• Paradigm LightDesigner Keyboard Shortcuts
    The Paradigm LightDesigner software incorporates many keyboard shortcuts to make programming easier. These include standards like Cut, Copy, and Paste, as well as shortcuts for moving between views.
    Many of these shortcuts are displayed as tooltips when hovering over buttons, such as the Network View:
    They are also given in the right-click Context Menu (e.g. of a Zone):
    context menu
    Please note that not all of these shortcuts are available in all versions of Light Designer.
    General Shortcuts
    CTRL-O: Open file
    CTRL-W: Close file
    CTRL-S: Save file
    CTRL-Z: Undo
    CTRL-Y: Redo
    CTRL-X: Cut
    CTRL-C: Copy
    CTRL-V: Paste
    CTRL-N: new project
    Del : Deletes the selected item(s)
    CTRL-U: Upload project dialog (Added in LD 3.0 to match Mosaic)
    CTRL-R: Retrieve project dialog (Added in LD 3.0 to match Mosaic)
    Change views
    ALT-1: Design view
    ALT-2: Program/Simulate View
    ALT-3: Timed Events View
    ALT-4: Macro Editor view
    ALT-5: Patch view
    ALT-6: Network view
    ALT-7: System Estimator
    F1: Launch help
    F2: edit text or name
    CTRL +: zoom in
    CTRL -: zoom out
    Multiple Selection
    In LightDesigner, it is possible to select multiple items such as buttons and faders on a station. This is done by holding the Alt key to select the first item, then holding the Control [CTRL] key while left-clicking following items. Each item selected will have a red box to indicate it is selected.
    When multiple items of the same type are selected, they can be copied and pasted using the right-click context menu:
    Smart Assign Control Function
    This function will allow you to select a range of Buttons or Faders and then assign a range of similar control functions to them.
    Note: You can only select items on a single station or page. All selected items must be the same type. You can not select both buttons and faders at the same time.
    • Use Left-Click+Alt+Control to select a range of buttons or faders on a station.
    • Right-Click on any selected item and Left-Click {Smart Assign Control Function} from the subsequent menu
    • Within the Set Control Function window, select the function for the range of Buttons or Faders
    • Left-Click {OK}
    • Note: The order for Smart Assign is based on the alphabetical sort order of the Browser.
    Copy/Paste Whole Stations
    You can copy and paste entire stations of the same type. If you make changes to one station and then copy it, you can paste those changes to other stations of the same type, rather than re-programming each station individually. This is done using Paste Station Control Assignments in the right-click Context Menu:
