Pressing {Fader Control} {Stop Effect} [Enter] will stop all running effects.
To stop a specific effect, press: [Effect] [x] [At] [Enter].
You may also stop effects on specific channels by [selecting channels] [Effect] [Enter].
You may also remove an effect instruction by [selecting channels] [Effect] [At] [Enter]. This command will work in live or blind. You can also stop the whole effect by pressing [Effect] [x] [At] [Enter].
A {Stop Effect} command can be assigned to a list of channels in a cue without an effect tracking into it, or to a list of channels in a submaster.
A stop all command can be used to place stop flags in cues and subs on channels or parameters that are not currently running effects, allowing subs and cues to stop other souces effects even if continuous run is enabled.
