Manual Control
Access to manual control settings.
Manual Timing
In this section you may change the default times for manual changes to occur in live. Times can be set for each parameter category (Intensity Up, Intensity Down, Focus, Color, and Beam). You may use the [Thru] key to enter a value for all categories.
The default for each of these is 0 seconds.
Button Values
This section allows you to specify the values for certain buttons or settings used in manual control. The following settings are available:
Highlight
This section allows you to specify highlight preferences. The following settings are available:
Default Times
In this section you may change the default times for sneak commands and the respective feature response times based upon parameter category. The default for these is 5 seconds, except for back time, which uses a default of 1 second. You can assign separate timing values to the Release and Off functions.
You can assign [Cue] as a timing value for the {Go to Cue Time} and {Back Time} The syntax, {Go to Cue Time} [Cue] [Enter] or {BackTime} [Cue] [Enter] will assign cue as the timing value.
When [Go To Cue] [n] [Enter] or [Back] is used, the fade will happen in the time set in the destination cue.
You can assign a separate time value for [Timing Disable]. When a fader has been set to timing disable mode, cues will use the time set in Setup. The default time is 0.
Encoder Map
This section allows you to specify a custom encoder mapping to be used as the default for all
fixtures. If left blank, any fixture types without a custom map assigned will use the default Eos encoder mapping.
For more information on custom encoder maps, please see Custom Encoder Maps.
