PD Test
  • ColorSource Relay Multiverse
    House of Worship
    Houses of worship can easily supplement current lighting in existing facilities or create effective and dynamic lighting in non-traditional locations.
    House of Worship
    Schools
    Schools can easily and safely transform multi-use facilities into performance spaces.
    Schools
    Backstage
    Temporary lighting positions backstage or even in the rig benefit from power and data control.
    Backstage
    Special Events
    Special events are even more special. One power cable and wireless DMX keep the party moving with quick setup and strike.
    Special Events
  • Creating options and reducing traffic with Multiverse technology
    City Theatrical Multiverse wireless DMX is a powerful addition to the ColorSource Relay system. Multiverse couples efficient use of radio energy with intelligent management of DMX signal broadcasting to create a resilient and far-reaching wireless DMX network.
    It’s been proven to work better in crowded wireless environments, so your signal can get through no matter where you are.
    Both the Multiverse SHoW Baby and ColorSource Relay require minimal setup and zero programming before use.
    Simply connect hard-wired DMX (Multiverse SHoW Baby or Multiverse Node) or sACN (Multiverse Transmitter) to automatically send wireless DMX to any ColorSource Relay Multiverse Receiver within a 100-meter (328-foot) range. Take them out, plug them in, and your new relay system is fully operational!
    ColorSource Relay Multiverse Receiver is also compatible with the first generation of ColorSource Relay transmitters (CST-W) in legacy SHoW DMX mode. See the ColorSource Relay Quick Guide for details.
    A solution for every system
    Whatever your system, ColorSource Relay makes power and data management easy.
    If you have plenty of DMX ports, the hard-wired ColorSource Relay DMX is perfect to fine-tune your power distribution.
    The ColorSource Relay Multiverse Receiver gives you wireless capabilities. It works with the first generation of ColorSource equipment, or with the new Multiverse technology.
    A Multiverse SHoW Baby Transmitter sends one universe of DMX to receivers up to 100 meters away, with six selectable SHoW IDs. Unlocking the Multiverse options via RDM gives users access to 147 more SHoW IDs, ensuring a clean DMX signal no matter the environment.
    For systems that need the most universes, the Multiverse Transmitter is capable of transmitting up to 10 universes of DMX over the 2.4 GHz bandwidth, perfect for ColorSource relay Multiverse Receivers. The Multiverse Transmitter can receive DMX via a 5-pin XLR connection or via sACN or ArtNet, thanks to a built-in ethernet port.
    Both Wired and Multiverse Receiver models have power and data capabilities to handle up to 16 amps of connected fixtures. Auto-sequencing and zero-cross switching mitigate inrush nuisances automatically. Each Relay can support up to 32 DMX or RDM receivers.
    Product Features
    • Receives DMX/RDM wirelessly via SHoW DMX or Multiverse (ColorSource Relay Multiverse Receiver) or via hard-wired 5-pin connector (ColorSource Relay DMX)
    • ColorSource Relay Multiverse Receiver operates in the 2.4 GHz frequency range
    • Hard-wired DMX/RDM out via 5-pin connector
    • Input voltage: 90–250 V; 47–63 Hz
    • Two-pole air-gap relay supports 208 V and Delta power applications
    • Auto sequencing: randomized turn-on delay in each relay ensures that no two turn on at the same time across a system
    • Zero-cross switching minimizes inrush draw
    ColorSource Relay Multiverse Family
    • Choice of relay mode:
      • Auto Mode (default) - switches on when DMX/RDM signal is detected; switches off after signal is no longer detected
      • DMX Mode - switches on when DMX address is at or above 50%; switches off below 50%
      • RDM Mode - switches on via RDM command; switches off via RDM command or power cycle
    • RDM configuration via software such as ETC Concert or Eos; or via the ETC Set Light or City Theatrical DMXcat® apps for Multiverse Transmitter
    • USB port for easy software upgrades
    • Three mounting options: pipe, fixture yoke, and wall mount
