Temporary Fader Mapping
Presets and palettes can be used to create a temporary list of content that can be played back on a fader.
Note:  This list is not recorded. If the fader is unloaded, the list cannot be recalled.
To create a list, press the [Load] button of an unmapped fader. You can then select presets or palettes to add to your list either by the command line or from the direct selects.
Once mapped, the fader will default to Master Only mode. See Master Only for more information.
The list will use the timing assigned to the fader.
A fader with temporary mapping will have the cue list options for Back From First and Go From Last. These are Cue List Properties, see Cue List Properties
The list of targets will display in the Fader Configuration List (Tab 36), in the Fader List (Tab 35), and in the Fader Ribbon.
