Quick Access tools are available at the top of each display.
There are three icons:
This option allows you to view a favorite magic sheet in a small pop-up window over your current display. The pop-up magic sheet functions just like a traditional magic sheet and is interactive. .
Press the wand icon to close the display when opened.
A pop-up magic sheet can be assigned in Setup>User>Displays>Popup Magic Sheet. If a magic sheet has not been assigned in Setup, when you first click the pop-up magic sheet icon, you will be able to select a default magic sheet from a list of the available ones.
In Setup>User>Displays>Popup Nav Lock, you can enable or disable the zoom and scroll navigation for pop-up magic sheets. This option is enabled by default.
See About Magic Sheets for more information
This option allows you quick access to the ML controls display in a small pop-up window over your current display. See Moving Light Controls for more information about this display.
Press the automated fixture beams icon to close the display when opened.
This option displays your favorite snapshots in a small pop-up window for quick access. Select a snapshot to recall it. Favorite is an option that can be selected or deselected when recording a snapshot.
Press the camera icon to close the display when opened.
See About Snapshots for more information.
