MIDI Show Control Devices
MIDI Show Control data carries a device ID (MIDI channel) within the data packet. Setup > System > Show Control > MIDI allows you to specify two device IDs: one for reception and one for transmission. This is different than the ACN Group Tx and Rx IDs, which are the show control gateway source ID and transmitting ID. The show control gateway, assigned an ACN Group Tx and Rx ID, can send MIDI messages to and from several Device IDs all on the same MIDI line.
Only MSC data that matches the MSC Receive Channel in Setup, or an All Call ID (127), will be interpreted by your console.
All outgoing MSC data contains the specified transmit device ID, as specified in Setup.
