Mosaic Show Integration
Integration of a Mosaic Show into the Unison Paradigm system allows the two systems to initiate control across the two products, allowing Paradigm and Mosaic to seamlessly function as a single control system. Paradigm can initiate control within the Mosaic Controller and can also receive control commands from the connected Mosaic control system.
Note: This feature requires the use of Mosaic Designer software version 1.10 or later and Paradigm LightDesigner version 2.1 or later software.
Configuring Paradigm for Interaction with Mosaic
Each project in a Paradigm system (excluding the server level project) offers the ability to add one or more Mosaic Show as part of the project. Mosaic Shows are not patched to specific outputs or controls, instead they are associated to a Paradigm Architectural Control Processor. By default they are associated with the Paradigm Arch Processor with the lowest Arch Processor ID (Processor 1 for example) in the specific project.
Add Mosaic Show(s) to the LightDesigner Configuration
Each project in LightDesigner offers a Mosaic Shows node directly beneath the Processors node in the Browser. For Server Projects, Mosaic Shows are added to each of the sub-projects, and they cannot be added at the server level.
  1. Right-click on "Mosaic Shows" node in the Browser and select "Add Mosaic Show" from the context menu. A Mosaic Show is added to the Browser and provided a default name (for example Mosaic Show 1, Mosaic Show 2, etc.). By default the controller is automatically associated to the Paradigm Processor with the lowest processor ID for that project (Processor 1, for example).
  2. Select the new Mosaic Show in the Browser and use the Property Editor to configure its properties:
  3. Save the LightDesigner configuration file.
    Note: For successful Mosaic Show integration, you must identify the physical Mosaic Show Controller to the Paradigm system and identify the Paradigm system to the configuration for the Mosaic Show.
Configuring Mosaic for Interaction with Paradigm
Each Mosaic Show that will be integrated with a Paradigm system must be configured to interface with the Paradigm processor it has been associated to in LightDesigner. Information on configuring Mosaic to communicate with Paradigm can be found in the Mosaic online help system.
Configuring the Control Actions
Controls must be configured in either Paradigm or Mosaic configurations to trigger the other product. Additionally, the receiving product must have a configuration that contains presets, timelines, scenes, or other objects to be controlled. It is recommended that you complete the majority of programming in both the Paradigm and Mosaic controllers independently before configuring the interactions between the systems.
Note: You must add the Mosaic Show to the LightDesigner project before you can assign a control action.
Configuring Paradigm to Trigger Mosaic
Assigning controls that initiate commands from Paradigm to trigger a Mosaic Show is done using the same process as assigning other control functions to Paradigm stations. This control feature is available for Advanced users only. For details on assigning control functions, see Assigning Station Control Function
After assigning the Mosaic control action, use the Property Editor to configure the action and the indication for the action. Be sure to fully specify each of the specific properties related to the selected control type.
Note: All control actions that are indicated below with an asterisk requires Mosaic v2.8.0 or later.
Indicator Function
Note: All indicator functions that are indicated below with an asterisk requires Mosaic v2.8.0 or later.
Mosaic indicator function properties are populated by default with the matching control assignment properties. Change these settings only as needed.
Configuring Mosaic to trigger Paradigm
Paradigm objects can be controlled from a connected Mosaic Show using triggers that have been configured in Mosaic Designer Software. Once the triggers are configured in Mosaic Designer software, they are then uploaded to the Mosaic Show Controller where access to the trigger can be made from the built-in Web Interface.
Expose Objects to Mosaic
When a Mosaic Show has been added to a project in LightDesigner, objects such as Presets, Groups, Channels, Walls, Macros and Overrides, in that project are updated with an additional property in the Property Editor called "Expose to Mosaic". By default, this property is set to "No" for all objects. You will need to change each object property to "Yes" for the object to be made available to Mosaic for control.
Note: You must open the line of communication between the two products. The Mosaic Show has to be identified by IP Address in LightDesigner to interface with a Paradigm Processor and the Paradigm Processor has to be identified by IP Address in Mosaic Designer to interface to the Mosaic Show.
  1. Select the object node in the Browser.
  2. Select the "Expose to Mosaic" property in the Property Editor and change that selection to "Yes". Enabling the per object exposure to Mosaic from LightDesigner reduces the unnecessary messages that could be sent, cluttering the communications.
Create a Trigger and Action in Mosaic Designer
The Mosaic Show must have a Trigger for each command to be sent to the related Paradigm object for control to be initiated by Mosaic. Reference the Mosaic Designer software help system for information to create a Trigger.
