External links can be used to trigger actions such as macros, show control, or snapshots.
When you press {Execute}, the softkeys will change to {Time Code}, {Macro}, {Relay}, {On}, {Off}, {Snapshot},{Go After Loop}, {MIDI Raw}, and {String}.
Note: For information about using {Relay}, {Time Code}, and {MIDI Raw}, see the sections on Relay Outputs, Time Code, and Midi Raw.
To trigger a macro:
To trigger a snapshot:
To trigger a relay either on or off:
{Go After Loop} will execute the next cue after a follow link/loop sequence has ended. By default, the loop will end with the last cue in the sequence. {Go After Loop} will use the follow time assigned to the last cue in the sequence.
To remove an external link:
