Creating New Show Files
To create a new show file, navigate within the browser to File > New and press [Select].
You will be prompted for confirmation that you want to create a new show. Any unsaved show data will be lost. Press {OK} to confirm or {Cancel} to discontinue the operation.
If you want your Augment3d model to be included in the new show, check the box labeled Preserve Augment3d Model.
Ion Classic users can select a 1-to-1 patch by pressing the {Patch 1to1} option. A new show created with {Patch 1to1} selected will have a 1-to-1 patch and 1-to-1 channel to sub assignment. On Element Classic, this option is enabled by default.
Template Show Files
A template show file can be assigned in the ECU via Settings > General.
When a show file is assigned as a template, Eos will create a copy of the file in the Templates folder to be used as the default starting point for any new show files. A new option will appear in the CIA under File > New From Template (Template Show File Name) to create a new show file identical to the template. A blank show file can always be created with the File > New option.
Templates can be managed via ECU > Settings > Maintenance > {File Manager...}, and are unaffected by deep clears.
