Editing in Blind
The following are representative methods used for editing palettes in Blind:
- [2] {Iris} [At] [Enter] - removes the current parameter value from channel 2.
- [1] {Iris} [5] [0] [Enter] - selects channel 1 and sets iris value to 50.
- [2] [Copy To] [5] [Enter] - copies the information from channel 2 to channel 5.
- [6] [Recall From] [Focus Palette] [1] [Enter] - recalls the values for channel 6 from Focus Palette 1 but not the reference.
- Element Classic users will need to use {Focus Palette}
You may set Blind levels with encoders, if available.
When editing in Blind, it is possible to remove an instruction from any palette by selecting the channel and parameter and pressing [At] [Enter] or {Make Null} [Enter].
[Recall From], [Copy To], Move To (accessed by pressing [Copy To] [Copy To]), and {Replace With} may be used to create and edit palette data. See Advanced Manual Control.
Note: While editing palettes in blind, hitting [Recall From] [Recall From] will put [Recall From] [Palette] on the command line.
Palettes can be assigned an icon, which can be configured to appear on the direct select button in Direct Selects (Tab 4) or Custom Direct Selects (Tab 39). See Icons.
