About Magic Sheets
Magic sheets are user-created interactive displays that allow you to customize how you interact with and view your show data and lighting system. A variety of objects can be tied to show data, such as channels, palettes, and other record targets, and added to a custom layout with additional graphics and icons.
Accessing Magic Sheets
Magic Sheet [Tab 3]
Magic Sheet can be opened in a standalone tab from the Workspace Layout Menu or by using [Tab] & [3]. Multiple instances of this tab may be open simultaneously.
By default, the tab opens to the magic sheet browser. If no magic sheets exist in the show file, the browser will be empty. Use the {New Magic Sheet} option to create the lowest new magic sheet number available. Created magic sheets are available via the browser alongside all other magic sheets in the show file.
When a magic sheet is open, a pop-up magic sheet browser can be accessed from the Magic Sheet Tab Configuration menu, or using Multi-Touch Gestures.
Use [Displays] {Magic Sheet} [#] [Enter] to recall a specific magic sheet by number.
Magic Sheet List [Tab 14]
The magic sheet list displays a list of all created magic sheets, their labels, and how many links to views have been saved for each magic sheet. Views can be saved via the Magic Sheet Tab Configuration menu.
Magic Sheet List can be opened in a standalone tab from the Workspace Layout Menu or by using [Tab] & [1][4].
This display can also be accessed:
  • Using {Magic Sheet} {Magic Sheet}.
  • Via a connected keyboard with ALT+MM.
  • From the Central Information Area (CIA) under Browser > Record Target Lists > Magic Sheets.
To label a magic sheet, use the syntax {Magic Sheet} [#] [Label] <name> [Enter].
Pressing [Label], when a label has already been applied to a magic sheet, will display the label on the command line for editing. Pressing [Label] a second time will clear the label, or you can press [Clear] to remove the label one character at a time.
Magic Sheet Direct Selects
Magic sheets can also be accessed using Direct Selects [Tab 4]. Using a direct select assigned to a magic sheet will open the magic sheet tab and display the selected magic sheet. Pressing a different magic sheet direct select will change the sheet open in the tab.
Magic sheets can be assigned Icons, which can be configured to appear on the direct select button in Direct Selects ([Tab] [4]) or Custom Direct Selects ([Tab] [3][9]).
Magic sheets can be navigated using a mouse, a keyboard, or a touchscreen. Many navigation options are also available via tools in the Magic Sheet Layout Toolbar, available in the Magic Sheet Editor.
Hold [Shift] or SHIFT while scrolling for fine control, allowing you to zoom in or out more precisely.
