Submasters & Triggers
Triggers can be used to tie actions such as macros, show control, or snapshots to sub playback.
{Execute}
When used after selecting a sub on the command line, {Execute} will open a trigger display in the CIA.
Buttons for common targets are available on the left. These options are also available below as softkeys.
The table on the right lists all triggers associated with the selected sub, along with their reference labels. You can remove individual triggers using the delete icon on each line.
Syntax
A variety of command line syntax is available when working with triggers:
Action Syntax
Add a trigger to a sub [Sub] [#] {Execute} [+] {Target} [#] [Enter]
Remove a trigger from a sub [Sub] [#] {Execute} [-] {Target} [#] [Enter]
Remove all triggers from a sub [Sub] [#] {Execute} [Enter]
Replace all triggers in a sub with the one specified* [Sub] [#] {Execute} {Target} [#] [Enter]
Remove all instances of the specified target from a sub* [Sub] [#] {Execute} {Target} [Enter]
* Confirmation required
