Cue List Index Tab Configuration
Tab configuration menus contain additional sets of context-specific options for a display. They can be accessed from the bottom of the Tab Tools by right-clicking or double-tapping either the tab or the gear icon to the left of the frame's tab bar.
  • Display Cue Parts - displays the individual parts of a part cue. When not enabled, the number of parts for that cue will display as a superscript number beside the cue's number.
  • Display Cue Links - displays the Link / Loop information.
  • Display Scenes - displays cue Scenes
  • Display PSD Time Countdown - displays the cue category times countdown in the PSD as a cue is fading.
  • Display Cues - displays the top half of the cue list index, which shows all the stored cues.
    • Not available on Element 2 or Element Classic
Reorder Columns
Reorder columns allows you choose what data displays in the top and bottom halves of the Cue List Index and what order it displays in. To make changes to the top half, select {Cues}. To make changes to the bottom half, select {Cue List}.
By default, all columns except notes will be displayed. The arrow keys on the right can be used to move columns around. Columns with multiple options are moved in groups. To select a column header to move, click or tap the name. The check boxes suppress or enable. When an item is enabled to display, a check mark will be in the corresponding box.
Default
The Cue List Index takes its default settings from the Playback Status Display. The default is identified with parentheses. See Playback Status Display Tab Configuration.
  • Reset to Default - returns the settings to the default state that you created.
  • Reset to Eos Default - returns all settings to the Eos defaults.
