Sets Macro 1's Label to "New
Label". |
Use to set the Label of a given Macro. |
| /eos/set/ms/<index>/label=<text> | <index>: Int. <text>: The string to set as the Label for the given Magic Sheet. |
/eos/set/ms/1/label="New Label" - Sets Magic Sheet 1's Label to "New
Label". |
Use to set the Label of a given Magic Sheet. |
| /eos/set/patch/<channel>/augment3d/position=<pos_x>, <pos_y>, <pos_z>, <orientation_x>, <orientation_y>, <orientation_z> | <channel>: Int. <pos_x>: Int. <pos_y>: Int. <pos_z>: Int. <orientation_x>: Int. <orientation_y>: Int. <orientation_z>: Int. |
/eos/set/patch/1/augment3d/position=0, 0, 0, 90, 90, 90 - Sets Chan 1 to be at the center of
Augment3D's model, with 90deg rotation in all axes. |
Use to set the Augment3D position and orientation data for the given channel in Patch. |
| /eos/set/patch/<channel>/gel=<gel string> | <channel>: Int. <gel string>: Any string can be entered, but Eos will recognize certain manufacturer and gel number combinations in the format "manufacturer abbreviation/gel number". |
/eos/set/patch/1/gel="AP1150" - Sets Chan 1's gel to Apollo
1150. /eos/set/patch/1/gel="L2" - Sets Chan 1's gel to Lee 2. /eos/set/patch/1/gel="R375" - Sets Chan 1's gel to Rosco 375. |
Use to set the Gel Field for a given channel in Patch. Any string can be entered, but certain
combinations will be recognized as a gel for use in Augment3D and elsewhere on the console. |
| /eos/set/patch/<channel>/label=<text> | <channel>: Int. text: String to set as the Label for the given chan. |
/eos/set/patch/1/label="New Label" - Sets the Label field to "New Label" for
Chan 1. |
Use to set the Label Field for a given channel in Patch. |
| /eos/set/patch/<channel>/text1=<text> | <channel>: Int. text: String to set as Text1 for the given chan. |
/eos/set/patch/1/text1="Text 1 Entry" - Sets the Text1 field to "Text 1
Entry" for Chan 1. |
Use to set the Text1 Field for a given channel in Patch. |
| /eos/set/patch/<channel>/text10=<text> | <channel>: Int. text: String to set as Text10 for the given chan. |
/eos/set/patch/1/text10="Text 10 Entry" - Sets the Text10 field to "Text 10
Use to set the Text10 Field for a given channel in Patch. |
| /eos/set/patch/<channel>/text2=<text> | <channel>: Int. text: String to set as Text2 for the given chan. |
/eos/set/patch/1/text2="Text 2 Entry" - Sets the Text2 field to "Text 2
Use to set the Text2 Field for a given channel in Patch. |
| /eos/set/patch/<channel>/text3=<text> | <channel>: Int. text: String to set as Text3 for the given chan. |
/eos/set/patch/1/text3="Text 3 Entry" - Sets the Text3 field to "Text 3
Use to set the Text3 Field for a given channel in Patch. |
| /eos/set/patch/<channel>/text4=<text> | <channel>: Int. text: String to set as Text4 for the given chan. |
/eos/set/patch/1/text4="Text 4 Entry" - Sets the Text1 field to "Text 4
Use to set the Text4 Field for a given channel in Patch. |
| /eos/set/patch/<channel>/text5=<text> | <channel>: Int. text: String to set as Text5 for the given chan. |
/eos/set/patch/1/text5="Text 5 Entry" - Sets the Text1 field to "Text 5
Use to set the Text5 Field for a given channel in Patch. |
| /eos/set/patch/<channel>/text6=<text> | <channel>: Int. text: String to set as Text6 for the given chan. |
/eos/set/patch/1/text1="Text 6 Entry" - Sets the Text6 field to "Text 6
Use to set the Text6 Field for a given channel in Patch. |
| /eos/set/patch/<channel>/text7=<text> | <channel>: Int. text: String to set as Text7 for the given chan. |
/eos/set/patch/1/text7="Text 7 Entry" - Sets the Text7 field to "Text 7
Use to set the Text7 Field for a given channel in Patch. |
| /eos/set/patch/<channel>/text8=<text> | <channel>: Int. text: String to set as Text8 for the given chan. |
/eos/set/patch/1/text1="Text 8 Entry" - Sets the Text8 field to "Text 8
| /eos/set/patch/<channel>/text9=<text> | <channel>: Int. text: String to set as Text9 for the given chan. |
/eos/set/patch/1/text9="Text 9 Entry" - Sets the Text9 field to "Text 9
Use to set the Text9 Field for a given channel in Patch. |
| /eos/set/pixmap/<index>/label=<text> | <index>: Int. <text>: The string to set as the Label for the given Pixel Map. |
/eos/set/pixmap/1/label="New Label" - Sets Pixel Map 1's Label to "New
Label". |
Use to set the Label of a given Pixel Map. |
| /eos/set/preset/<index>/label=<text> | <index>: Int. <text>: The string to set as the Label for the given Preset. |
/eos/set/preset/1/label="New Label" - Sets Preset 1's Label to "New
Label". |
Use to set the Label of a given Preset. |
| /eos/set/fx/<index>/label=<text> | <index>: Int. <text>: The string to set as the Label for the given Snapshot. |
/eos/set/fx/1/label="New Label" - Sets Snapshot 1's Label to "New
Label". |
Use to set the Label of a given Snapshot. |
| /eos/set/sub/<index>/label=<text> | <index>: Int. <text>: The string to set as the Label for the given Submaster. |
/eos/set/sub/1/label="New Label" - Sets Sub 1's Label to "New
Label". |
Use to set the Label of a given Submaster. |
| /eos/snap/fire=<index> /eos/snap/<index>/fire=<button edge> |
<index>: Snapshot to fire. <button edge>: Float, 1.0=down (default), 0.0=up. Optional param to specify button edge. |
/eos/snap/fire=1 - Runs Snapshot 1. /eos/snap/1/fire - Runs Snapshot 1. |
Fires (executes) Snapshots. |
| /eos/snap=<index> | <index>: Snapshot to select. |
/eos/snap=1 - Selects Snapshot 1. |
Use to select snapshots. |
| /eos/softkey/<index>=<button edge> | <index>: Int, index of softkey to select. There are 6 softkeys and 2 pages, so valid
<index> numbers are 1-12. <button edge>: Float, 1.0=down (default), 0.0=up. Optional param to specify button edge. |
/eos/softkey/1=1.0 - press 1st softkey. /eos/softkey/1=0.0 - release 1st softkey. |
Used to press softkeys. The commands on those softkeys are determined by the state of Eos for the OSC
user. |
| /eos/sub/fire=<index> /eos/sub/<index>/fire=<button edge> |
<index>: Int. Sub to fire. <button edge>: Float, 1.0=down, 0.0=up. Optional param to specify button edge. |
/eos/sub/fire=1 - Fires Sub 1. /eos/sub/1/fire=1 - Fires Sub 1, and holds it in Bump Down. |
Fires (bumps) the given Sub. A button edge can be specified to do either a Bump Down or Bump Up action.
If a Sub is bumped down, it will stay down until a bump up is received. |
| /eos/sub/<index>/full /eos/sub/<index>/full=<button edge> |
<index>: Int. Submaster to target. <button edge>: Float. 1.0=down (default), 0.0=up. Optional to specify a button edge. |
/eos/sub/1/full - Sets the Submaster to its Full level. |
| /eos/sub/<index>/home /eos/sub/<index>/home=<button edge> |
/eos/sub/1/home - Sets the Submaster to its Home level. |
| /eos/sub/<index>/level /eos/sub/<index>/level=<button edge> |
/eos/sub/1/level - Sets the Submaster to the Level value. |
Sets the Submaster to the Level value, as specified in Setup. |
| /eos/sub/<index>/max /eos/sub/<index>/max=<button edge> |
/eos/sub/1/max - Sets the Submaster to its Maximum level. |
| /eos/sub/<index>/min /eos/sub/<index>/min=<button edge> |
/eos/sub/1/min - Sets the Submaster to its Minimum level. |
| /eos/sub/<index>/out /eos/sub/<index>/out=<button edge> |
/eos/sub/1/out - Sets the Submaster to Out. |
| /eos/sub=<index> /eos/sub/<index>=<level> |
<index>: Int. Submaster to select. <level>: A float to set the submaster to as a percent between 0 and 1. Can also be a keyword such as full, out, home, min, max, level. |
/eos/sub=1 - Selects Sub 1. /eos/sub/1=0.75 - Sets Sub 1 to 75%. Useful for mapping to an OSC slider. /eos/sub/1=full - Sets Sub 1 to Full. |
Used to select Submasters and modify their levels. |
| /eos/subscribe/param/<param1>=<value> /eos/subscribe/param/<param1>/<param2>=<value> |
<value>: Int, 1=subscribe, 0=unsubscribe. |
/eos/subscribe/param/red=1 - Subscribes to the Red
parameter. /eos/subscribe/param/pan/tilt=1 - Subscribes to both Pan and Tilt parameters. |
Any number of parameters can be specified by continuing to list them as
<param1>/<param2>/<param3>.... Once subscribed, Eos will reply with an OSC packed per parameter as they change. |
| /eos/switch/coarse/<param>=<level> /eos/switch/coarse/<param1>/<param2>=<level> |
<level>: Int, number of wheel ticks to change specified parameters by continuously. |
/eos/switch/coarse/pan=1.0 - Increase the selection's pan by 1 coarse wheel tick
continuously. /eos/switch/coarse/pan/tilt=1.0 - Increase the selection's pan and tilt by 1 coarse wheel tick continuously. /eos/switch/coarse/pan/tilt=0 - Stop the continuous wheel ticking for pan and tilt parameters. |
Continuously adjusts the given parameters by the given amount of fine wheel ticks until a level=0
command is sent to stop it. Any number of parameters is allowed. |
| /eos/switch/fine/<param>=<level> /eos/switch/fine/<param1>/<param2> |
/eos/switch/fine/pan=1.0 - Increase the selection's pan by 1 fine wheel tick
continuously. /eos/switch/fine/pan/tilt=1.0 - Increase the selection's pan and tilt by 1 fine wheel tick continuously. /eos/switch/fine/pan/tilt=0 - Stop the continuous wheel ticking for pan and tilt parameters. |
| /eos/switch/level | <level>: Int, number of wheel ticks to change specified parameters by continuously. |
/eos/switch/level=1.0 - increase value. /eos/switch/level=-1.0 - decrease value. /eos/switch/level=4.0 - increase value rapidly. |
Used to change the level of the selected parameter. Defaults to Coarse mode, but can be changed with
/eos/wheel command. |
| /eos/switch=<wheel
mode> /eos/switch/<param>=<level> /eos/switch/<param1>/<param2>=<level> |
<wheel mode>: Int for wheel mode. 0=coarse, 1=fine. <level>: Int, number of wheel ticks to change specified parameters by continuously. The expected range is -1.0 to 1.0, which affects the tick rate accordingly, but can be a smaller or larger range for more subtle or rapid movement. |
/eos/switch=1.0 - Sets the wheel mode to fine. /eos/switch/pan=1.0 - Increase the selection's pan by 1 wheel tick continuously. /eos/switch/pan/tilt=1.0 - Increase the selection's pan and tilt by 1 wheel tick continuously. /eos/switch/pan/tilt=0 - Stop the continuous wheel ticking for pan and tilt parameters. |
Changes the switch mode. Affects sensitivity of other switch commands. Switch is a variant of Wheel with the added functionality of continuously repeating wheel ticks until a subsequent OSC switch command sets the wheel ticks to zero. This may be used to continuously tick a wheel while a button is held down, for example. Any number of parameters is allowed. |
| /eos/user/auto | /eos/user/auto - Sets OSC user to an automatically different number than everyone
else. |
This command sets the OSC user to find a user ID not used by any other device. Useful for apps that want
to have their own command line and avoid possible conflicts on the background user. |
| /eos/user=<user number> | <user number>: Int, User number this OSC device should use. User 0 represents the background user
(used in Background Macros and elsewhere). User -1 represents the current user on the console that is
receiving OSC commands. |
/eos/user=2 - Sets OSC user to User 2 on the console. /eos/user=0 - Sets OSC user to the background user. No commands will appear on any command line. /eos/user=-1 - Sets OSC user to the current user on the console. |
Use to change the console user that receives OSC commands. |
| /eos/wheel/coarse/<param>=<level> /eos/wheel/coarse/<param1>/<param2>=<level> |
<level>: Int, number of wheel ticks to increment by. |
/eos/wheel/coarse/pan=1.0 - Increase the selection's pan by 1 coarse wheel
tick. /eos/wheel/coarse/pan/tilt=1.0 - Increase the selection's pan and tilt by 1 coarse wheel tick each. |
Adjusts the given parameters by the given amount of coarse wheel ticks. Multiple parameters can be targeted by listing each one as <param1>/<param2>/.... |
| /eos/wheel/fine/<param>=<level> /eos/wheel/fine/<param1>/<param2>=<level> |
/eos/wheel/fine/pan=1.0 - Increase the selection's pan by 1 fine wheel
tick. /eos/wheel/fine/pan/tilt=1.0 - Increase the selection's pan and tilt by 1 fine wheel tick each. |
Adjusts the given parameters by the given amount of fine wheel ticks. Multiple parameters can be targeted by listing each one as <param1>/<param2>/.... |
| /eos/wheel/level=<level> | <level>: Int, number of wheel ticks to increment by. |
/eos/wheel/level=1.0 - increase value. /eos/wheel/level=-1.0 - decrease value. /eos/wheel/level=4.0 - increase value rapidly. |
| /eos/wheel=<wheel
mode> /eos/wheel/<param>=<level> /eos/wheel/<param1>/<param2>=<level> |
<wheel mode>: Int for wheel mode. 0=coarse, 1=fine. <level>: Int, number of wheel ticks to increment by. |
/eos/wheel=1.0 - Sets the wheel mode to fine. /eos/wheel/pan=1.0 - Increase the selection's pan by 1 wheel tick. /eos/wheel/pan/tilt=1.0 - Increase the selection's pan and tilt by 1 wheel tick each. |
Changes the wheel mode. Affects sensitivity of other wheel commands. Multiple parameters can be targeted by listing each one as <param1>/<param2>/.... |
| /eos/xyz=<x>, <y>, <z> | <x>: Any number, in decimal meters. <y>: Any number, in decimal meters. <z>: Any number, in decimal meters. |
/eos/xyz/=1, 1, 1 - Sets the current selection's focus to XYZ coordinates (1, 1,
1). |
Sets XYZ position of current selection according to Augment3d data. OSC XYZ coordinates are measured in decimal meters, regardless of the unit selected in Setup > System Settings > Augment3d. Channels can be focused this way regardless of whether XYZ Format is enabled for them. |
OSC Outputs
| Address Pattern | Arguments | Examples | Notes |
| /eos/out/user = <user index> | <user index>: Int. |
/eos/out/user = 2 - OSC User is User 2. |
Sends when the OSC user changes. |
| /eos/out/wheel = <wheel value> | <wheel value>: Float. |
/eos/out/wheel = 0.000 - Wheel is not moving. |
Sends when an OSC wheel changes. |
| /eos/out/switch = <switch value> | <switch value>: Float. |
/eos/out/switch = 0.000 - Wheel is not moving. |
Sends when an OSC switch changes. |
| /eos/out/get/version = <Eos version>, <FixLib version>, <gel swatch type> | <Eos version>: String in the format "major.minor.patch.build". <FixLib version>: String in the format "major.minor.patch.build". <gel swatch type>: Int. |
/eos/out/get/version="3.3.0.273", "3.3.0.102", 0 - Eos Version is 3.3.0.273,
Fixture Library version is 3.3.0.102, and the gel swatch type is 0. |
Returns information about the current Eos version. Useful to distinguish versions if OSC commands ever
change. |
| /eos/out/get/processors = <processor count> /eos/out/get/processors = <id>, <backup id>, <host flag>, <health status>, <label>, <name>, <desc>, <IP>, <universe string> |
<processor count>: Int, number of processors. <id>: Int, internal id of the processor. <backup id>: Int, the id of this processor's backup. -1 = no backup for this processor. <host flag>: Bool, True if this is the host processor. <health status>: Int. 0 through 3. 0 = Online, 1 = Offline, 2 = Warnings, 3 = Critical Error. <label>: String. <name>: String. <desc>: String. <IP>: String. <universe string>: String containing the universes this processor controls in the format "1>3". |
/eos/out/get/processors= 1 - There is 1 expansion
processor. /eos/out/get/processors= 10, -1, True, 0, "Host Label", "Laptop Name", "ETCnomad", "0.0.0.0", "1>3" "Expansion Proccessor", "0.0.0.0", "4>6" - The first processor has an id of 0, no backup, is the host, is online, its label, name, description, IP address, and assigned universes 1 thru 3. |
Returns information about processors in the showfile. The first returned OSC message will have the number of processors in the showfile (and the number of upcoming OSC messages.) Each processor will send its data as a separate OSC command. |
| /eos/out/get/group/count = <count> | <count>: Int. |
/eos/out/get/group/count = 10 - 10 Groups in show. |
Returns the number of Groups in the show. |
| /eos/out/get/macro/count = <count> | <count>: Int. |
/eos/out/get/macro/count = 10 - 10 Macros in show. |
Returns the number of Macros in the show. |
| /eos/out/get/bp/count = <count> | <count>: Int. |
/eos/out/get/bp/count = 10 - 10 Beam Palettes in show. |
Returns the number of Beam Palettes in the show. |
| /eos/out/get/cp/count = <count> | <count>: Int. |
/eos/out/get/cp/count = 10 - 10 Color Palettes in show. |
Returns the number of Color Palettes in the show. |
| /eos/out/get/fp/count = <count> | <count>: Int. |
/eos/out/get/fp/count = 10 - 10 Focus Palettes in show. |
Returns the number of Focus Palettes in the show. |
| /eos/out/get/ip/count = <count> | <count>: Int. |
/eos/out/get/ip/count = 10 - 10 Intensity Palettes in show. |
Returns the number of Intensity Palettes in the show. |
| /eos/out/get/preset/count = <count> | <count>: Int. |
/eos/out/get/preset/count = 10 - 10 Presets in show. |
Returns the number of Presets in the show. |
| /eos/out/get/curve/count = <count> | <count>: Int. |
/eos/out/get/curve/count = 12 - 12 Curves in show. |
Returns the number of Curves in the show. |
| /eos/out/get/ms/count = <count> | <count>: Int. |
/eos/out/get/ms/count = 2 - 2 Magic Sheets in show. |
Returns the number of Magic Sheets in the show. |
| /eos/out/get/sub/count = <count> | <count>: Int. |
/eos/out/get/sub/count = 10 - 10 Submasters in show. |
Returns the number of Submasters in the show. |
| /eos/out/get/fx/count = <count> | <count>: Int. |
/eos/out/get/fx/count = 12 - 12 Effects in show. |
Returns the number of Effects in the show. |
| /eos/out/get/snap/count = <count> | <count>: Int. |
/eos/out/get/snap/count = 3 - 3 Snapshots in show. |
Returns the number of Snapshots in the show. |
| /eos/out/get/pixmap/count = <count> | <count>: Int. |
/eos/out/get/pixmap/count = 1 - 1 Pixel Map in show. |
Returns the number of Pixel Maps in the show. |
| /eos/out/get/cuelist/count = <count> | <count>: Int. |
/eos/out/get/cuelist/count = 1 - 1 Cue List in show. |
Returns the number of Cue Lists in the show. |
| /eos/out/get/cue/<cue list>/count = <count> | <cue list>: Int, a number of a cue list. <count>: Int. |
/eos/out/get/cuelist/1/count = 10 - 10 Cues in Cue List 1. |
Returns the number of Cues in the given cue list, including part cues. |
| /eos/out/get/cue/<cue list>/noparts/count = <count> | <cue list>: Int, a number of a cue list. <count>: Int. |
Returns the number of Cues in the given cue list, excluding part cues. |
| /eos/out/get/cue/<cue list>/<cue index>/count = <count> | <cue list>: Int, a number of a cue list. <cue index>: Int, a cue number. <count>: Int. |
/eos/out/get/cue/1/1/count = 10 - 10 Parts in Cue 1 in Cue List 1. |
Returns the number of Parts of the given cue in the given Cue List. |
| /eos/out/get/patch/count = <count> | <count>: Int. |
/eos/out/get/patch/count = 10 - 10 Patched fixtures in this show. |
Returns the number of patched fixtures in the show. |
| /eos/out/get/patch/<channel number>/<part number>/list/<arg index>/<arg count> =
<list index>, <UID>, <label>, <manufacturer>, <fixture type>,
<address>, <intensity address>, <current level>, <gel>, <text 1>, <text
2>, <text 3>, <text 4>, <text 5>, <text 6>, <text 7>, <text 8>,
<text 9>, <text 10>, <part count>, <ending
address> /eos/out/get/patch/<channel number>/<part number>/notes = <list index>, <UID>, <notes> /eos/out/get/patch/<channel number>/<part number>/augmented3d/position = <list index>, <UID>, <pos x>, <pos y>, <pos z>, <orientation x>, <orientation y>, <orientation z>, <fpe set index> /eos/out/get/patch/<channel number>/<part number>/augmented3d/beam = <list index>, <UID>, <beam angle>, <color>, <number of shutters>, (<shutter thrust> , <shutter angle>) repeated for every shutter), <gobo>, <gobo name>, <gobo rotate>, <hide beam state> |
<channel number>: Int. <part number>: Int, 0 if referring to the base channel. <list index>: Int, Usually optimized to -1. If target is recalled with some /eos/get/<target>/index=<list index>, this will return the given target's index within its list, 0-indexed. <UID>: String, UID of this Channel, in the form "00000000-0000-0000-0000-000000000000". <label>: String, label for this Channel. <manufacturer>: String containing the manufacturer name. <fixture type>: String containing the name of this fixture. <address>: Int, the starting absolute address of this Channel. <intensity address>: Int, the absolute address of the intensity parameter of this Channel. <current level>: Int, the current intensity level of this Channel. <gel>: String. <text 1>: String. <text 2>: String. <text 3>: String. <text 4>: String. <text 5>: String. <text 6>: String. <text 7>: String. <text 8>: String. <text 9>: String. <text 10>: String. <part count>: Int. <ending address>: Int, absolute address of the last address for this Channel. <notes>: String. <pos x>: Float. <pos y>: Float. <pos z>: Float. <orientation x>: Float. <orientation y>: Float. <orientation z>: Float. <FPE set index>: Int, index of the FPE set used by this channel. <beam angle>: Float. <color>: String. <number of shutters>: Int. (<shutter thrust>, <shutter angle>): Floats, repeated for every shutter. <gobo>: String. <gobo name>: String. <gobo rotate>: Float. <hide beam state>: Bool. <arg index>: Starting argument index for this packet. See OSC List Convention. <arg count>: Number of args sent in this packet. |
/eos/out/get/patch/1/1/list/0/21= 0, "00000000-0000-0000-0000-000000000000", "Channel
Label", "ETC_Fixtures", "Releve_Spot_Direct", 513, 513, 100, "",
"Text1", "Text2", "Text3", "Text4", "Text5",
"Text6", "Text7", "Text8", "Text9", "Text10", 1,
537 - Chan 1 Part 1's list index, UID, label, manufacturer, type, starting address,
intensity address, current level, gel, text fields, part count, and ending
address. /eos/get/patch/1/1/notes=0, "00000000-0000-0000-0000-000000000000", "Note" - Chan 1 Part 1's list index, UID, and note. /eos/get/patch/1/1/augment3d/position=0, "00000000-0000-0000-0000-000000000000", 1.000, 1.000, 1.000, 45.000, 45.000, 45.000, 1 - Chan 1 Part 1's list index, UID, x pos, y pos, z pos, x orientation, y orientation, z orientation, and FPE set. /eos/get/patch/1/1/augment3d/beam=0, "00000000-0000-0000-0000-000000000000", 0.000, "", 4, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, "", "", 0.000, False - Chan 1 Part 1's list index, UID, beam angle, color, number of shutters, shutter thrust and shutter angle for each of the 4 shutters, gobo number, gobo name, gobo rotation, hide beam. |
Returns a minimum of 4 OSC commands. Returns details about a given channel. |
| /eos/out/get/group/<index>/list/<arg index>/<arg count>= <list index>,
<UID>, <label> /eos/out/get/group/<index>/channels/list/<arg index>/<arg count>= <list index>, <UID>, (channel args) |
<index>: Group index. <list index>: Int, Usually optimized to -1. If target is recalled with some /eos/get/<target>/index=<list index>, this will return the given target's index within its list, 0-indexed. <UID>: String, UID of this Group, in the form "00000000-0000-0000-0000-000000000000". <label>: String, label for this Group. (channel args): The list of channels contained within the group. If this command is the response to /eos/get/group/displayed/<index>, the channels will appear as they would on the. <arg index>: Starting argument index for this packet. See OSC List Convention. <arg count>: Number of args sent in this packet. |
/eos/out/get/group/2/list/0/3= 1, "00000000-0000-0000-0000-000000000000", "Group 2
Label" - Group 2's index, UID, and
label. /eos/out/get/group/2/channels/list/0/4= 1, "00000000-0000-0000-0000-000000000000", 1, "11-12" - Group 2's index, UID, and Channels, which are Chan 1 and Chan 11 Thru 12. /eos/out/get/group/2/channels/list/0/3= 1, "00000000-0000-0000-0000-000000000000", "1 + 11 Thru 12" - Group 2's index, UID, and Channels, as a response to /eos/get/group/displayed/<index>. |
Returns a minimum of 2 OSC commands. Returns details about a given group. |
| /eos/out/get/macro/<index>/list/<arg index>/<arg count> = <list index>,
<UID>, <label>, <mode> /eos/out/get/macro/<index>/list/<arg index>/<arg count> = <list index>, <UID>, <macro text> |
<index>: Macro index. <list index>: Int, Usually optimized to -1. If target is recalled with some /eos/get/<target>/index=<list index>, this will return the given target's index within its list, 0-indexed. <UID>: String, UID of this Macro, in the form "00000000-0000-0000-0000-000000000000". <label>: String, label for this Macro. <mode>: String, mode for this Macro. <macro text>: String containing the contents of the Macro. <arg index>: Starting argument index for this packet. See OSC List Convention. <arg count>: Number of args sent in this packet. |
/eos/out/get/macro/2/list/0/4 = 1, "00000000-0000-0000-0000-000000000000", "Macro
Label", "Foreground" - Macro 2's list index, UID, label, and
mode. /eos/out/get/macro/2/list/0/3 = 1, "00000000-0000-0000-0000-000000000000", "Go_To_Cue Out Time 0" - Macro 2's list index, UID, and macro string. |
Returns a minimum of 2 OSC commands. Returns details about a given Macro. |
| /eos/out/get/cue/<list number>/<cue number>/<part number>/list/<arg
index>/<arg count>= <list index>, <UID>, <cue label>, <up time>, <up
time delay>, <down time>, <down time delay>, <focus time>, <focus time
delay>, <color time>, <color time delay>, <beam time>, <beam time delay>,
<preheat>, <curve>, <rate>, <mark>, <block>, <assert>, <link>
(int if cue is in same list, string if cue in different list), <follow time>, <hang time>,
<all fade>, <loop>, <solo>, <timecode>, <number of parts>, <notes>,
<scene>, <scene end>, <multipart index> /eos/out/get/cue/<list number>/<cue number>/<part number>/fx/list/<arg index>/<arg count>= <list index>, <UID>, (Effect args) /eos/out/get/cue/<list number>/<cue number>/<part number>/links/list/<arg index>/<arg count>= <list index>, <UID>, (Link args) /eos/out/get/cue/<list number>/<cue number>/<part number>/actions/list/<arg index>/<arg count>= <list index>, <UID>, (Execute Action args) |
<list number>: Int. <cue number>: Int. <part number>: Int, optional. If not present, the base cue is assumed. <list index>: Int, Usually optimized to -1. If target is recalled with some /eos/get/<target>/index=<list index>, this will return the given target's index within its list, 0-indexed. <UID>: String. <cue label>: String. <up time>: Int. <up time delay>: Int. <down time>: Int. <down time delay>: Int. <focus time>: Int. <focus time delay>: Int. <color time>: Int. <color time delay>: Int. <beam time>: Int. <beam time delay>: Int. <preheat>: Bool. <curve>: String. <rate>: Int. <mark>: String. <parts>: Int, number of parts this cue has. <notes>: String. <scene>: String. <scene end>: Bool, True if this cue is the end of a scene. <multipart index>: Int, 0-indexed list of cue parts of the base cue. 0 if this is a base cue. (Effect args): The effects in this Cue. Single Effects represented as separate int arguments. Ranges represented as strings in the format "x-y". (Link args): The links in this Cue as a list of string arguments. (Execute Action args): The Actions to Execute in this Cue as a list of string arguments. <arg index>: Starting argument index for this packet. See OSC List Convention. <arg count>: Number of args sent in this packet. |
/eos/out/get/cue/1/1/1/list/0/31=1, "00000000-0000-0000-0000-000000000000", "Cue 1
Label", 5000, 0, -1, -1, -1, -1, -1, -1, -1, -1, False, "0", 100, "",
"", "", "2/1", -1, -1, False, -1, False, "", 1,
"Note", "Scene", True, 0 - Cue 1 Part 1 in Cue List 1's index, UID,
label, cue times, attributes, flags, timecode, number of parts, notes, scene data, and multipart
index. /eos/out/get/cue/1/1/1/fx/list/0/4=1, "00000000-0000-0000-0000-000000000000", 901, "903-904" - Cue 1 Part 1 in Cue List 1's index, UID, and effects. /eos/out/get/cue/1/1/1/links/list/0/3=1, "00000000-0000-0000-0000-000000000000", 2 - Cue 1 Part 1 in Cue List 1's index, UID, and linked lists. /eos/out/get/cue/1/1/1/actions/list/0/4=1, "00000000-0000-0000-0000-000000000000", "M5", "Q1 / 5" - Cue 1 Part 1 in Cue List 1's index, UID, and execute actions. |
Returns a minimum of 4 OSC commands. Returns info about a given Cue. |
| /eos/out/get/cuelist/<index>/list/<arg index>/<arg count> = <list index>,
<UID>, <label>, <playback mode>, <fader mode>, <independent>, <HTP>,
<assert>, <block>, <background>, <solo mode>, <timecode list>, <OOS
sync> /eos/out/get/cuelist/<index>/list/<arg index>/<arg count>= <list index>, <UID>, (Link args) |
<index>: Int. <UID>: String. <label>: String. <playback mode>: String. <fader mode>: String. <independent>: Bool. <HTP>: Bool. <assert>: Bool. <block>: Bool. <background>: Bool. <solo mode>: Bool. <timecode list>: Int. <OOS sync state>: Bool. (Link args): Cues that link to this list as string arguments. <arg index>: Starting argument index for this packet. See OSC List Convention. <arg count>: Number of args sent in this packet. |
/eos/out/get/cuelist/1/list/0/13= 0, "00000000-0000-0000-0000-000000000000", "Cue List
Label", "Master (U2)", "Proportional", False, False, False, False, True,
False, -1, False - Cue List 1's list index, UID, label, playback mode, fader mode,
independent state, HTP state, assert state, block state, background state, solo mode state, timecode
list, and OOS sync state. /eos/out/get/cuelist/1/links/list/0/3= 0, "00000000-0000-0000-0000-000000000000", "2/1" - Cue List 1's list index, UID, and links. |
Returns a minimum of 2 OSC commands. Returns details about the given Cue List. |
| /eos/out/get/<palette type>/<index>/list/<arg index>/<arg count> = <list
index>, <UID>, <label>, <absolute palette>, <locked palette, <tracking
channel> /eos/out/get/<palette type>/<index>/channels/list/<arg index>/<arg count>= <list index>, <UID>, (channel args) /eos/out/get/<palette type>/<index>/byType/list/<arg index>/<arg count>= <list index>, <UID>, (byType channel args) |
<palette type>: Bp (Beam Palette), cp (Color Palette), fp (Focus Palette), or ip (Intensity
Palette). <index>: Int, palette ID. <list index>: Int, Usually optimized to -1. If target is recalled with some /eos/get/<target>/index=<list index>, this will return the given target's index within its list, 0-indexed. <UID>: String. <label>: String. <absolute palette>: Bool, True if palette is absolute. <locked palette>: Bool, True if palette is locked. <tracking channel>: Int. (channel args): The channels in the Palette. Single channels represented as separate int arguments. Ranges represented as strings in the format "x-y". (byType channel args): The By Type channels in the Palette. Single channels represented as separate int arguments. Ranges represented as strings in the format "x-y". <arg index>: Starting argument index for this packet. See OSC List Convention. <arg count>: Number of args sent in this packet. |
/eos/out/get/ip/2/list/0/6=1, "00000000-0000-0000-0000-000000000000", "Intensity
Palette 2 Label", False, False, 0 - Intensity Palette 2's list index, UID, label,
absolute state, locked state, and tracking channel. /eos/out/get/ip/2/channels/list/0/4=1, "00000000-0000-0000-0000-000000000000", 1, "11-12" - Intensity Palette 2's list index, UID, and channels. /eos/out/get/ip/2/byType/list/0/4=1, "00000000-0000-0000-0000-000000000000", 2, "20-24" - Intensity Palette 2's list index, UID, and By Type channels. |
Returns a minimum of 3 OSC commands. Returns details about the given Palette. |
| /eos/out/get/preset/<index>/list/<arg index>/<arg count> = <list index>,
channel> /eos/out/get/preset/<index>/channels/list/<arg index>/<arg count>= <list index>, <UID>, (channel args) /eos/out/get/preset/<index>/byType/list/<arg index>/<arg count>= <list index>, <UID>, (byType channel args) /eos/out/get/preset/<index>/fx/list/<arg index>/<arg count>= <list index>, <UID>, (effects args) |
<index>: Int, preset ID. <list index>: Int, Usually optimized to -1. If target is recalled with some /eos/get/<target>/index=<list index>, this will return the given target's index within its list, 0-indexed. <UID>: String. <label>: String. <absolute palette>: Bool, True if palette is absolute. <locked palette>: Bool, True if palette is locked. <tracking channel>: Int. (channel args): The channels in the Preset. Single channels represented as separate int arguments. Ranges represented as strings in the format "x-y". (byType channel args): The By Type channels in the Palette. Single channels represented as separate int arguments. Ranges represented as strings in the format "x-y". (effects args): The effects in the Preset. Single effects represented as separate int arguments. Ranges represented as strings in the format "x-y". <arg index>: Starting argument index for this packet. See OSC List Convention. <arg count>: Number of args sent in this packet. |
/eos/out/get/preset/2/list/0/6=1, "00000000-0000-0000-0000-000000000000", "Preset 2
Label", False, False, 0) - Preset 2's list index, UID, label, absolute state, locked
state, and tracking channel. /eos/out/get/preset/2/channels/list/0/4=1, "00000000-0000-0000-0000-000000000000", 1, "11-12" - Preset 2's list index, UID, and channels. /eos/out/get/preset/2/byType/list/0/4=1, "00000000-0000-0000-0000-000000000000", 2, "20-24" - Preset 2's list index, UID, and By Type channels. /eos/out/get/preset/2/fx/list/0/4=1, "00000000-0000-0000-0000-000000000000", 901, "905-906" - Preset 2's list index, UID, and effects. |
Returns a minimum of 4 OSC commands. Returns details about the given Preset. |
| /eos/out/get/sub/<index>/list/<arg index>/<arg count> = <list index>,
<UID>, <label>, <mode>, <fader mode>, <HTP>, <exclusive>,
<background>, <restore>, <priority>, <up time>, <dwell time>,
<downtime> /eos/out/get/sub/<index>/fx/list/<arg index>/<arg count>= <list index>, <UID>, (effects args) |
<index>: Int, submaster ID. <list index>: Int, Usually optimized to -1. If target is recalled with some /eos/get/<target>/index=<list index>, this will return the given target's index within its list, 0-indexed. <UID>: String. <label>: String. <mode>: String. <fader mode>: String. <HTP>: Bool. <exclusive>: Bool. <background>: Bool. <restore>: Bool. <priority>: Bool. <up time>: String. <dwell time>: String. <down time>: String. (effects args): The effects in the Submaster. Single effects represented as separate int arguments. Ranges represented as strings in the format "x-y". <arg index>: Starting argument index for this packet. See OSC List Convention. <arg count>: Number of args sent in this packet. |
/eos/out/get/sub/2/list/0/13=1, "00000000-0000-0000-0000-000000000000", "Sub 2
Label", "Additive", "Proportional", True, False, True, False,
"P3", "0", "Man", "0" - Sub 2's list index, UID,
label, mode, fader mode, HTP state, exclusive state, background state, restore state, priority, up time,
dwell time, and down time. /eos/out/get/sub/2/fx/list/0/4=1, "00000000-0000-0000-0000-000000000000", 901, "905-906" - Sub 2's list index, UID, and effects. |
Returns a minimum of 2 OSC commands. Returns details about a given Submaster. |
| /eos/out/get/fx/<index>/list/<arg index>/<arg count> = <list index>, <UID>, <label>, <effect type>, <entry>, <exit>, <duration>, <scale> | <index>: Int, effect ID. <list index>: Int, Usually optimized to -1. If target is recalled with some /eos/get/<target>/index=<list index>, this will return the given target's index within its list, 0-indexed. <UID>: String. <label>: String. <effect type>: String. <entry>: String. <exit>: String. <duration>: String. <scale>: Int. <arg index>: Starting argument index for this packet. See OSC List Convention. <arg count>: Number of args sent in this packet. |
/eos/out/get/fx/901/list/0/8=0, "00000000-0000-0000-0000-000000000000", "Effect 901
Label", "Focus", "Immediate", "Immediate", "Infinite",
25 - Effect 901's list index, UID, label, effect type, entry, exit, duration, and
scale. |
Returns a minimum of 1 OSC command. Returns details about a given Effect. |
| /eos/out/get/pixmap/<index>/list/<arg index>/<arg count> = <list index>,
<UID>, <label>, <server channel>, <interface>, <width>, <height>,
<pixel count>, <fixture count> /eos/out/get/pixmap/<index>/list/<arg index>/<arg count> = <list index>, <UID>, (channel args) |
<index>: Int, Pixel Map ID. <list index>: Int, Usually optimized to -1. If target is recalled with some /eos/get/<target>/index=<list index>, this will return the given target's index within its list, 0-indexed. <UID>: String. <label>: String. <server channel>: Int. <interface>: String. <width>: Int. <height>: Int. <pixel count>: Int. <fixture count>: Int. (channel args): The channels in the Pixel Map. Single channels represented as separate int arguments. Ranges represented as strings in the format "x-y". <arg index>: Starting argument index for this packet. See OSC List Convention. <arg count>: Number of args sent in this packet. |
/eos/out/get/pixmap/2/list/0/9= 1, "00000000-0000-0000-0000-000000000000", "Pixel Map
Label", 100, "sACN", 32, 32, 1024, 1024 - Pixel Map 2's list index, UID,
label, server channel, interface, width, height, pixel count, and fixture
count. /eos/out/get/pixmap/2/list/0/3= 1, "00000000-0000-0000-0000-000000000000", 101, "105-106" - Pixel Map 2's list index, UID, label, layer channels, which are Chan 101 and Chan 105 Thru 106. |
Returns a minimum of 2 OSC commands. Returns details about a given Pixel Map. |
| /eos/out/get/curve/<index>/list/<arg index>/<arg count> = <list index>, <UID>, <label> | <index>: Int, Curve ID. <list index>: Int, Usually optimized to -1. If target is recalled with some /eos/get/<target>/index=<list index>, this will return the given target's index within its list, 0-indexed. <UID>: String. <label>: String. <arg index>: Starting argument index for this packet. See OSC List Convention. <arg count>: Number of args sent in this packet. |
/eos/out/get/curve/2/list/0/9= 1, "00000000-0000-0000-0000-000000000000", "Curve
Label" - Curve 2's list index, UID, label. |
Returns a minimum of 1 OSC command. Returns details about a given Curve. |
| /eos/out/get/ms/<index>/list/<arg index>/<arg count> = <list index>, <UID>, <label> | <index>: Int, Magic Sheet ID. <list index>: Int, Usually optimized to -1. If target is recalled with some /eos/get/<target>/index=<list index>, this will return the given target's index within its list, 0-indexed. <UID>: String. <label>: String. <arg index>: Starting argument index for this packet. See OSC List Convention. <arg count>: Number of args sent in this packet. |
/eos/out/get/ms/2/list/0/9= 1, "00000000-0000-0000-0000-000000000000", "Magic Sheet
Label" - Magic Sheet 2's list index, UID, label. |
Returns a minimum of 1 OSC command. Returns details about a given Magic Sheet. |
| /eos/out/get/snap/<index>/list/<arg index>/<arg count> = <list index>, <UID>, <label> | <index>: Int, Snapshot ID. <list index>: Int, Usually optimized to -1. If target is recalled with some /eos/get/<target>/index=<list index>, this will return the given target's index within its list, 0-indexed. <UID>: String. <label>: String. <arg index>: Starting argument index for this packet. See OSC List Convention. <arg count>: Number of args sent in this packet. |
/eos/out/get/snap/2/list/0/9= 1, "00000000-0000-0000-0000-000000000000", "Snapshot
Label" - Snapshot 2's list index, UID, label. |
Returns a minimum of 1 OSC command. Returns details about a giveen Snapshot. |
| /eos/out/get/setup/list/<arg index>/<arg count> = <up time>, <down time>, <focus time>, <color time>, <beam time>, | <up time>: Int, default Intensity Up time. <down time>: Int, default Intensity Down time. <focus time>: Int, default Focus time. <color time>: Int, default Color time. <beam time>: Int, default Beam time. <arg index>: Starting argument index for this packet. See OSC List Convention. <arg count>: Number of args sent in this packet. |
/eos/out/get/setup/list/0/5= 5, 5, 5, 5, 5 - All Cue Default Times are set to 5. |
Returns a minimum of 1 OSC command. Returns the default cue timings from Setup. |
| /eos/out/get/<target type>/<target number>/<part number> | <target number>: Any target number. <part number>: Omitted for targets without parts. |
/eos/out/get/cue/1/1/1 = - Cue 1 Part 1 in Cue List 1 does not exist. |
This is an empty target packet. If the target does not exist, Eos will send this method. |
| /eos/out/get/show/path = <show file path> | <show file path>: String, the file path to the show file. |
/eos/out/get/show/path="C:\Users\user\Documents\ETC\Eos\ShowArchive\showfile.esf3d" -
The file path where the show file can be found. |
| /eos/out/ping = (ping arguments) | (ping arguments): Any number of arguments will be present, matching what was sent with
/eos/ping. |
/eos/out/ping="abcde", 4 - The response to the command /eos/ping =
"abcde", 4. |
Ping with /eos/ping. Any number of args can be passed. |
| /eos/fader/<index>/reset | <index>: Int, OSC fader bank. |
/eos/fader/1/reset - Fader Bank 1 has been reset. |
This method is sent when an OSC fader bank is reset. |
| /eos/cuelist/<index>/reset | <index>: Int, OSC cuelist. |
/eos/cuelist/1/reset - Cue List 1 has been reset. |
This method is sent when an OSC Cue List is reset. |
| /eos/out/get/userlist = <args per user>, (<user id>, <console type>, <console name>) | <args per user>: Int, always 3. <user id>: Int. <console type>: String. <console name>: String. |
/eos/out/get/userlist = 3, 1, "ETCnomad", "PC-Name" - There is only one user
on this show, running on ETCnomad off of PC-Name. |
(<user id>, <console type>, <console name>) args will repeat for each user in
the show. |
| /eos/out/get/chans = <chans> | <chans>: String containing the currently selected chans by the OSC user. |
/eos/out/get/chans = "2, 6-7" - Channels 2 and 6 thru 7 are selected. |
Sends the current selected channels by the OSC user. |
| /eos/out/get/3dserver = <server address>, <UID> | <server address>: String with the Augment3D server. Repeated for multiple IP
addresses. <UID>: String containing the UID of the Augment3D server. |
/eos/out/get/3dserver = "0.0.0.0:3040", "0.0.0.0:3040",
"UID=00000000-0000-0000-0000-000000000000" - The IP addresses and UID of the Augment3D
server. |
Sends the IP addresses of the Augment3D server. |
| /eos/out/get/fpe/<set index>/count = <list index>, <count> | <set index>: Int. <list index>: Int, Usually optimized to -1. If target is recalled with some /eos/get/<target>/index=<list index>, this will return the given target's index within its list,. <count>: Int, number of points in this FPE set. |
/eos/out/get/fpe/1/count = 0, 4 - FPE set 1 has 4 FPE points. |
Sends the number of points within the given FPE set. |
| /eos/out/get/fpe/count = <count> | <count>: Int, number of FPE sets. |
/eos/out/get/fpe/count = 1 - This show has 1 FPE set. |
Sends the number of FPE sets. |
| /eos/out/get/fpe/<set index>/<point index> = <list index>, <point list index>, <text name>, <index>, <x coord>, <y coord>, <z coord> | <set index>: Int. <point index>: Int. <list index>: Int, Usually optimized to -1. If target is recalled with some /eos/get/<target>/index=<list index>, this will return the given target's index within its list,. <point list index>: Int, the point's index within its set, 0-indexed. <text name>: String in the format "FPE Point <set>/<point>". <index>: Int, FP Number. <x coord>: Float, x coordinate of this point. <y coord>: Float, y coordinate of this point. <z coord>: Float, z coordinate of this point. |
/eos/out/get/fpe/1/0 = 0, 0, "FPE Point 1/1", 901, -3.000, 3.000, 0.000 - FPE Point
1/1's id number, and coordinates. |
Sends back information about a particular FPE point. |
| /eos/out/get/fpe/<set index> = <list index>, <label>, <count> | <set index>: Int. <list index>: Int, Usually optimized to -1. If target is recalled with some /eos/get/<target>/index=<list index>, this will return the given target's index within its list,. <label>: String. <count>: Int, number of points in this FPE set. |
/eos/out/get/fpe/1 = 0, "FPE Label", 4 - FPE Set 1's list index, label, and number
of points. |
Sends back information about a particular FPE set. |
| /eos/out/get/params/<chan number> = <manufacturer>, <fixture type>, (<param name>, <level>, <min level>, <max level>) | <chan number>: Int. <manufacturer>: String. <fixture type>: String. <param name>: String. <level>: Float. <min level>: Float. <max level>: Float. |
/eos/out/get/params/1="ETC Fixtures", "Releve Spot Direct", "Intens",
0.000, 0.000, 100.000, "Red", 100.000, 0.000, 100.000, "Lime", 100.000, 0.000,
100.000, "Green", 100.000, 0.000, 100.000, "Blue", 100.000, 0.000, 100.000,
"Pan", 0.000, -270.000, 270.000, "Tilt", 100.000, -135.000, 135.000 - Chan
1's fixture manufacturer, type, and params, with their current level, min level, and max
level. |
(<param name>, <level>, <min level>, <max level>) repeats for all params
in the channel. |
| /eos/out/get/emitters/<chan number> = <manufacturer>, <fixture type>, (<param name>, <level>, <min level>, <max level>) | <chan number>: Int. <manufacturer>: String. <fixture type>: String. <param name>: String. <level>: Float. <min level>: Float. <max level>: Float. |
/eos/out/get/emitters/1="ETC Fixtures", "Releve Spot Direct", "Intens",
100.000, "Green", 100.000, 0.000, 100.000, "Blue", 100.000, 0.000, 100.000 -
Chan 1's fixture manufacturer, type, and emitters, with their current level, min level, and max
level. |
emitters in the channel. |
| /eos/out/get/csv = <offset>, <filesize>, <file> | <offset>: Int. <filesize>: Int, number of bytes in the CSV. <file>: Blob, the file stream. |
/eos/out/get/csv = 0, 72608, (blob) - Sends out the csv file in some format. |
| /eos/out/event/cue/<cue list>/<cue id>/<action> = <label> | <cue list>: Int. <cue id>: Int. <action>: Stop, resume, or fire (depending on the state of the triggered cue). |
/eos/out/event/cue/1/7/fire= "Cue 7 Label" - Cue 7 in List 1 was fired. |
Sends every time a cue is fired, stopped, or resumed. |
Sends every timea cue is fired, stopped, or resumed as a custom cue event. |
| /eos/out/event | /eos/out/event - timecode Learn. |
Sends when a timecode event is learned. |
| /eos/out/event/sub/<sub id> = <on/off> | <sub id>: Int. <on/off>: Int, 0 = off, 1 = on. |
/eos/out/event/sub/1 = 1 - Sub 1 was fired. |
Sends when a sub is fired from a show control event. |
| /eos/out/event/macro/<macro id> | <macro id>: Int. |
/eos/out/event/macro/1 - Macro 1 was fired. |
Sends when a macro is fired from a show control event. |
| /eos/out/event/relay/<address>/<level> = <on/off> | <address>: Int. <level>: Int. <on/off>: Int, 0 = off, 1 = on. |
/eos/out/event/relay/1/1 = 1 - Relay 1 was fired. |
Sends when a relay is fired from a show control event. |
| /eos/out/event/show/<state> = <show file> | /eos/out/event/show/saved =
"C:\Users\user\Documents\ETC\Eos\ShowArchive\filename.esf3d" - The show file was saved
to this location. |
Sends every time a file is saved, loaded, or cleared. |
| /eos/out/cmd = <command line>, <error> | <command line>: String containing the command line. <error>: Int, 0 if no error, 1 if error. |
/eos/out/cmd = "LIVE: Cue 1 : Chan 1 #", 0 - The command line, closed as noted by
Sends every time the command line updates, sent only to that OSC user. |
| /eos/out/user/<user id>/cmd = <command line>, <error> | <user id>: Int. <error>: Int, 0 if no error, 1 if error. <command line>: String containing the command line. |
/eos/out/user/1/cmd = "LIVE: Cue 1 \: Chan 1 #", 0 - User 1's command line, closed
as noted by "#" :$1. |
| /eos/out/softkey/<softkey id> = <text> | <softkey id>: Int, 1 through 12. |
/eos/out/softkey/1 = "Address" - Softkey 1's button text is now
"Address". |
Sends every time a softkey changes, in sets of 12 commands, for each softkey. |
| /eos/out/show/name = <show name> | <show name>: String. |
/eos/out/show/name = "New Show Name" - The name of this showfile changed. |
Sends when the name of the show changes. |
| /eos/out/previous/cue/<list>/<number>/<part> | <list>: Int. <number>: Int. <part>: Int, if a cue part. |
/eos/out/previous/cue/1/1 - Previous cue is now Cue 1 in List 1. |
Sends when the previous cue changes. |
| /eos/out/previous/cue/text = <(cue list)/(cue number) (label) (duration)> | <(cue list)/(cue number) (label) (duration)>: String formatted as "(cue list)/(cue number)
(label) (duration)". |
/eos/out/previous/cue/text = "1/1 Label 5.0" - Previous cue is Cue 1 in List 1, with a
5 second duration. |
| /eos/out/active/cue/<list>/<number> = <percent> | <list>: Int. <number>: Int. <percent>: Float, the percent completed of the active cue, between 0.000-1.000. |
/eos/out/active/cue/1/1 = 0.500 - Active cue (1/1) is halfway complete. |
Sends while the active cue is fading. |
| /eos/out/active/cue/ = <percent> | <percent>: Float, the percent completed of the active cue, between 0.000-1.000. |
/eos/out/active/cue = 0.500 - Active cue (1/1) is halfway complete. |
| /eos/out/active/cue/text = <(cue list)/(cue number) (label) (duration)> | <(cue list)/(cue number) (label) (duration)>: String formatted as "(cue list)/(cue number)
/eos/out/active/cue/text = "1/1 Label 5.0" - Active cue is Cue 1 in List 1, with a 5
second duration. |
Sends when the active cue changes. |
| /eos/out/pending/cue/<list>/<number>/<part> | <list>: Int. <number>: Int. <part>: Int, if a cue part. |
/eos/out/pending/cue/1/1 - Pending cue is now Cue 1 in List 1. |
Sends when the pending cue changes. |
| /eos/out/pending/cue/text = <(cue list)/(cue number) (label) (duration)> | <(cue list)/(cue number) (label) (duration)>: String formatted as "(cue list)/(cue number)
/eos/out/pending/cue/text = "1/2 Label 5.0" - Pending cue is Cue 2 in List 1, with a 5
second duration. |
| /eos/out/active/chan = <chan>, <channel info> | <chan>: Int. <channel info>: String formatted as "[(level)] (fixture type) (fixture description)". |
/eos/out/active/chan = 2, "[100] ETC_Revolution_Original FixtureNote" - Channel 2 is
selected, at Full intensity. |
Sends when the active channel changes. |
| /eos/out/active/wheel/<index> = <param name & level>, <param group>, <level> | <param name & level>: String formatted as "(param name)
[(level)]". <param group>: Int, 1 through 6. <level: Float. |
/eos/out/active/wheel/1 = "Intens [0]", 1, 0.000 - The first parameter is intensity,
which is at 0. |
Sends when the active wheels change. Each wheel will send as a different command, one for each parameter
of the selection. |
| /eos/out/color/hs = <hue>, <saturation> | <hue>: Float. <saturation>: Float. |
/eos/out/color/hs = 296.445, 38.265 - The color of the current selection. |
Sends when the active selection changes. |
| /eos/out/pantilt = <pan min>, <pan max>, <tilt min>, <tilt max>, <pan>, <tilt> | <pan min>: Float. <pan max>: Float. <tilt min>: Float. <tilt max>: Float. <pan>: Float. <tilt>: Float. |
/eos/out/pantilt = -270.000, 270.000, -135.000, 135.000, 0.000, 0.000 - Selected chan's pan
and tilt values are at 0. |
| /eos/out/xyz = <x>, <y>, <z> | <x>: Float. <y>: Float. <z>: Float. |
/eos/out/xyz = 0, 0, 0 - Selected fixture is focused at (0, 0, 0). |
| /eos/out/event/state = <state> | <state>: Int, 0 is Blind, 1 is Live. |
/eos/out/event/state = 0 - Console is in Blind Mode. |
Sends when the console state changes. |
| /eos/out/event/locked = <state> | <state>: Int, 0 is unlocked, 1 is locked. |
/eos/out/event/locked = 1 - Console is locked. |
Sends when the console's lock state changes. |
| /eos/out/ds/<ds index>/<button index> = <target name>, <button name> | <ds index>: Int, representing which Direct Select Bank this is. <button index>: Int. <target name>: String with the target's label in the form "(label) [(target id)]". <button name>: String. |
/eos/out/ds/1/1 = "Beam Palette Label [1]", "1" - The first Direct Select
button in Bank 1 is set to Beam Palette 1. |
Sends when the direct select bank changes. All buttons will refresh with a separate method. |
| /eos/out/ds/<ds index> = <target type> | <ds index>: Int, representing which Direct Select Bank this is. <target type>: String in the format "(Target Type) [(page)]". |
/eos/out/ds/1 = "Beam Palettes [1]" - The first Direct Select Bank is filled with Beam
Palettes. |
| /eos/fader/<bank index>/<fader index> = <level> | <bank index>: Int, representing which OSC fader bank this is. <fader index>: Int. <level>: Float. |
/eos/fader/1/1 = 0.500 - The first fader in OSC Fader Bank 1 is at 50%. |
Sends when the fader bank changes. All faders will refresh with a separate method. |
| /eos/out/fader/range/<bank index>/<fader index> = <min>, <max> | <bank index>: Int, representing which OSC fader bank this is. <fader index>: Int. <min>: Float, minimum level for this fader. <max>: Float, maximum level for this fader. |
/eos/out/fader/range/1/1 = 0.00, 100.000 - The first fader in OSC Fader Bank has a range from 0
to 100. |
Sends when the fader bank is created. All faders will refresh with a separate method. |
| /eos/out/fader/<bank index>/<fader index>/name = <target name> | <bank index>: Int, representing which OSC fader bank this is. <fader index>: Int. <target name>: String. |
/eos/out/fader/1/1 = "S 1 Hold P3" - The first fader in OSC Fader Bank is targeting Sub
1. |
Sends when the faders are updated. All faders will refresh with a separate method. |
| /eos/out/fader/<bank index> = <page index> | <bank index>: Int, representing which OSC fader bank this is. <page index>: Strin representing the current fader page number. |
/eos/out/fader/1 = "2" - OSC Bank 1 is on page 2. |
Sends when the fader page updates. |
| /eos/out/cuelist/<bank index> = <label>, <total cues>, <follow time> | <bank index>: Int, representing which OSC cue list this is. <label>: String. <total cues>: String. |
/eos/out/cuelist/1 = "Cue List 1", 10, 0 - Cue list 1's label, number of cues, and
follow time. |
Sends when the OSC cue list is updated. |
| /eos/out/cuelist/<bank index>/<cue index> = <OSC label>, <cue number>, <cue label>, <notes>, <scene>, <scene end>, <duration>, <remaining> | <bank index>: Int, representing which OSC cue list this is. <cue index>: Int. <OSC label>: String with the cue number, and label. <cue number>: String with cue number and part if necessary. <cue label>: String. <notes>: String. <scene>: String. <scene end>: Bool. <duration>: Int. <remaining>: Int, -1 if not counting down. |
/eos/out/cuelist/1/3 = "2 P2 Label", "2 P2", "Label", "note",
"scene 2", False, 5000, -1 - Cue 2 Part 2's details. |
| /eos/out/param/<param name> = <value>, <min>, <max> | <param name>: Name of the subscribed parameter. <value>: Float. <min>: Float. <max>: Float. |
/eos/out/param/red = 20.000, 0.000, 100.000 - A red parameter was just set to 20. |
Sends when a subscribed parameter updates. See /eos/subscribe. |
| /eos/out/notify/<target type>/list/<arg index>/<arg count> = <sequence number>,
(changed IDs) /eos/out/notify/<target type>/<list number>/list/<arg index>/<arg count> = <sequence number>, (changed IDs) |
<target type>: Any valid Eos Target type. <list number>: Int, if target type is a cue, the cue list number will also send. Excluded for other target types. <sequence number>: Int, to keep track of how many /notify/ commands have been sent, this number will increase with each sent command to uniquely identify them. (changed IDs): List of target ids that changed as a list of arguments. Ranges are represented as a string "X-Y" and individual targets are represented as ints. <arg index>: Starting argument index for this packet. See OSC List Convention. <arg count>: Number of args sent in this packet. |
/eos/out/notify/cue/1 = 0 - Cue 1's sequence number is 0. |
In order to stay in sync with changes as a user makes them, OSC devices can request to be notified of
changes with /eos/subscribe=1. After subscribing, any time a target. |
OSC Eos Keys
OSC names for each key can also be viewed on the Virtual Keyboard [Tab 7] by selecting OSC /key Names in the bottom-right dropdown menu.
| 0 | 1 | 2 |
| 3 | 4 | 5 |
| 6 | 7 | 8 |
| 9 | @ | Label |
| Undo | Delay | External_Relationship |
| Full | Group | Rem_Dim |
| Time | Trace | Park |
| Learn | Mark | Sneak |
| Out | Part | Cue |
| Record | Sub | Thru |
| Update | Level | Follow |
| CueOnly | Query | Record_Only |
| Clear_Cmd | Delete | Enter |
| Bump | Color_Path | Live |
| Blind | Spreadsheet | Cue_Sheet |
| Setup | Fader_Display | Stop |
| Back | Load | Show_Control_Action |
| Resume | To_Full_Snapshot | Gel_Swatch_Setting_Gel_And_Source_Lamp |
| / (use \ key in Address Pattern) | Page_Left | Page_Right |
| Page_Up | Page_Down | Go_0 |
| Assert | Augment3d_Display_Behavior | Filter_Fader_Button |
| Go_To_Cue | Independent | Go_To_Cue_0 |
| Manual_Override | Recall_From | Copy_To |
| Rate | Timing_Disable | Fader_Release |
| Fader_Freeze | Next | Last |
| Help | Select_All | Beam |
| Capture | Native | Filter_Mode |
| Image | Intensity | Select_Last |
| Select_Manual | Control | Focus |
| Color | Shutter | Display_Timing |
| Select_Active | Macro_1 | Macro_2 |
| Macro_3 | Macro_4 | Macro_5 |
| Macro_6 | Macro_7 | Macro_8 |
| Macro_Button | Snapshot | _+% |
| _-% | About | Record Rig Check |
| Run Rig Check | Clear Rig Check | Clear Errors |
| Repeat_On_Go | Restart_Effect | Flip |
| Color_Palette | Beam_Palette | Intensity_Palette |
| Focus_Palette | Effect | Preset |
| Page_Mode | HS | Softkey_1 |
| Softkey_2 | Softkey_3 | Softkey_4 |
| Softkey_5 | Softkey_6 | Softkey_7 |
| Softkey_8 | Control | Swap_Address |
| CIE_XYY | AUTO_DIM | Lock |
| Fine | Shift | Device_Discovered |
| Device_Disconnected | Display_Palettes | Display_Presets |
| Display_Groups | Block | Fan_ |
| Offset | Patch_Done | Even |
| Odd | RGB | CMY |
| Lightwright | Gel_Match_Setting_Hybrid | Color_Gel_Match_Hybrid |
| SAT_ADJUST | COLOR_SCRUB | Allfade |
| Curve | Link | AutoMark_Off |
| Is_In | Isn't_In | Can_Be |
| Can't_Be | Unpatch | Stop_All |
| Move_To | Replace_With | SubType |
| GEL_ | Hold | Color_Fade_Times |
| Plus_FX | Limited_Expand_Mode_Toggle | FaderWing_Page |
| COLOR_SCRUB_REPLAY | WheelAndEncoderButton | FineWheelAndEncoderButton |
| Wheel | ADD_LOG_ENTRY | Down |
| Wheel0 | Wheel1 | Wheel2 |
| Wheel3 | Wheel4 | Wheel5 |
| Wheel6 | Wheel7 | Wheel8 |
| Wheel9 | Keywords | OOS_Sync |
| Patch_1_To_1 | Fader_Page_Back | Magic_Sheet |
| Open_Magic_Sheet_Blind | Magic_Sheet_Recall | Hide_Mouse |
| Color_Gel | Only_Text | Only_Show |
| LD_Flags | Display_Intensity_Palettes | Display_Focus_Palettes |
| Display_Color_Palettes | Display_Beam_Palettes | Tab |
| Format | FlexiChannel_Mode | Preserve_Native_On_Patch_Change |
| Select | Escape | Parameter_View |
| Level_Wheel_Move | Display_Macros | Display_Channels |
| Continuous_Run | Complete | Device_Properties |
| ChannelParam | Device_Errors | Device_Sensors |
| Device_Ignore_Errors | HTP_ | CueOnlyTrack |
| Lock_ | Fader_Assert | Stop_Effect_Button |
| More_Softkeys | Slider_Move | Lamp_Control |
| Flash | OSC_RX | Manual |
| Lamp_On | Douse | Calibrate |
| ShutDown_Fixture | Test_Fixture | Labels_Only |
| Mirror_Mode | Attach | Detach |
| Moves_Only | Marks | Device_Lamp_Controls |
| End_Query | CLEAR_HOLD_COLOR_POINT_ORIGIN | Ordered_View |
| Reorder | Select_Event_At_Current_Time_Code | Flexi_Staging_Mode |
| Workspace | Gel_Swatch_Setting_Gel_Only | User_ |
| Cell Editing | Scene | View |
| Go_Button | Stop_Button | Load_Button |
| Stop_Effect | Open_Fader_Config_Blind | Absolute |
| Linear | StepBased | Action |
| Focus_Effect | Color_Effect | Properties |
| Step | Duration | RCE_On_Off |
| CycleTime | Insert | Include_Color_Fade |
| RCE_Insert | Effect_Edit | RCE_Channels |
| Import_Path | Second_Action | PDV_Point |
| PDV_Time | Insert_Channel | Device_Clear_Errors |
| Select_Last_Params | Encoder Custom | Magic_Sheet_Edit |
| Magic_Sheet_Apply | Display_Magic_Sheets | Import_Gobo |
| OSC_Cue_Recv_String | OSC_Cue_Send_String | Park Buffer |
| Page_Column_1 | Page_Column_2 | Page_Column_3 |
| Page_Column_4 | Page_Column_5 | Page_Column_6 |
| Page_Column_7 | Make_Null | Make_Absolute |
| Make_Manual | Preview | Unmark_At_Zero |
| Mapped_To | Number_Of_Controls | Scene_End |
| Discrete_Instance | Device | Fader_1 |
| Fader_2 | Fader_3 | Fader_4 |
| Fader_5 | Fader_6 | Fader_7 |
| Fader_8 | Fader_9 | Fader_10 |
| Fader_AB | Stop_1 | Stop_2 |
| Stop_3 | Stop_4 | Stop_5 |
| Stop_6 | Stop_7 | Stop_8 |
| Stop_9 | Stop_10 | Bump_1 |
| Bump_2 | Bump_3 | Bump_4 |
| Bump_5 | Bump_6 | Bump_7 |
| Bump_8 | Bump_9 | Bump_10 |
| Fader_Pages | Displays | Escape |
| Encoder_1 | Encoder_2 | Encoder_3 |
| Encoder_4 | Encoder_5 | Encoder_6 |
| Encoder_Wheel_Move | Encoder_Category_Color | Encoder_Category_Shutter |
| Encoder_Category_Image | Encoder_Category_Form | Encoder_Category_Intensity |
| Encoder_Category_Focus | Partitions | Rate_Wheel_Move |
| Fader_Rate | Unmap_Faders | Module_1_Connected |
| Module_2_Connected | Module_3_Connected | Module_1_Disconnected |
| Module_2_Disconnected | Module_3_Disconnected | Expand |
| Data | Insert_Before | Insert_After |
| ParamCategory | Edit_Target | Size |
| HForm | Loop | Done |
| Macro_Loop_Begin | Macro_Loop_End | Macro_Loop_Num |
| Macro_Wait | Execute | Pattern |
| Grouping | Trail | Open_Color_Picker |
| Open_Browser | Haptic_Level_Wheel_Move | Haptic_Rate_Wheel_Move |
| Haptic_Encoder_Wheel_Move | Open_Fader_Config | Master |
| Open_Pattern_Effects | Open_DMX_Patch | Clear_Module |
| Reverse | Interpolate | Run_Cue |
| Entry | Edit_Mode | Open_Cue_Blind |
| Open_Preset_Blind | Open_CP_Blind | Open_BP_Blind |
| Open_IP_Blind | Open_FP_Blind | Open_Sub_Blind |
| Open_Group_Blind | Open_Park_Blind | Open_Effect_Blind |
| Reverse_Steps | Scale | Close_Offset_Display |
| User | Dwell | InTime |
| DecayTime | OnState | OffState |
| StepTime | Check | Patch |
| Swap_Pan/Tilt | Invert_Pan | Invert_Tilt |
| Random_Channels | Lamp_Ctrls | Patch_Mode |
| Attribute_Mode | Database_Mode | FaderModule_1_Connected |
| FaderModule_2_Connected | FaderModule_3_Connected | Display_Effects |
| Bounce | Random_Groups | Random_Rate |
| Cycles | Action | Duration//Cycles |
| System_Settings | User_Settings | Device_Settings |
| RVI_Settings | Color_Gel_Match_Spectrum | Level_ |
| Gel_Match_Setting_Spectrum | Delete_Device | Chan |
| Parameters | Effect_Time_Wheel | Effect_Shape_Vertical_Wheel |
| Effect_Size_Wheel | Effect_Axis_Wheel | Exit |
| Cascade_Entry | Gel_Match_Setting_Brightest | Negative |
| Alternate | Build | Hide_CIA |
| Address | Interface | Offline |
| sACN | Cascade_Exit | Proportion |
| OSC_UDP_RX_Port | OSC_UDP_TX_Port | OSC_UDP_TX_IP_Address |
| Open_Color_Path_Blind | Notes | Type |
| Single_Param | Multi_Param | Minus_Links |
| LoadForGo | Attributes | Event |
| Open_Effect_Status | On | Off |
| EventList | Source | SMPTE_Timecode |
| MIDI_Timecode | NumOfChannels | AutoMark |
| PartitionedControl | MidiTimecode | SmpteTimecode |
| _Fader | MSC_Tx_Device_ID | MSC_Rx_Device_ID |
| Manual_Up_Time | Manual_Down_Time | Scenes |
| Fader | Back_From_First | AllNPs |
| First_Time | Last_Time | Internal |
| External | Frame_Rate | VForm |
| Axis | Flexi_All | Flexi_Show |
| Flexi_Active | Flexi_Moved | Flexi_Selected |
| Positive | Forward | Toggle_Effects |
| Toggle_Effect_Shape_Mode_For_Encoder | Effect_Shape_Horizontal_Wheel | Open_Setup |
| EntryTime | ExitTime | Macro_Entry_Delete |
| AutoPlayback | Track | BackTime |
| RecordConfirm | AutoSave | AutoBlock_Clean |
| GoToCueTime | AssertTime | DeleteConfirm |
| AutoSaveTime | Int | Highlight |
| Intime_Effect | Highlight_Append | Encoders |
| Direct_Selects | Flexi_In_Use | Clear_CmdLine |
| ListView | Edit | HTP |
| Learn_Events | Effect_Scale_Wheel | Effect_Rate_Wheel |
| Reset_System | Clear_Show | Clear_Targets |
| Reset_System_Settings | Reset_User_Settings | Clear_Patch |
| Patch_1_to_1 | Clear_MIDI | Clear_SMPTE |
| Effect_Rotate_Wheel | Effect_Form_Horizontal_Wheel | Effect_Form_Vertical_Wheel |
| Fader_Off | Keyboard_Shortcuts | Or |
| And | Greater_Than | Less_Than |
| Visible_Workspaces | Faders | Chan_Per_Group |
| Open_Snapshot_Blind | Display_Snapshots | Save |
| Save_Folder | Export_Folder | Save_File |
| Export_File | Open_File | Import_File |
| RPU_21 | Quit | Confirm_Command |
| Cancel_Command | Home | Spread |
| Solo | Infinite | Fade_By_Size |
| Fade_By_Size_And_Rate | Stop_And_Fade | Stop_And_Hold |
| Even_Effect | Text1 | Text2 |
| Text3 | Text4 | Text5 |
| Text6 | Text7 | Text8 |
| Text9 | Text10 | Gel |
| Control_ | Close_Fader_Controls | Wrap |
| Cue_Out | Restore_Background | Do_Nothing |
| Go_From_Last | Cue_Up_Time | Cue_Down_Time |
| Cue_Focus_Time | Cue_Color_Time | Cue_Beam_Time |
| Encoder_Mode_1 | Encoder_Mode_2 | Encoder_Mode_3 |
| Encoder_Mode_4 | Encoder_Mode_5 | RPU_1 |
| RPU_2 | RPU_3 | RPU_4 |
| RPU_5 | RPU_6 | RPU_7 |
| RPU_8 | RPU_9 | RPU_10 |
| RPU_11 | RPU_12 | RPU_13 |
| RPU_14 | RPU_15 | RPU_16 |
| RPU_17 | RPU_18 | RPU_19 |
| RPU_20 | Clear_Filters | Luminaire |
| Open_Macro_Preview | Discrete | Global |
| By_Type | MSC_Receive | MSC_Transmit |
| MIDI_Rx_Source_ID | MIDI_Tx_Source_ID | Request_File |
| Dimmer_Double_Offset | A | B |
| Undouble | Cues | Patch |
| Palettes | Groups | Macros |
| Presets | Submasters | Effects |
| Setup | DMX Patch | Show_Control |
| Fixtures | Snapshots | Curves |
| SW_Stop_1 | SW_Stop_2 | SW_Stop_3 |
| SW_Stop_4 | SW_Stop_5 | SW_Stop_6 |
| SW_Stop_7 | SW_Stop_8 | SW_Stop_9 |
| SW_Stop_10 | SW_Stop_11 | SW_Stop_12 |
| SW_Stop_13 | SW_Stop_14 | SW_Stop_15 |
| SW_Stop_16 | SW_Stop_17 | SW_Stop_18 |
| SW_Stop_19 | SW_Stop_20 | SW_Stop_21 |
| SW_Stop_22 | SW_Stop_23 | SW_Stop_24 |
| SW_Stop_25 | SW_Stop_26 | SW_Stop_27 |
| SW_Stop_28 | SW_Stop_29 | SW_Stop_30 |
| SW_Stop_31 | SW_Stop_32 | SW_Stop_33 |
| SW_Stop_34 | SW_Stop_35 | SW_Stop_36 |
| SW_Stop_37 | SW_Stop_38 | SW_Stop_39 |
| SW_Stop_40 | SW_Go_1 | SW_Go_2 |
| SW_Go_3 | SW_Go_4 | SW_Go_5 |
| SW_Go_6 | SW_Go_7 | SW_Go_8 |
| SW_Go_9 | SW_Go_10 | SW_Go_11 |
| SW_Go_12 | SW_Go_13 | SW_Go_14 |
| SW_Go_15 | SW_Go_16 | SW_Go_17 |
| SW_Go_18 | SW_Go_19 | SW_Go_20 |
| SW_Go_21 | SW_Go_22 | SW_Go_23 |
| SW_Go_24 | SW_Go_25 | SW_Go_26 |
| SW_Go_27 | SW_Go_28 | SW_Go_29 |
| SW_Go_30 | SW_Go_31 | SW_Go_32 |
| SW_Go_33 | SW_Go_34 | SW_Go_35 |
| SW_Go_36 | SW_Go_37 | SW_Go_38 |
| SW_Go_39 | SW_Go_40 | SubMove |
| SubDown | SubUp | Curves |
| Open_Curve_Preview | Print_File | Print_Folder |
| All | Break_Nested | Redo |
| Tab_Down | Tab_Up | FaderPagePress |
| FaderPageRelease | Command_History | Real_Time_Clock |
| Analog | Type_ | Relay |
| Filters | Power_Off | Blackout_Enable |
| Fader_Control | Ion_Encoder_1 | Ion_Encoder_2 |
| Ion_Encoder_3 | Ion_Encoder_4 | Encoder_Ext_1 |
| Encoder_Ext_2 | Encoder_Ext_3 | Encoder_Ext_4 |
| Encoder_Ext_5 | Encoder_Ext_6 | Flexi_Patch |
| Fixtures | AddFilterParam | AddFilterCat |
| Go_Bump | Stop_Back | Assert_ |
| Group_Select | Freeze_ | Button_Disabled |
| Solo | Additive | At |
| Backspace | : | No_Priority |
| Emergency_Mark | Hang | Movefade |
| Attributes_ | Enable | Disable |
| Release_CueList | Up | Assert_CueList |
| Rate_CueList | SubRelease | SubAssert |
| StopEffect | vFaderMove_CueList | FaderMove_CueList |
| Grandmaster | GoToCue | AttributeWheel |
| FineWheel | RateWheel | RemFilterParam |
| RemFilterCat | Partition | _Next |
| _Last | Min | Create_Type |
| StopBack | Off_CueList | GoCue0 |
| TimingDisable | Freeze | Manual_Override_CueList |
| Device_Dimmers | Device_RDM | MiniWheel |
| ( | Go_CueList | Open_Partition_Preview |
| Macro | Unown | Blackout |
| Solo_Mode | ) | Form |
| Timing_Disable_Time | Analog_Input | Relay_Output |
| Preheat | Preheat_Off | Timing_Disable_Go |
| Timing_Disable_Back | Off_Time | Create_Virtual_HSB |
| Back_CueList | Stop_CueList | Swap |
| Flexi_Channel_Partition_Toggle | User_ID | Clear_Filters |
| Background_Priority | StopEffect_CueList | Snapshot_Recall |
| SET_CHAN_LEVEL | List_Partition | BPM |
| Phantom | MIDI String | _sACN |
| FaderMove | Limited_Expand_Mode_Enter | Limited_Expand_Mode_Exit |
| Paging_Mode_Offset_Change | Patch_Show_Tab | Patch_Manu_Tab |
| Patch_User_Tab | Update_Lin | New_Keyword |
| Status | Learn_Time_Sample_BPM | Preserve_Blind_Cue |
| Lowlight_Preset | Highlight_Preset | Home_Preset |
| Live_RemDim_Level | Mark_Time | Release_Time |
| Wait_For_Input | Intensity_Master | Proportional_Master |
| LTP | Exclude_From_Record | Magic Sheets |
| Edit_MIDI_SC_Data | Highlight_RemDim | View_Channels |
| Import_Ascii_File | Replace | Import_ASCIIFile_Custom |
| ResyncFrames | CIA_Softkey1 | CIA_Softkey2 |
| CIA_Softkey3 | CIA_Softkey4 | CIA_Softkey5 |
| CIA_Softkey6 | DMX_ | ArtNet |
| Default | RTC_Time | Days |
| Date | Month | Year |
| Before_Sunrise | Before_Sunset | After_Sunrise |
| After_Sunset | Monday | Tuesday |
| Wednesday | Thursday | Friday |
| Saturday | Sunday | Live_ |
| Earliest | Input_String | String_RX |
| String_RX_Source_IDs | Clear_Subs_1to1_ | Latest |
| Learn_Time_Discrete_Steps | Print_Tracked_Levels | Print_Color_Printout |
| Print_Summary_View | New_Show | Repeat_Last_Command |
| Save_Show | Analog_Address | Only_Levels |
| Plus_Show | RFR | Intensity_Block |
| Force_Grandmaster_Move | Lamp_Controls_Edit | ASCII_Manuf |
| ASCII_Delims | ASCII_Levels | ASCII_Case |
| EffectSub | Trckbll On/Off | Inhibitive |
| ChannelFader | String_TX_Source_Name | String_RX_Source_Name |
| Time_Code_ID | Flexi_Patch_Address | Element_Bump_1 |
| Element_Bump_2 | Element_Bump_3 | Element_Bump_4 |
| Element_Bump_5 | Element_Bump_6 | Element_Bump_7 |
| Element_Bump_8 | Element_Bump_9 | Element_Bump_10 |
| Element_Bump_11 | Element_Bump_12 | Element_Bump_13 |
| Element_Bump_14 | Element_Bump_15 | Element_Bump_16 |
| Element_Bump_17 | Element_Bump_18 | Element_Bump_19 |
| Element_Bump_20 | Element_Bump_21 | Element_Bump_22 |
| Element_Bump_23 | Element_Bump_24 | Element_Bump_25 |
| Element_Bump_26 | Element_Bump_27 | Element_Bump_28 |
| Element_Bump_29 | Element_Bump_30 | Element_Bump_31 |
| Element_Bump_32 | Element_Bump_33 | Element_Bump_34 |
| Element_Bump_35 | Element_Bump_36 | Element_Bump_37 |
| Element_Bump_38 | Element_Bump_39 | Element_Bump_40 |
| Element_Bump_41 | Element_Bump_42 | Element_Bump_43 |
| Element_Bump_44 | Element_Bump_45 | Element_Bump_46 |
| Element_Bump_47 | Element_Bump_48 | Element_Bump_49 |
| Element_Bump_50 | Element_Bump_51 | Element_Bump_52 |
| Element_Bump_53 | Element_Bump_54 | Element_Bump_55 |
| Element_Bump_56 | Element_Bump_57 | Element_Bump_58 |
| Element_Bump_59 | Element_Bump_60 | Open_ML_Controls |
| Playback | Grandmaster_ | _Scene_End |
| Network_Inputs | Fader_Edge_Up | Fader_Edge_Down |
| Pixel_Cell_Mapping | Clear_Points | Pending |
| Previous | ACN_Device_Disconnect | Effect_Rate |
| Effect_Size | Rate_Master | Show_Control |
| Scroller_Frame | Fader_Disabled | Use_Content_Config |
| SubStopEffect | Sneak_Effect | SubMove_From_CommandLine |
| Page_Subs | Step | In_Time |
| On | Delete_Effect | Device_Discovery |
| SubFreeze | SubOff | Preheat_Time |
| Add_To_Show | Apply | Restore_Effect |
| Clear_Effect | vSubMove | Dwell |
| Toggle NI Params In Spreadsheet | DMX | Masters_Off |
| Open_Mirror_Dialog | Time_Code | Shutter_Order |
| Center | InterLeave | Num_Groups |
| Mirror_Out | Repeat | Cluster |
| Tracking | Select_NonSub_Active | Lock |
| Always_Absolute | Print_Feedback_Errors | Fan_Curve |
| Last_Ref | Ref_Only | Update_Mode |
| MultiConsole_Power_On | MultiConsole_Power_Off | Cleanup |
| Flexi_Manual | Reset_Update | Break_Nested_Off |
| Last_Ref_Off | Direct_SelectDC_Recall_From | Pixel Maps |
| Split_Cue_Time | Flash_On | Flash_Off |
| GM_Exempt | Earliest_M | PixelMap |
| Pixel_Maps | Encoder Flexi | Spacebar_Go |
| Height | Width | Server_Chan |
| Snap | Manual_Master | Fader_Mode |
| Macro_Mode | Background_Mode | Foreground_Mode |
| Default_Mode | Pixel_Map_Edit | Pixel_Map_Done |
| Pixel_Map_Delete | Invert | Flip_H |
| Flip_V | Rotate_90 | Pixel_Map_Snapshot |
| TB_XY_Swap | TB_Pan_Swap | TB_Tilt_Swap |
| PSD_Time_Countdown | Open_Chan_Effect_Display | String |
| String_TX | String_TX_Source_IDs | Mirror_In |
| String_TX_Port | String_RX_Port | Release |
| Off_ | String_MSC_TX | String_TX_IP_Address |
| Send_String | Shield | Cue List |
| Feedback Errors | Utilization Reports | Show Channels |
| Media_Layer_Chan | Import_All_Media | Export_Media |
| Wait_For_Enter | Import_Show_Media | Priority |
| Pixel_Map_Column_Guides | Pixel_Map_Row_Guides | Pixel_Map_Start_Address |
| Pixel_Map_Horizontal_Order | Pixel_Map_Vertical_Order | Pixel_Map_Direction |
| Pixel_Map_Apply_Check | Pixel_Map_Flash | Pixel_Map_MASK |
| Pixel_Map_Overlay | Pixel_Map_Last | Pixel_Map_Next |
| Prev_Channels | MIDI_Cue_List | Pixel_Map_Library |
| Pixel_Map_File | Pixel_Map_Reorder_Libraries | Pixel_Map_Reorder_Files |
| Pixel_Map_Overwrite | Display_Time_Mode_Latch | Data_Mode_Latch |
| Curve_Edit | Gio_Encoder_Display | Device_Mode |
| Encoder_Lockout | Clear_All_Tabs | Show_Reference_Labels |
| Display_Color_Path_Mode_Latch | Display_Next_Cue_Move | Display_Next_Cue_Move_Latch |
| Display_Park_Level | Display_Park_Level_Latch | Jump |
| Favorite | Column_Resize_Smaller | Column_Resize_Larger |
| Column_Move_Right | Column_Move_Left | Expand_Right |
| Expand_Down | Expand_Collapse_Left | Background_ |
| Minimum | Background | Restore |
| Port_Offset | Post_Select_Softkeys | Only_Active |
| Fade_By_Rate | MIDI_Raw | Send_MIDI_Raw |
| Fader_Spread | Display_Color_Path | Color_Fade_Type |
| ClearCues_CueList | System_Startup_Macro | System_Shutdown_Macro |
| Select_Live_Cue_Live | Select_Live_Cue_Blind | Page_Encoders_Up |
| Page_Encoders_Down | Left_Side_SK_1 | Left_Side_SK_2 |
| Left_Side_SK_3 | Left_Side_SK_4 | Left_Side_SK_5 |
| Left_Side_SK_6 | Left_Side_SK_7 | Next_Live_Display |
| Next_Blind_Display | Flexi_Time | Clear_Calibration |
| Edit_Frame | Degrees_Per_Rev | Percent_Per_Rev |
| Toggle_Accel | Disconnect_Macro | All_Speed |
| Spacebar_disabled_in_setup,_ALT-G_to_enable | Hard_Poweroff | Macro_801 |
| Macro_802 | Macro_803 | Macro_804 |
| Macro_805 | Macro_806 | Macro_807 |
| Macro_808 | Macro_809 | Macro_810 |
| Macro_811 | Macro_812 | Macro_813 |
| Macro_814 | Macro_815 | Macro_816 |
| Macro_817 | Macro_818 | Macro_819 |
| Macro_820 | Time_Template | Resources and Media |
| Plus_Patch | Unpatched | Expand_Collapse_Up |
| CLEAR_TEXT | Clear_All_Workspace_Tabs | Clear_All_Visible_Tabs |
| Reset_All_Tabs | All_Workspaces | Popup_Virtual_Keyboard |
| Macro_701 | Macro_702 | Macro_703 |
| Macro_704 | Macro_705 | Macro_706 |
| Macro_707 | Macro_708 | Macro_709 |
| Macro_710 | Macro_711 | Macro_712 |
| Color_ | _Red | _Green |
| _White | Dark | Color Path |
| Down_Fade | Off_When_Stomped | Unload_When_Stomped |
| Nothing_When_Stomped | Release_When_Stomped | Insert_Last_Target |
| Toggle_Blink | Scene_Only | Go_After_Loop |
| Host | Backup | All_Users |
| All_But_Me | Fader_Load | Notes_Only |
| Target | Invert_Rack | Master_User |
| Release_ | Wing_Fader_Pages | WingFaderPagePress |
| WingFaderPageRelease | Filter | Inhibit_This_Fader |
| Exclude_From_Solo | Exclude_From_Inhibitive | Exclude_From_Grandmaster |
| SET_CHAN_LEVEL_DMX | Master_Only_ | Master_Only |
| Back_ | Manual_Focus_Time | Manual_Color_Time |
| Manual_Beam_Time | Fader Config | Display_Non_Manual_Level |
| Display_Non_Manual_Level_Latch | Display_Cue_Part_Num | Display_Cue_Part_Num_Latch |
| Display_Source | Display_Source_Latch | Display_Prev_Cue_Move |
| Display_Prev_Cue_Move_Latch | Display_Marked | Display_Marked_Latch |
| Display_Address | Display_Addresses_Latch | Display_DMX |
| Display_DMX_Latch | Up_Moves | Down_Moves |
| Live_Moves | Dark_Moves | Autoblock |
| Broken_Mark | Marking | From_Absolute |
| Exclude_From_Event_List | Display_Fader_Ribbon | Low_Priority |
| High_Priority | Start_Effect_Off_Zero | Display_Help_Prompts |
| Effect_Master | Effect_And_Levels | Start_Stop_Effect |
| Mark_NPs | Fire_Relay | Clear_Partitions |
| Levels_Only | Attrs_Only | Popup_Magic_Sheet |
| Popup_Nav_Lock | Silent_Mode | Staging_Mode |
| Max | Man_Time | Fire_Macro |
| Visible_To_Mobile_Apps | Cell | Global_FX |
| Cue_List | Manual_ | Send_String_Global |
| Cells_Off | Cells_Only | Minus_Cells |
| Level_By_Address | SET_LEVEL_FROM_ADDRESS | DMX_Outputs |
| Default_Output_Protocol | Output_In_Client_Mode | USB_MIDI/SMPTE |
| Local_MIDI/SMPTE_Rx | Local_MIDI_Tx | In_Source_Id |
| In_Address_1 | In_Address_2 | In_Address_3 |
| In_Address_4 | Relay_Out_Source_Id | Relay_Out_Address |
| OSC_TX | MSpeed_Controls | Preheat_Preset |
| RFR_Record | Device_Startup_Macro | Device_Shutdown_Macro |
| Device_Name | Sound_Enable | Use_Shift_As_Eos_Shift |
| Element_Stop_1 | Element_Stop_2 | Element_Stop_3 |
| Element_Stop_4 | Element_Stop_5 | Element_Stop_6 |
| Element_Stop_7 | Element_Stop_8 | Element_Stop_9 |
| Element_Stop_10 | Element_Stop_11 | Element_Stop_12 |
| Element_Stop_13 | Element_Stop_14 | Element_Stop_15 |
| Element_Stop_16 | Element_Stop_17 | Element_Stop_18 |
| Element_Stop_19 | Element_Stop_20 | Element_Stop_21 |
| Element_Stop_22 | Element_Stop_23 | Element_Stop_24 |
| Element_Stop_25 | Element_Stop_26 | Element_Stop_27 |
| Element_Stop_28 | Element_Stop_29 | Element_Stop_30 |
| Element_Stop_31 | Element_Stop_32 | Element_Stop_33 |
| Element_Stop_34 | Element_Stop_35 | Element_Stop_36 |
| Element_Stop_37 | Element_Stop_38 | Element_Stop_39 |
| Element_Stop_40 | Element_Pos_1 | Element_Pos_2 |
| Element_Pos_3 | Element_Pos_4 | Element_Pos_5 |
| Bounce_Channels | Console_Lockout | Position |
| Orientation | Save_Fixture | Cancel_Edit |
| Relative_FX_Draw | Relative_FX_Select | Relative_FX_Move |
| Relative_FX_Form | Relative_FX_Gamma | Relative_FX_Size |
| Relative_FX_Rotate | Relative_FX_Select_All | Relative_FX_Smooth |
| Relative_FX_Mirror_Horiz | Relative_FX_Mirror_Vert | Relative_FX_Subdivide |
| Relative_FX_Remove | Relative_FX_Undo | Relative_FX_Redo |
| Use_ESF_File_Format | Break_Mode | | |
| All_Cells | XYZ | Set_Focus_to_Wand |
| Focus_Wand | Virtual_Fixture_Move | OSC_TCP_Server_Ports |
| Beam_Angle | Gobo | System_Status_Notify_ID |
| Reboot | * | Invert |
| Group_Cells | Shutters | Metric/Imperial_Mode |
| Gobo_Rotate | FPE_Set | Physical_Data |
| Editor | Lamp_Controls | _Invert_ |
| Meters | Feet | Feet/Inches |
| A3D_Edit | MIDI_Raw_Send | Network_List_Receive |
| A3D_Camera_View | Push_Shutter_Limit | Augment3d |
| CIA_Open | CIA_Close | Internal_Wing_Offset_Toggle |
| Clear_A3D_Model | XYZ_Format | Augment3d Model |
| Sync_A3D_Model | Hide_Beam | Order_From_Group |
| Effect_Layer_Chan | Store_Staging_Mode_Changes | Clear_Staging_Mode |
| Random_Modifier | Request_A3D_Edit | Release_A3D_Edit |
| Variable_1 | Variable_2 | Variable_3 |
| Variable_4 | Variable_5 | Variable_6 |
| Variable_7 | Variable_8 | Variable_9 |
| Variable_10 | Variable | Display_Colors_In_D65 |
| Background__ | Random_Subgroups | Beam_Edge |
| Next_Target | Last_Target | Complete_Number |
| Encoder_Category_Intensity_Page_Down | Encoder_Category_Color_Page_Down | Encoder_Category_Shutter_Page_Down |
| Encoder_Category_Image_Page_Down | Encoder_Category_Form_Page_Down | Custom_Direct_Select |
| Open_Direct_Select_List_Blind | Custom Direct Selects | Fader_Move_Additive |
| Fader_Wheel_Button | Scroll_Wheel_Button | Scroll_Wheel_Mode |
| Icon | Load_Modifer_Button | Fader_Scroll_Button |
| Fader_Scroll_Wheel_Move | Blind_Next/Last_Affects_Target | Next_Channel |
| Last_Channel | Brightness_Preset_Recall | Brightness_Preset_Record |
| Extinguish | Encoder_Map | Encoder Map |
| Open Encoder Mapping List | Default_Encoder_Map | Default_Mini_Encoder_Map |
| Filter_To_Users | Map_To_Fixture | Create_From_Fixture |
| Missing_Fixture(s) | Recall_Faders_From_SnapShot | USB_SERIAL |
| Scroll_Percent_Per_Rev | Mini_Percent_Per_Rev | Minus_FX |
| Intensity_Cue_Only | Intensity_Cue_Only_Off | Fan_Toggle |
| Select_Target | Record_Effects_In_Presets | Normal_Display |
| Channel_Display | Control__ | MIDI_Ignore_Active_Sensing |
| MIDI_Ignore_Beat_Clock | Backup_Processor | Force_Confirmed |
| Track_SEM | sACN_Priority | Per_Address_Priority |
| Output_Priority | Universe | Output_Protocol |
| Backups_Use_Higher_Priority | Start_Subnet | Broadcast_Mode |
| Start_Universe | Limited | Directed |
| Processor | Processors | Add_Processor |
| OSC_TCP_Mode | Packet_Length_(v1.0) | SLIP_(v1.1) |
| Macro_Zone_Trigger | ZoneChan | ZoneID |
| FDX_2000_Feedback | Override | Zones |
| Other | CLICK_TO_FOCUS | Fader_Wheel_Page |
| Fader_Wheel_Independent_Mode | Fader_Wheel_Extended_Mode | Augment3d_Flags |
| Fader_Wheel_Page_Mode | Alert_Time | Learn_Alert_Time |
| New_Template_Show | Go_Main_CueList | Stop_Back_Main_CueList |
| Unicast_Destinations | Use_Multicast | Use_Broadcast |
| Backups_Automatically_Take_Control | Ignore_Channel_Selection | Forward_ |
| Zones | ArtPoll | Log_Message |
| Expansion_Processing | Lumens | Output_Universes |
| Internal_Start_Cue_Hang | Internal_Template_Show_Load_Clear | Timing_Disable_Stop |
| Take_Control | Wing_Group | Path |
| Allow_Multiconsole_Power_On | Allow_Multiconsole_Power_Off | Expansion_Processing_Hold_Last_Look |
| Expansion_Processing_Hold_Last_Look_Time | On_ | SubOn |
