Local Contact Properties
Local contact inputs and contact outputs are physically located on the I/O board of the Unison DRd Rack Enclosure or ERn Control Enclosure that hosts the selected
- Object Type - the type of object you have selected. This property is not selectable or editable.
- Name - The name of the contact (default is Contact Input 1).
- Project Scope - This setting is specific to a server project. Use to set which sub-project will be affected by the control (default is the sub-project that the control is associated.
- Control Space - This setting is specific to a contact input. Use to set which space will be affected by the control (default is Global).
- Lockout Group - This setting is specific to a contact input. Set the lockout group to which this contact is associated (default is "A").
- Lockout Threshold - This setting is specific to a contact input. The threshold that must be met or exceeded which causes the contact to become disabled (default is "50%").
- Priority - This setting is specific to a contact input. Set the priority level of the action for the contact.
- Override - This setting is specific to a contact input and allows the assignment of an override to the contact.
- Control Group - This setting is specific to a contact input. Set which control group the contact is associated.
- Text - This free text field is available for a contact output only.
- Function - Set the controls function from the available options in the drop-down menu..
Note: Function properties are dependent on the contact type selected, either contact input or a contact output.
Note:
Note:
When a function is selected, additional properties will display to further specify the contacts function. Properties can become very specific depending on the selections made. For best results, fully specify a property for each of the "Function" sub-property selections. Functions that are displayed in blue denote an Advanced user function.
- Runtime Properties - a "view only" property that displays the current “live” properties for a contact input.
- State - this is a "view only" property of a contact input that displays the position of the contact ( "Open" or "Closed").
