  • Express Console Remote Macros
    The Express Console and Express LPC's provide four remote macro inputs through the 15-pin connector on the back panel labeled Remote Macro. A user-supplied remote device connects to the console via a 24 AWG, aluminum-shielded, multi-conductor cable with one twisted pair designated for each switch (Belden 9507 S-R PCV Insulated or Alpha 5477 80 Deg. C 300 V PVC).
    The cable connector at the remote device will vary depending on the device itself.
    Console connector DB-15 female Connector type Pin Function1 + Macro 1,9012 - Macro 1,9013 + Macro 1,9024 - Macro 1,9025 + Macro 1,9036 - Macro 1,9037 + Macro 1,9048 - Macro 1,9049
    Remote Trigger - normally closed (30V 1 amp max)
    10 Remote Trigger - normally open (30V 1 amp max)
    11 Remote Trigger - common (30V 1 amp max)
    12 Ground
    13 Ground
    14 + 12 Vdc fused
    15 + 12 Vdc fused
