Eos Console Hardkey Shortcuts
Displays
Note: [Data] is used below. Consoles without this hardkey use the following syntax:
Data and Params can also be accessed via a connected keyboard with CONTROL+D.
  • [Data] - while held, toggles the display to show data living under referenced data. Keep [Data] depressed to page. [Data] [Data] locks this display.
  • [About] & [Data] - while held, toggles the display to show absolute data. [About] & [Data] [Data] locks this display.
  • [Time] - while held, toggles the display to show discrete timing. Keep [Time] depressed to page.
  • [About] & [Time] - while held, toggles the display to show discrete time data.
  • [Data] & [Focus] / [Color] / [Beam] - to expand/ suppress categories on displays.
  • [Data] & {Parameter Tiles} - to suppress/ display individual parameters from the display when not in summary view.
  • [Displays] & [Level Wheel] - controls the Main slider in Brightness Settings.
  • [Displays] [Displays] - resets the CIA to the browser.
  • [About] & [Path]/{ Color Path} - toggles the display to show the color paths.
  • [Shift] & [Select] - reset display columns.
  • [Shift] & [Tab] - clear all tabs on the current monitor (but keep locked frames) (Does not clear tab 1 and 2).
  • [Shift] & [Tab] [Tab] - clear all tabs on all monitors (but keep locked frames) (Does not clear tab 1 and 2).
  • [Shift] & [Tab] [Tab] [Tab] - clear all tabs on all monitors (including locked frames) (does not clear tab 1 and 2).
  • [About] & [Label] - toggles the Live / Blind display to show reference labels or numbers, based on setup.
  • [About] & [Label] [Label] - double press to lock reference labels on. Press [About] & [Label] again to unlock.
  • [Shift] & [Live/ Blind] - advances the displays to the next instance of Live or Blind.
  • [Live] (when already in Live) - re-syncs the selected cue to the most recently activated cue.
  • [Blind] (when already in Blind) - re-syncs the selected cue to the live selected cue (when blind cue has been changed or when preserve blind cue has been enabled).
  • [Flexi] & [Time] - to invoke Flexi time view on displays.
  • [Format] & [Level Wheel] - zooms the display in focus.
  • [Tab] & [Up/Down Arrow] - cycle workspaces.
  • [Tab] & [Left/Right Arrow] - move displays.
  • [Tab] & [number] - open or focus specific displays.
  • [Flexi] & [.] - turns on Flexi multicells off mode. Press again to turn off.
  • [About] & [Live] - displays the DMX values.
  • [About] & [Mark] - displays the mark cue used by the channels.
  • [About] & [Next]/[Last] - displays the next cue that the channels move in or the last cue that the channels moved in.
  • [About] & [Park] - displays the parked levels.
  • [About] & [Part] - displays the cue part number for each parameter.
  • [Expand] & [Effect] - opens the Effect Status Display (Tab 8).
Operations
  • [At] [Enter] - removes move information from selected channel/parameters.
  • [At] [At] - set to Level (as defined in Setup).
  • [Color] (Encoder Paging Key) & Encoder Movement - hold Color Point while adjusting parameters.
  • [Copy To] [Copy to] - posts Move To on the command line.
  • [Full] [Full] - sets selected channels intensity to “full” and self terminates.
  • [Label] [Label] - appended to a record target command, clears the current label, this includes show file labels.
  • [Recall From] [Recall From] - posts Recall From Cue to the command line.
  • [Record] [Record] - posts Record Only to the command line.
  • [Select Active] [Select Active] - Select Active minus submaster contributions.
  • [Shift] & [Select Active] - posts Select Non-Sub Active.
  • [Shift] & [Enter] - repeats last command line, unterminated; loops last five commands.
  • [Shift] & [At] - recalls last channels and parameters without terminating; loops last five commands.
  • [Shift] & [Block] - posts Intensity Block to the command line.
  • [Shift] & [Clear] - clears the command line.
  • [Shift] & [Delay] - posts follow.
  • [Shift] & Encoder Paging Key - posts the category to the command line. For beam subcategories, press Image, Form or Shutter twice to post Beam. (Ion/Gio)
  • [Shift] & Encoder Movement - accesses fine mode.
  • [Shift] & Encoder Push/ Toggle - posts the parameter to the command line. (Ion)
  • [Shift] & Gel Tile - cycles through three modes of Brightness.
  • [Shift] & [Full] or [Shift] & [Out] - flash on or flash out.
  • [Shift] & [+] or [Shift] & [-] - +% or -%.
  • [Shift] & [Highlight] - appends highlight to the current channel selection.
  • [Shift] & [Label] - opens the existing cue note for the selected cue or creates a new one.
  • [Shift] & [Select Last] - posts additional channel selection options to the softkeys.
  • [Shift] & [Sneak] - makes manual data un-manual.
  • [Shift] & [Update] - shortcut to Save.
  • [Shift] & restore manual faders - reset faders to zero without asserting control.
  • [Shift] & {Direct Select} - posts DS to the command line without terminating.
  • [Shift] & [Next] or [Shift] & [Last] - advances the cue without changing channel selection.
  • [Sneak] [Sneak] - releases NPs of selected channels and self-terminates.
  • [Timing Disable] & [Go] or & [Back] - cuts the next cue or cuts the last cue.
  • [Thru] [Thru] - [Thru] command accesses only channels displayed in the current Flexi state (unless the range specified is not in the current display). [Thru] [Thru] selects the range regardless of the flexi mode.
  • [Trace] [Trace] - forces a previously inactive light to track its new intensity setting backwards.
  • [Undo] - clears an unterminated command line. Otherwise opens undo controls.
  • [Update] & [Sub Bump] - to update a specific submaster.
  • [n] [At] [/] [/] [m] [Enter] - sets direct DMX value (m) for channel (n).
  • [Shift] & [Delay] [Delay] - posts hang to the command line.
  • [Shift] & [About] - opens a command line search window.
  • [Shift] & [.] - posts minus cells to the command line. This is for use with multicell fixtures.
  • [.] - posts multicell fixture cells or cells only to the command line when used after channel numbers.
  • [Shift] & [Int Palette] - posts preset on the command line (Element & Element 2).
  • [Displays] & [Record] - puts a marker in the log file.
Face Panel
  • [Shift] & [Escape] - to lock and unlock face panel.
  • Encoder Paging Keys & [Number] - pages to the desired encoder control page.
  • [Escape] & Encoder Paging Keys - locks the encoders. Press any encoder page button to unlock.
  • [Flexi] & Encoder Paging Key - to invoke flexi encoder states.
  • [Fader Controls] & [Bump Button] - select a fader page on wings.
  • [Fader Page] & Rate Wheel - rolls the selected fader page. (Ti/Eos/Gio)
  • [Fader Page] & [number] - select a fader page on integral faders. (Ti/Eos/Gio)
  • [Fader Page] - increments the fader page by 1.(Ti/Eos/Gio)
  • [Shift] & [Fader Page] - decrements the fader page by 1. (Ti/Eos/Gio)
  • [Learn] & [Load] - opens the selected fader's configuration tools.
  • [Off] & [Load] - releases control of content, restoring to background and leave cue list with pending cue in tact.
  • [Release] & [Load] - releases control of content, restoring to background, and resets cue list to top.
  • [Shift] & [Go] or [Shift] & [Back] - cuts the pending cue or the previous cue.
  • [Shift] & [Load] - to remove content from a fader.
  • [Shift] & [Stage] - toggles Scroll Lock on and off.
